Author Topic: How similar are the HHKB Pro and HHKB Pro 2??  (Read 12745 times)
Offline iMav
  • geekhack creator/founder
« on: Mon, 07 January 2008, 13:47:41 »
Close enough to do this:
So, the keyboard I am using now is a black HHKB Pro 2 with a white top case (and white dip switch cover) from my white HHKB Pro (1).
I had to remove the circuit board from the top case as the connector from the circuit board is different.  There are two plastic stand offs that are longer on the HHKB Pro 2 top case than on the original...so I had to trim those.  Otherwise, the mixing and matching of parts are a perfect fit!
Offline karlito
    • http://altitudegame.com
« Reply #1 on: Mon, 07 January 2008, 18:55:47 »
geek... ;)
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
« Reply #2 on: Mon, 07 January 2008, 19:47:36 »
maniac.
They are very distinctive looking.
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #3 on: Mon, 07 January 2008, 21:05:26 »
Nice, not what I would have done, but I like it.
Offline iMav
« Reply #4 on: Mon, 07 January 2008, 21:20:31 »
Quote from: xsphat;2262
As soon as I saw them together, I knew I wanted black keys on the white topcase.  And to actually have the USB hub of the HHKB Pro 2, I needed to use the black bottom.  I think this looks slick.
Now, the white (and gray) keys on the black topcase?  Well, that's just the crap left over (kinda like Danny Devito in "Twins").  ;)
Offline xsphat
  • Enlightened
« Reply #5 on: Mon, 07 January 2008, 21:48:30 »
Here's a 'Shop of what I'd do:
Offline iMav
« Reply #6 on: Mon, 07 January 2008, 22:29:42 »
Quote from: xsphat;2265
I wonder what the "leftovers" looked like.
Offline xsphat
  • Enlightened
« Reply #7 on: Mon, 07 January 2008, 22:39:48 »
Quote from: iMav;2266
