Author Topic: Question about the matias mini tactile pro  (Read 1659 times)
Offline jooks1184
« on: Sun, 24 February 2013, 23:56:17 »
Hey guys, I'm sorry if this is a stupid question but is the matias mini tactile pro mac only or can you use it with a PC?
Offline calavera
Re: Question about the matias mini tactile pro
« Reply #1 on: Mon, 25 February 2013, 00:07:10 »
edit: nevermind
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #2 on: Mon, 25 February 2013, 00:14:58 »
It's made for Macs (though they are considering a PC version).
You can use it with Windows, but the Windows and Alt key places will be swapped unless you install a driver to make them normal.
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #3 on: Mon, 25 February 2013, 00:38:46 »
Yeah it's technically a Mac keyboard but you can plug it in a PC and use it.  Like burz said you have to use a third party program like autohotkey or something to swap the window and alt key.  After that you might need to map a few key like insert, delete, print screen... Etc since Mac doesn't have those functions on their keyboard.
As for the PC version it's estimated to come out end I this year, so it's gonna be a long wait.  Kind of why I end up buying the Quiet Pro in the end  :P
