Author Topic: Budget Camcorder? $150-200  (Read 1937 times)
Offline gameaholic
« on: Thu, 21 February 2013, 20:32:26 »
What's the best budget Camcorder as of Feb 2013?  HD is a plus.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Re: Budget Camcorder? $150-200
« Reply #1 on: Fri, 22 February 2013, 08:08:56 »
My Panasonic Lumix camera is several years old and takes great videos, if .MOV is an acceptable format.
Only real problem is that you can't zoom while it is running.
- Franklin Roosevelt 1933
