Author Topic: Noppoo choc mini 84 red, bios, unable to boot, Intel DH77DF  (Read 3108 times)
Offline Nedlinin
« on: Fri, 22 February 2013, 23:02:25 »
My computer won't boot with this keyboard in. It is a nice keyboard and i want to keep it. How do i fix this.
Offline jabar
Re: Noppoo choc mini 84 red, bios, unable to boot, Intel DH77DF
« Reply #1 on: Sat, 23 February 2013, 00:04:11 »
The Choc Mini uses a USB hack to give it NKRO over USB which can be incompatible with many BIOSes and OS like OSX. I am not sure there is a work around.
e: the computer should boot but using the keyboard within BIOS might be problematic.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Nedlinin
« Reply #2 on: Sat, 23 February 2013, 00:13:20 »
Ok. Thanks.
I will be ordering a usb male to ps2 female, and a usb female to ps2 male. It will be arriving soon. Will post if it works. I read it in a mac thread.
Offline jabar
« Reply #3 on: Sat, 23 February 2013, 00:15:50 »
Ok. Thanks.
Yep, that is the only possible workaround I've heard of for Macs. Will have to be tested.
Phantom 7bit
Offline Nedlinin
« Reply #4 on: Sat, 23 February 2013, 19:05:55 »
Bios attemps to boot from the keyboard? . Enable the checkbox, usb devices (keyboard and mouse) will not be available after OS boot, but BIOS will boot faster. This will not affect USB capabilities after OS boot.
Temporary fix. You lose some things. For now i won't have to unplug my keyboard to boot and stick it back in after
« Last Edit: Sat, 23 February 2013, 19:13:40 by Nedlinin »
Offline Nedlinin
« Reply #5 on: Mon, 04 March 2013, 00:15:23 »
14879-0
Problem fixed. Works. I bought one of these just so i can get into the bios. thanks to whoever mentioned this. sold my logitech g710+
« Last Edit: Mon, 04 March 2013, 00:17:16 by Nedlinin »
