Author Topic: Post your Topre Keyboard  (Read 4625310 times)
Re: Post your Topre Keyboard
« Reply #250 on: Wed, 19 June 2013, 05:33:18 »
Now I get to legitimately post in this thread! :)
Now I gotta find that Topre yellow Esc that GirlShark WizBro sent across a while back ...
Offline longweight
  • philanthropist
« Reply #251 on: Wed, 19 June 2013, 05:47:49 »
« Last Edit: Wed, 19 June 2013, 05:50:14 by longweight »
« Reply #252 on: Wed, 19 June 2013, 06:05:28 »
Longweight! How many toppers do you have!!
Offline longweight
  • philanthropist
« Reply #253 on: Wed, 19 June 2013, 06:12:39 »
3 Now :)
« Reply #254 on: Wed, 19 June 2013, 06:15:46 »
3 Now :)
I've just seen so many pics from you, thought maybe more :)
You planning on getting any more?
Offline longweight
  • philanthropist
« Reply #255 on: Wed, 19 June 2013, 06:32:43 »
Probably not, I now have one for each desk. Going to cannibalise two to make the perfect board soon :)
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #256 on: Wed, 19 June 2013, 07:49:52 »
HHKB 55g type s?
Offline longweight
  • philanthropist
« Reply #257 on: Wed, 19 June 2013, 08:14:47 »
RF 45g uniform silenced in white :)
Offline hoasican2004
« Reply #258 on: Wed, 19 June 2013, 09:06:44 »
Sorry for dust, cat hairs, dirt and bad photo. :>
I love this case very very very much  :p I will buy one in someday  :-*
Offline ekw808
  • Ekw
« Reply #259 on: Tue, 02 July 2013, 13:40:28 »
Just go my 10thAE in the mail today, again.
[One Keyboard at a time]
Offline Dgsbllx
« Reply #260 on: Tue, 02 July 2013, 13:42:15 »
Very nice indeed, those caps really suit.
Offline Michael
  • Formerly Bro Caps
« Reply #261 on: Tue, 02 July 2013, 14:04:49 »
FTFY
« Reply #262 on: Tue, 02 July 2013, 17:06:26 »
Offline megaxpop
« Reply #263 on: Sat, 06 July 2013, 06:09:42 »
that bear's so kute,man! :))
Offline ikoma
« Reply #264 on: Sat, 06 July 2013, 08:50:22 »
Where do you guys get your keycaps?
Everything is so expensive.  :'(
QFR x2 | HHKB Pro2 | IBM Model M2 x2 | IBM Model M | Razer Blackwidow | NeXT Keyboard (Alps)
« Reply #265 on: Sun, 07 July 2013, 00:26:25 »
Pretty much from EK - although there are only black and white complete sets for HHKB.
Offline Ultratude
    • Ultratude's Blog
« Reply #266 on: Sun, 07 July 2013, 00:33:15 »
Hey longweight, how did you remove the logo?
Offline finaltheorem
« Reply #267 on: Fri, 12 July 2013, 15:46:47 »
I'm also interested to hear how longweight got the logo off.  Can you tell a difference in the texture where the logo used to be?
I've been cleaning up a bunch of older keyboards and noticed Mr. Clean Magic Eraser took off marks very easily, so I would venture a guess that it might take the label off with enough elbow grease.  Also thinking toothpaste or some other type of rubbing compound might do the job without marring the textured surface too much, or making it shiny and smooth.
Using:
IBM Model M (1396790)  |  IBM XT Model F (at work)
Collection:
2 IBM Model M terminal boards (1392595)  |  Unicomp 101, Black w/Black Blanks  |  IBM XT Model F  |  SIIG Minitouch, black vinyl dye  |  7 Dell AT101Ws  |  Coolermaster QFR w/Blues - gifted
In the mail:
Realforce 87U Tenkeyless 55g (Black)  |  IBM AT Model F  |  Leopold FC660C (Whenever EK gets them in stock)
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #268 on: Tue, 16 July 2013, 21:02:18 »
« Reply #269 on: Tue, 16 July 2013, 21:11:05 »
Need a mint left shift too ;)
Offline Michael
  • Formerly Bro Caps
« Reply #270 on: Tue, 16 July 2013, 21:31:29 »
Aweee yeeeeeeee. Sweet Type55g-S, bro.
« Reply #271 on: Wed, 17 July 2013, 05:41:07 »
Added a little bit of (non-yellow) colour to my HHKB:
Offline Sniping
« Reply #272 on: Sun, 21 July 2013, 14:34:45 »
Dood, do you even thick ABS doubleshot/tripleshot?
muahahahahaha
The caps came off a rubber dome, like father like son.
http://geekhack.org/index.php?topic=46009.0
« Last Edit: Sun, 21 July 2013, 14:57:10 by Sniping »
Offline AKIMbO
  • HHKBro
« Reply #273 on: Sun, 21 July 2013, 14:49:07 »
muahahahahaha
No way that works....you trolling us bro?
| KBD75 (box reds)
Offline Sniping
« Reply #274 on: Sun, 21 July 2013, 14:56:40 »
I'll film a typing video later this afternoon :D
« Reply #275 on: Sun, 21 July 2013, 14:57:49 »
Wow it actually worked? Damn. Also wtf is your spacebar
Offline Xenderwind
« Reply #276 on: Sun, 21 July 2013, 15:00:20 »
I would assume tape to cover some text/branding on the spacebar?
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline AKIMbO
  • HHKBro
« Reply #277 on: Sun, 21 July 2013, 15:01:56 »
Awesome!  Please try and capture if there is any key wobble....compare those new keys with the stock 660C keys.
| KBD75 (box reds)
« Reply #278 on: Sun, 21 July 2013, 15:02:25 »
Tape is there to prevent the spacebar from shining I bet. I've seen that before.
Offline yearn4
  • formerly known as 4en
« Reply #279 on: Sun, 21 July 2013, 15:03:53 »
muahahahahaha
i'll bet people would pay more for those than a cc!
Offline Michael
  • Formerly Bro Caps
« Reply #280 on: Sun, 21 July 2013, 15:05:51 »
muahahahahaha
The thing I like most about topre boards, is PBT. Can't even begin to consider typing on ABS knowing it's going to get shiny. My OCD just refuses to allow for it.
Offline Sniping
« Reply #281 on: Sun, 21 July 2013, 16:59:07 »
Be prepared for awkward ending as well. Sorry for quiet voice, I had to keep it down.
Here's the video
Again, the difference is mostly in feel, these caps sound different than stock, but only very slightly different. It's amazing how crisp these are though, hard to tell that these are 45g, they definitely feel a lot heavier.
So I kinda did a bad job explaining the repeating key at the end. It's caused by the different profile on these caps combined with the inconsistencies that I was talking about that made the "," key sit lower than all the other keys, and so if you pressed it slowly you would get a repeating key. If you press it again normally, the repetition will stop. But I'm just going to say that these keys feel quite different because of extra stiffness. As much as I would like to type on these all day, I also really want to get an Ergo Clear ErgoDox so I'm probably going to auction these off in FS meaning these caps are going to have to come off to keep them in like-new condition.
« Last Edit: Sun, 21 July 2013, 17:17:51 by Sniping »
Offline eth0s
  • Peace & Love
« Reply #282 on: Sun, 21 July 2013, 19:51:55 »
Here's my Leo FC660C:
Offline eth0s
  • Peace & Love
« Reply #283 on: Sun, 21 July 2013, 19:53:22 »
And here is a RealForce combo:
« Reply #284 on: Sun, 21 July 2013, 20:18:52 »
Nice rainbow clacky goodness!
Offline eth0s
  • Peace & Love
« Reply #285 on: Sun, 21 July 2013, 20:36:54 »
Yes!  There's also a black and white pair, and the beer one too.
« Reply #286 on: Sun, 21 July 2013, 21:02:49 »
I saw those too.
Now you need CC backspace to finish the top row.
Offline morpheus
« Reply #287 on: Mon, 22 July 2013, 00:42:11 »
muahahahahaha
How the heck did you do this?
Can you please post the pics of you making this?
« Reply #288 on: Mon, 22 July 2013, 00:46:42 »
muahahahahaha
All he did was to pull vaguely Topre-compatible keycaps off an old typewriter and put them on his FC660C ;)
Offline yasuo
  • spanengan puyeng newbie
« Reply #289 on: Mon, 22 July 2013, 04:04:02 »
I'm waiting for someone to post uTrton :D
Logitech MK220 Colemak DH
Offline nky0210
« Reply #290 on: Mon, 22 July 2013, 05:27:14 »
WOW, your CC collection is great ;)
|| Filco MJ2 Brown 87 || Realforce 87UW ||
Offline Sniping
« Reply #291 on: Mon, 22 July 2013, 08:54:54 »
muahahahahaha
It's funny because I thought the caps needed modification and I ended up breaking two keys because of that but they fit right on without any mods.
Offline AuRinBei
« Reply #292 on: Mon, 22 July 2013, 11:34:58 »
muahahahahaha
Why would you not just throw them on first? Did you not have the board at the time?
87u || Poker 2
Offline esoomenona
  • Gnillort?
« Reply #293 on: Mon, 22 July 2013, 11:41:16 »
And Topre laughs in your face everyday with ABS spacebars, the key that shines the most/fastest.
Offline guilleguillaume
« Reply #294 on: Mon, 22 July 2013, 11:44:00 »
Not in JIS layout :D
Offline phetto
  • HHKB JP
« Reply #295 on: Thu, 25 July 2013, 03:16:31 »
JIS layout ftw.
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #296 on: Thu, 25 July 2013, 04:44:21 »
Eth0s, that is an incredible looking 660c o.o
Having a bad day?
Offline AKIMbO
  • HHKBro
« Reply #297 on: Thu, 25 July 2013, 17:14:24 »
All my topres in one pic (sans a 23u).
| KBD75 (box reds)
Offline Michael
  • Formerly Bro Caps
« Reply #298 on: Thu, 25 July 2013, 17:24:43 »
dat candycorn skull
Offline MJ45
  • HHKB Pro
« Reply #299 on: Thu, 25 July 2013, 21:11:29 »
A most excellent selection you have!
