Author Topic: Simple Questions, Simple Answers (FAQ in the OP)  (Read 6228206 times)
Offline SeeThruHead
« Reply #7100 on: Tue, 01 April 2014, 18:54:53 »
Is that a typo or am I misunderstanding something?
 Painted QFR          Poker 2
« Reply #7101 on: Tue, 01 April 2014, 18:55:42 »
Massdrop and/or Mechanicalkeyboards.com
Ignore pacifist
Offline Pacifist
  • on hiatus
« Reply #7102 on: Tue, 01 April 2014, 18:56:35 »
MassDrop
MechanicalKeyboards.COM
sorry for the shorthand
« Last Edit: Tue, 01 April 2014, 18:59:39 by Pacifist »
Offline SeeThruHead
« Reply #7103 on: Tue, 01 April 2014, 19:26:03 »
ah i should have been able to figure that out. Does massdrop do ergo kits constantly. Because it seems like a missed the last one. If they do another one again soon I'll probably wait for that.
 Painted QFR          Poker 2
« Reply #7104 on: Tue, 01 April 2014, 19:26:59 »
It seems like they run the ergo-dox kit pretty often.
Offline Pacifist
  • on hiatus
« Reply #7105 on: Tue, 01 April 2014, 19:29:17 »
a lot
probally their #1 hit
Offline ithinkimkorean
« Reply #7106 on: Tue, 01 April 2014, 21:00:29 »
What screwdriver do I need for the kpad? It looks like the ones they give you to put together ikea furniture. I want to buy one off amazon. Can't find the size.
Also, do I need to open it to take off the metal feet?
« Reply #7107 on: Tue, 01 April 2014, 21:03:14 »
What screwdriver do I need for the kpad? Also, do I need to open it to take off the metal feet?
I think the KMAC stuff all uses the same size screws. Try looking for a 2.0mm hexdriver/hex key. That's what I'm using for my KMAC. And if it's like my board, yes you'll have to open it up to get the feet off.
« Last Edit: Tue, 01 April 2014, 21:07:36 by CPTBadAss »
« Reply #7108 on: Tue, 01 April 2014, 21:04:48 »
I think the KMAC stuff all uses the same size screws. Try looking for a 2.0mm hexdriver/hex key. That's what I'm using for my KMAC. And if it's like my KMAC LE, yes you'll have to open it up to get the feet off.
So quick. Thanks  :thumb:
Offline minho
  • i'm kind of back
« Reply #7109 on: Tue, 01 April 2014, 23:10:21 »
Is there a difference between the actually switches that are used in plate mounted vs PCB mounted switches? (ex. would I be able to mount the same switches on PCB or plate? Were I to build my own keyboard, would I have to determine if I want PCB or plate mount prior to buying the switches?)
« Reply #7110 on: Tue, 01 April 2014, 23:11:28 »
PCB mount you can snip off the 2 plastic pins at the bottom and "convert" it to plate mount.
Plate mount can't technically be put onto a PCB without a plate while maintaining the stability that the two pins are there for.
So it only really matters if you're planning on building PCB mounted because you can't have plate mounted switches.
Offline HPE1000
  • Keycap Paparazzo
« Reply #7111 on: Tue, 01 April 2014, 23:13:43 »
PCB mount switches have 2 little plastic nubs on them, but they can just be clipped off if you are using a plate to mount the switches on. So best bet it to just aim for PCB mount switches if you are not sure what you are using them for.
Edit: Sifo beat me
Offline Jalberstone
« Reply #7112 on: Wed, 02 April 2014, 02:23:41 »
What is the difference between cherry mx greens and whites besides the fact that whites have a softer click?
« Last Edit: Wed, 02 April 2014, 02:50:26 by Jalberstone »
Offline epzy
  • HHKB Fiend
  • ded
« Reply #7113 on: Wed, 02 April 2014, 05:04:44 »
Where can I get a black replacement spacebar for a black Realforce 88u?
Offline BlueBär
« Reply #7114 on: Wed, 02 April 2014, 06:31:49 »
Apart from the color and the click, nothing.
Some say there's extra lube on Whites (which seems to be the case on the MX Whites I have), but others, including Cherry themselves, say there is no extra lube. Could be a different plastic as well, but why the click is dampened on Whites is not really clear.
Since EK doesn't offer any black sets for it, ebay, some Japanese auction sites, the classifieds etc. should be your best bet.
Offline Pacifist
  • on hiatus
« Reply #7115 on: Wed, 02 April 2014, 20:50:23 »
Are resistors mandatory? My techkeys card and qazpad didn't need any and I just soldered the LEDs directly to the switch
« Reply #7116 on: Wed, 02 April 2014, 20:53:22 »
Because those had SMD resistors soldered on already? So yes...
Offline Pacifist
  • on hiatus
« Reply #7117 on: Wed, 02 April 2014, 20:56:28 »
Did not know that
are resisitors always SMD? Can they be throughhole?
« Reply #7118 on: Wed, 02 April 2014, 21:02:46 »
1) Are resisitors always SMD?
2) Can they be through hole?
1) No
2) Yes
« Reply #7119 on: Wed, 02 April 2014, 21:21:34 »
Has anyone done any force measurements for MY switches?
And what are the white alps switches called described as follow, white stem, black body, clicky, almost remind me of a buckling spring sound, very springy sound. It said ALPS on the switch and I think had a letter and the number 21
« Last Edit: Wed, 02 April 2014, 21:32:26 by SpAmRaY »
« Reply #7120 on: Wed, 02 April 2014, 21:46:04 »
1) Has anyone done any force measurements for MY switches?
2) And what are the white alps switches called described as follow, white stem, black body, clicky, almost remind me of a buckling spring sound, very springy sound. It said ALPS on the switch and I think had a letter and the number 21
1) Check out this post on Geekhack
2) From what you're describing, they sound like Simplified White Alps. But to be sure, can you check Mr. Interface's simulation links to see if your switches sound like the sounds he posted?
« Last Edit: Wed, 02 April 2014, 21:50:19 by CPTBadAss »
« Reply #7121 on: Wed, 02 April 2014, 21:49:01 »
Bro your link ****ed up
http://www.mrinterface.com/
« Reply #7122 on: Wed, 02 April 2014, 21:50:42 »
Thanks mang <3
« Reply #7123 on: Wed, 02 April 2014, 21:51:00 »
Thanks CPT! I'm falling asleep at the computer so I'll look into these more in 8 hours or so. :D
Offline vovkab
« Reply #7124 on: Wed, 02 April 2014, 23:58:43 »
Does anyone know where I can find keycaps set from official ergodox keyboard image?
« Reply #7125 on: Thu, 03 April 2014, 00:33:07 »
Welcome to Geekhack!
Those look almost like DSA.
You might try the Granite GB: http://geekhack.org/index.php?topic=56354.0
Offline SeeThruHead
« Reply #7126 on: Thu, 03 April 2014, 02:27:38 »
Is it possible to make a one hand ergodox. And for it to be the left hand? I'm thinking of an orbweaver alternative.
 Painted QFR          Poker 2
« Reply #7127 on: Thu, 03 April 2014, 03:53:11 »
I made one a few weeks ago. It works great with soarer's firmware. I've been meaning to post pictures sometime.
The keyset in that render was never actually produced, though the model is closest to SP's DSA
« Last Edit: Thu, 03 April 2014, 03:54:44 by dorkvader »
Offline delobe
« Reply #7128 on: Thu, 03 April 2014, 05:15:02 »
Does anyone have a picture of the inside of their edsyn soldapult? Just got one wanted to check I wasn't missing anything. There's just a simple metal pole inside. Also, maintenance?
Thanks
de hand, de fingres, de nails, de arma, de bilbow
« Reply #7129 on: Thu, 03 April 2014, 06:33:55 »
1) Does anyone have a picture of the inside of their edsyn soldapult?
2) Maintenance?
1) I can't find a decent picture through a quick Google search. Picture I did find won't open up to the proper size. You can try searching for pictures. The model number is DS017. I did find this Edsyn video where he disassembles the tool.
2) Check out this post from mkawa and this other post from mkawa. This video looks ok as well.
Offline delobe
« Reply #7130 on: Thu, 03 April 2014, 07:04:14 »
2) Maintenance?
Found a link on youtube to my soldapult from yours, many thanks.
Offline combataran
« Reply #7131 on: Thu, 03 April 2014, 07:04:35 »
How much for a Ruby red topre brobot, CC and gas mask respectively?
Cherry G80-1000HFD | CM Storm Spawn | Keypuller.com - Key Caps News & Database
Offline BlueBär
« Reply #7132 on: Thu, 03 April 2014, 07:07:09 »
We have a seperate price check thread in the classifieds, but for CCs you should check the Clack info thread.
Offline ideus
  • Björkö.
« Reply #7133 on: Thu, 03 April 2014, 09:59:49 »
I thought in that yesterday when I read this post, but I do not want to be accused to advertise it, so I prefer to say nothing.
Offline esoomenona
  • Gnillort?
« Reply #7134 on: Thu, 03 April 2014, 10:00:45 »
That looks to be a rendered image. I don't think those caps exist. Granite may be best bet.
Offline BlueBär
« Reply #7135 on: Thu, 03 April 2014, 10:19:31 »
You are allowed to sell things in the classifieds, it is not a commercial group buy (apart for SP) and it is not even your group buy. There is no "hidden advertising" you could have done or profited from.
Offline ideus
  • Björkö.
« Reply #7136 on: Thu, 03 April 2014, 10:22:45 »
Yeah that is correct sir. Thank you for your feedback. It cleared my thoughts.
Offline meiosis
  • Time
« Reply #7137 on: Thu, 03 April 2014, 18:02:45 »
I'm sure many people have asked before me, but can someone point me in the direction to find some 3mm led's that work with boards such as an LZ-GH? without much modding (or trimming the bulb)
Keyboards:
Aripeko TKL
Offline Pacifist
  • on hiatus
« Reply #7138 on: Thu, 03 April 2014, 18:03:43 »
http://www.ebay.com/itm/321332751221?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7139 on: Thu, 03 April 2014, 18:28:32 »
You can see more selection with this search. It may be mobile specific cause I'm on my phone.
http://m.ebay.com/sch/i.html?_nkw=2x3x4mm+led&isNewKw=1&_pgn=1&epp=24&itemId=&isRefine=true&mfs=GOCLK&acimp=0&sqp=2x3x4mm+led&trksid=p2056088.m2428.l1313.TR0.TRC0.X2x3x4mm+led
Offline Pacifist
  • on hiatus
« Reply #7140 on: Thu, 03 April 2014, 19:08:48 »
is the only way to open MYs is through taking off the whole thing or can I open it from the top?
figured it out
« Last Edit: Thu, 03 April 2014, 19:25:03 by Pacifist »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7141 on: Thu, 03 April 2014, 19:54:25 »
Two more things to note:
- there are crystal clear and diffused style led's there. Choose what you think you will enjoy.
- they will come in either 2.x forward voltage (red, orange, yellow) or 3.x forward voltage (white, blue, green, pink$$). The difference is that they require different resistors.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #7142 on: Thu, 03 April 2014, 20:28:12 »
I believe there was a third range which was high 1.x to low 2.x forward voltages.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7143 on: Thu, 03 April 2014, 20:37:54 »
Ya, there may be a third range.  I remember there being some in the high 1s and low 2s, so for simplicity I just put 2.x.  I think everything I bought was >=3.2.
« Reply #7144 on: Thu, 03 April 2014, 21:23:44 »
orange / red are usually 1.7 Vf
yellow amber can vary, but are usually in the 2.0 Vf
White/blue are usually 3.1 vf to 3.4 vf
they don't necessarily require different resistors, but you can use ones that will make them brighter if you like. At that point, your KB will be VERY bright, so I say to calculate a value and stick with it.
« Last Edit: Thu, 03 April 2014, 21:25:15 by dorkvader »
Offline Dreamre
    • kbdlife
« Reply #7145 on: Thu, 03 April 2014, 22:00:55 »
I'm planning on relubing my vintage blacks and I wanted to know the most effective method of removing old lube on the stems. Thanks!
Offline Melvang
« Reply #7146 on: Thu, 03 April 2014, 22:03:23 »
I would just use a paper towel and re apply.  The bit of residue shouldn't hurt anything.  If you are really worried about it you could use a soak of as high of percentage as you can find of rubbing alcohol.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7147 on: Thu, 03 April 2014, 22:07:31 »
Not sure I would recommend soaking the switch bases, only the stems.  The leafs in the switch bases may corrode if you soak them.  I know they will if you soak them in water (there are pictures on here somewhere).  You are taking a risk (IMO) if you soak the bases in alcohol...
Offline Dreamre
    • kbdlife
« Reply #7148 on: Thu, 03 April 2014, 22:13:43 »
Thanks for the replies! I'm actually using new housings. I will probably go with the cloth rubbing off method. I asked because I saw someone here leave the stems soaking in water with something else.
Offline Melvang
« Reply #7149 on: Thu, 03 April 2014, 22:16:16 »
I wouldn't be afraid to soak the housings in alcohol for 10 to 15 minutes before drying.
