Author Topic: Cherry MX Red Majestouch 2: Period key (. Del) on numpad doesn't input "."  (Read 1232 times)
Offline killazys
Hi all,
As stated in the topic, my numpad's "." key seems to be whacky: with Numlock off, the Delete function works, but with Numlock on, the "." won't appear in Command Prompt or anywhere else. I'm running Windows 8 Pro.
Anyone seen this issue before?
Offline gnubag
Re: Cherry MX Red Majestouch 2: Period key (. Del) on numpad doesn't input "."
« Reply #1 on: Fri, 22 February 2013, 17:44:15 »
well, have you tried the filco with another pc?
Offline killazys
« Reply #2 on: Fri, 22 February 2013, 18:14:20 »
Weirdly enough, a restart fixed the issue. I did not try it with another PC..
EDIT: And again, the same issue occurs after some time. I can't seem to pinpoint the reason.
« Last Edit: Sun, 24 February 2013, 19:12:14 by killazys »
