Author Topic: Post your Topre Keyboard  (Read 4666023 times)
0 Members and 6 Guests are viewing this topic.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
Re: Post your Topre Keyboard
« Reply #6050 on: Thu, 20 August 2015, 13:51:17 »
anyone here try SA profile caps on a topre keyboard? I hear it's godly
I have not but people rave about SA on the Novatouch. I'm liking forward to getting some topre to MX sliders to try it out.
Offline Ngt
« Reply #6051 on: Thu, 20 August 2015, 14:21:13 »
I'm writing on it and it feels definitely really nice! Love it so far and it has been for a few months already.
Offline Kudos
  • Godspeed
  • GAF
« Reply #6052 on: Thu, 20 August 2015, 14:48:49 »
108897-0
Offline joey
« Reply #6053 on: Thu, 20 August 2015, 14:57:17 »
That's teally nice!  :))
Offline Ngt
« Reply #6054 on: Thu, 20 August 2015, 15:01:52 »
« Reply #6055 on: Thu, 20 August 2015, 15:27:19 »
Offline Kudos
  • Godspeed
  • GAF
« Reply #6056 on: Thu, 20 August 2015, 15:27:54 »
Offline Kudos
  • Godspeed
  • GAF
« Reply #6057 on: Thu, 20 August 2015, 15:29:13 »
That's sick bro! Did you make all of those ?!
Yessir!
I still owe you a kit anyways. I've listed the colors I will be releasing. If any of those sound good, I can prioritize a sample set for you!
https://geekhack.org/index.php?topic=70388.0
Offline Sed8op8
  • Keyboard Padawan
« Reply #6058 on: Thu, 20 August 2015, 15:37:33 »
« Reply #6059 on: Thu, 20 August 2015, 15:38:59 »
Yessir!
Omg, you're the best bro! That mod set looks awesome. Your walls are way thicker and look awesome too!
Offline Kudos
  • Godspeed
  • GAF
« Reply #6060 on: Thu, 20 August 2015, 16:07:52 »
Yessir!
Who doesn't want a nice girthy thock?
« Reply #6061 on: Thu, 20 August 2015, 22:25:13 »
I like SA on the Novatouch just fine, but I still prefer GMK.  :thumb:
« Reply #6062 on: Thu, 20 August 2015, 22:28:52 »
purposely ruin topre with a **** profile?
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #6063 on: Thu, 20 August 2015, 23:11:28 »
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline Ngt
« Reply #6064 on: Fri, 21 August 2015, 01:49:04 »
Looking forward to try GMK on it too! Does cherry profile go fine on the Novatouch or does it need the oring they provided?
« Reply #6065 on: Fri, 21 August 2015, 07:36:55 »
I didn't have any issues using it normally, but then again I've never felt the need for orings for anything so I might be the wrong person to ask about it.  :3
Offline azhdar
  • Praise the AZERTY god
« Reply #6066 on: Fri, 21 August 2015, 07:38:08 »
Aren't the vortex you used for a while of cherry profile? I'm not quite sure.
Azerty Propagandiste
Offline Ngt
« Reply #6067 on: Fri, 21 August 2015, 07:39:08 »
IIRC the o-rings provided with the Novatouch are not used like all the other o-rings we often see. I think their function is to raise the key cap.
Offline Ngt
« Reply #6068 on: Fri, 21 August 2015, 07:40:39 »
It was the Leopold PBT set from widebasket. I don't remember if they are OEM or cherry profile.
Offline azhdar
« Reply #6069 on: Fri, 21 August 2015, 07:43:06 »
by the look of this thread : https://geekhack.org/index.php?topic=59780.0
they aren't exactly cherry but close.
Offline Blackhawk
« Reply #6070 on: Fri, 21 August 2015, 07:46:52 »
I have a novatouch with GMK and they do indeed hit the slider housing (most notably on the homerow and modifiers). O-rings solves the problem. :)
Offline Ngt
« Reply #6071 on: Fri, 21 August 2015, 08:30:27 »
Alright thanks for clarifying.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #6072 on: Fri, 21 August 2015, 12:35:16 »
Would any of you with a novatouch & gmk mind posting a video of the key-presses/finger-banging please? I'm very curious, gracias.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #6073 on: Fri, 21 August 2015, 12:37:23 »
If no one else does, I will once my Hyperfuse set arrives.
« Reply #6074 on: Fri, 21 August 2015, 13:06:09 »
What part of it would you like to see? I can do it soon.
Offline Blackhawk
« Reply #6075 on: Fri, 21 August 2015, 13:09:00 »
Here you go.
https://youtu.be/xVUldarYmF0
There is an o-ring installed on the control key.
The board is silenced using the ironed landing pads mod. It is possible that the small reduction in travel distance is to blame.
Offline digi
  • elite af tbh
« Reply #6076 on: Fri, 21 August 2015, 13:09:19 »
I'd like to see how high the GMK caps sit on the stems with or without the o-rings, sound of the thock would be cool too.
I was contemplating getting a novatouch but I might just wait for those JT/CtrlAlt sliders and put them on my RF.
Offline digi
  • elite af tbh
« Reply #6077 on: Fri, 21 August 2015, 13:15:30 »
Here you go.
thanks blackhawk, when you say that the gmk caps hit the slider housing what is it about the gmk caps that would be different than any regular abs cap?
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #6078 on: Fri, 21 August 2015, 13:24:48 »
Here you go.
Thickness maybe.
Epzy I think installed novatouch sliders on his HHKB and has dolch on his, and he never said anything about o-rings..
I guess I'll see how it turns out once I get my  JT sliders.
Offline digi
  • elite af tbh
« Reply #6079 on: Fri, 21 August 2015, 13:28:06 »
Here you go.
Thickness maybe.
Are there pictures of the JT sliders anywhere? Was the only way to get them to get a set of JT caps from Bunny's GB?
Offline Blackhawk
« Reply #6080 on: Fri, 21 August 2015, 13:28:23 »
Here you go.
I think it is mainly due to the low profile. As far as i can tell it is the protruding lines (not sure what they are called) on the underside of the cap that is hitting the top part of the housing.
I tried illustrating it with some pictures :p
Offline digi
  • elite af tbh
« Reply #6081 on: Fri, 21 August 2015, 13:29:10 »
Here you go.
that makes sense, thanks for the pics!
« Reply #6082 on: Sat, 22 August 2015, 04:17:00 »
Pretty vanilla boards for now but you guys have amazing ideas :D
PS Just LOOOVVVVEEEE the green goblin one ;)
Every artist needs a canvas - and you have two canvassess (canvii? canvessi?) :)
Offline Kudos
  • Godspeed
  • GAF
« Reply #6083 on: Sun, 23 August 2015, 01:32:06 »
Decided to play a little dress up for an upcoming sale:
109205-0
109207-1
109209-2
109211-3
109213-4
109215-5
Offline Happylomo
« Reply #6084 on: Sun, 23 August 2015, 02:24:17 »
Love that "watermelon" modifiers, man! :D
Offline Sed8op8
  • Keyboard Padawan
« Reply #6085 on: Sun, 23 August 2015, 05:02:22 »
« Reply #6086 on: Sun, 23 August 2015, 07:13:33 »
Oh man those dark purple fn's are perfect! 👌
Offline Ngt
« Reply #6087 on: Sun, 23 August 2015, 09:08:52 »
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #6088 on: Sun, 23 August 2015, 09:39:16 »
Waiting on Martins Red and black functions to replace the bubble window caps. other then that she is perfect!
109241-0
« Reply #6089 on: Sun, 23 August 2015, 10:56:53 »
Nice case man! Slick!
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #6090 on: Sun, 23 August 2015, 11:11:59 »
That is going to look so sick with the two tone fns :thumb:
« Reply #6091 on: Sun, 23 August 2015, 16:36:27 »
artsy fartsy
Frankly, I think it would look cool with just the yellow/light blue colours going on. Still neat though mister :P
nooo.. needs more colors!
p1 purple and pink are always great together. :)
here are some leftover pics i took awhile ago that i don't think i posted yet.
dark
light
MMMMMMMMMMMMMM THAT MILK PURPLEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
Offline sth
  • 2 girls 1 cuprubber
« Reply #6092 on: Mon, 24 August 2015, 07:51:46 »
yo how bout hookin me up with some betas since i'm not usually awake at 3:45 AM monday morning :llama:
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #6093 on: Mon, 24 August 2015, 08:20:10 »
Leopold keycaps are Step Sculpture 2 profile ;)
« Last Edit: Tue, 25 August 2015, 01:38:10 by _PixelNinja »
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #6094 on: Mon, 24 August 2015, 17:59:13 »
CMY keys on my HHKB
« Last Edit: Mon, 24 August 2015, 18:43:10 by nickheller »
Offline Ngt
« Reply #6095 on: Tue, 25 August 2015, 02:54:43 »
thanks.
CMY keys on my HHKB
Nice board!  :thumb:
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #6096 on: Wed, 26 August 2015, 09:49:27 »
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #6097 on: Wed, 26 August 2015, 09:58:34 »
Offline Sed8op8
  • Keyboard Padawan
« Reply #6099 on: Wed, 26 August 2015, 11:04:14 »
jesus Christ that looks good. With all the different colors you wouldn't think it would work but it does! Definite win  :thumb:
