Author Topic: Post your Topre Keyboard  (Read 4666375 times)
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: Post your Topre Keyboard
« Reply #6150 on: Wed, 02 September 2015, 22:37:59 »
ignore the cherry peasantry ****
When you gonna upgrade that thing to a RF?? You probably have a Mac too...ugh
« Reply #6151 on: Wed, 02 September 2015, 22:41:36 »
SOON DIGI. SOON. IM GONNA PLACE MY MONEY ON RAIDERS WINNING THE SUPERBOWL AND BE RICH.
haha jk ill be living in the dumpster ;_;
Offline yomammary
« Reply #6152 on: Thu, 03 September 2015, 07:06:31 »
Restored Realforce 86u
Yea very nice, not sure why we have 87U's...86U is perfect.
When is the last time you used the right-click mouse button keyboard key? :))
What's the difference between the 86U and 87U?
86u = 86 keys
87u = 87 keys
Is the only difference, the bigger spacebar? I like it.
86u has 1.5x ctrl 1x super 1.5x alt 7x space 1.5x alt 1x super 1.5x ctrl, 87u has 1.5x ctrl 1x super 1.5x alt 6x space 1.5x alt 1x super 1x menu 1.5x ctrl
Ah I see.
RF 87u 55g | Leeku 1800
Offline keshley
    • Blog n stuff
« Reply #6153 on: Thu, 03 September 2015, 07:27:17 »
I know I'm probably the outlier here but I use the Menu key literally all the time. Menu key + r is engrained in my brain for opening up the file properties window.
Is that the same as alt+enter? I remember when the Menu and Windows keys showed up on keyboards, and thinking they were dumb at the time, so a lot of the older shortcuts are ingrained for me... but some of the 'new' ones are nicer/easier.
I've used the menu key occasionally, but I don't miss not having it on my current setup. If I wanted another TKL setup, the 86U certainly is attractive.
HHKB Pro 2       Pok3r
Offline Shinryuu
« Reply #6154 on: Fri, 04 September 2015, 02:37:12 »
Guess what I did yesterday ;)
(ノ◕ヮ◕)ノ*:・゚✧
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #6155 on: Fri, 04 September 2015, 07:29:13 »
I really wish PFU would make the dark grey a true black like it appears to be in your photo. Sigh.
Offline keshley
    • Blog n stuff
« Reply #6156 on: Fri, 04 September 2015, 07:43:56 »
Could always disassemble and dye :)
Trick is to find a black dye that doesn't look blue/purple. The crowd here, as well as the 3d printing crowd seem to like idye poly the best right now. Last time I dyed something with Rit black, it had the purplish hue to it. Going to try idye poly black on some of the 3d printed stuff in the near future. Not going to dye my HHKB though as I like the charcoal color.
HHKB Pro 2       Pok3r
Offline sth
  • 2 girls 1 cuprubber
« Reply #6157 on: Fri, 04 September 2015, 07:44:37 »
starting with such a dark case already, dying further black might work out without getting too blue.
Offline Ngt
« Reply #6158 on: Fri, 04 September 2015, 07:49:10 »
Really nice color combination. Nice choice.
Offline MJ45
  • HHKB Pro
« Reply #6159 on: Fri, 04 September 2015, 10:26:05 »
It also could ruin your HHKB, the case is ABS plastic that is not as dye friendly as PBT is.
Offline sth
« Reply #6160 on: Fri, 04 September 2015, 10:59:15 »
well would it be ruined or just ugly?
« Reply #6161 on: Fri, 04 September 2015, 11:00:24 »
What's the difference?
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #6162 on: Fri, 04 September 2015, 11:02:30 »
It could be ruined if you are not very careful, as warping is much more likely with ABS when dying.
I would avoid dying ABS.
Plus dye reacts differently to ABS that it does PBT and could have affects that you didn't want or expect.
Even more risky with a case that you can't replace.
« Last Edit: Fri, 04 September 2015, 11:04:16 by Air tree »
Offline sth
« Reply #6163 on: Fri, 04 September 2015, 11:04:34 »
 gotcha, that's what I was getting at, whether it would warp the case or just look bad due to the dye not
'taking'.
Offline keshley
    • Blog n stuff
« Reply #6164 on: Fri, 04 September 2015, 11:05:49 »
Which is why you always do a test dying.
I've dyed plenty of plastics with a lower melting temperature than ABS. As has anybody who has done any 3d printing. Its not rocket science guys :P
Just have to find the right combo.
HHKB Pro 2       Pok3r
Offline keshley
    • Blog n stuff
« Reply #6165 on: Fri, 04 September 2015, 11:07:03 »
For the record, ABS is indeed on of the more difficult plastics to dye, but it is dye-able.
HHKB Pro 2       Pok3r
Offline MJ45
  • HHKB Pro
« Reply #6166 on: Fri, 04 September 2015, 11:16:49 »
Have you seen any posts about failed ABS keycap dyeing? ABS cant take heat like PBT and can be melted or warped- deformed in the dyeing process. Just like you don't see ABS dye-sub keycaps.
@ keshley when you dye up a HHKB make sure you post some pics.
« Last Edit: Fri, 04 September 2015, 11:24:35 by MJ45 »
Offline Air tree
« Reply #6167 on: Fri, 04 September 2015, 11:19:45 »
It is of course, I just feel one is taking a big risk dying a case that a replacement can't be got.  :)
Offline sth
« Reply #6168 on: Fri, 04 September 2015, 15:57:39 »
what about dye options that don't include high heat?
i dont know what the hell i'm talking about here
Offline keshley
    • Blog n stuff
« Reply #6169 on: Fri, 04 September 2015, 16:45:19 »
I believe they call that 'paint'  :p
HHKB Pro 2       Pok3r
Offline septamber
« Reply #6170 on: Fri, 04 September 2015, 21:09:50 »
Where are the 23u's at?
« Last Edit: Sun, 06 September 2015, 00:30:08 by septamber »
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #6171 on: Sat, 05 September 2015, 01:46:28 »
I'm not sure Vinyl Dye would work on the HHKB's case...
Offline Shinryuu
« Reply #6172 on: Sat, 05 September 2015, 04:10:09 »
Mhh, I'm fine with this dark gray thing. It seems my photo makes it to look darker what it should be and I haven't dyed it or anything. Guess there's a way to dye it somehow but you'll have to be careful because you're dealing with ABS.
(ノ◕ヮ◕)ノ*:・゚✧
« Reply #6173 on: Sat, 05 September 2015, 22:19:57 »
Nice 23UB man! Just installed my PEXON cable! Love it.  :cool:
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #6174 on: Sun, 06 September 2015, 03:09:17 »
My peeve with the dark grey model is that the blue tint makes it look like a old case bleached from UV exposure. But that's just me; I'm picky like that. Otherwise, yeah — more often than not, in photos, the contrast makes the case look darker than it really is.
Offline invisuu
« Reply #6175 on: Mon, 07 September 2015, 01:47:46 »
Ooooh so purdy!
Offline Hypersphere
« Reply #6176 on: Mon, 07 September 2015, 09:58:27 »
Here's my RF87UB55 testing out some keycap combinations:
110438-0
Offline Ngt
« Reply #6177 on: Mon, 07 September 2015, 13:25:26 »
Interesting color match. I like it.
Offline keshley
    • Blog n stuff
« Reply #6178 on: Mon, 07 September 2015, 15:06:37 »
That's pretty nice. I wouldn't have attempted to put those colors together, but they go nicely.
HHKB Pro 2       Pok3r
Offline Sed8op8
  • Keyboard Padawan
« Reply #6179 on: Mon, 07 September 2015, 22:36:49 »
very nice 8)
Offline Kinaesthetic
« Reply #6180 on: Wed, 09 September 2015, 22:39:06 »
I have a random question for y'all, and I dunno if there is any other better place to post it than here.
Does anyone know if the blank/printed HHKB keysets share the same profile as the Realforce keysets? I need a black keyset for the alphas on my RF, and was wondering if these keysets were compatible with the Realforce.
Offline btctopre
« Reply #6181 on: Wed, 09 September 2015, 22:41:45 »
same profile, different font though.
Offline koalapear
  • Actually hates koalas.
« Reply #6182 on: Wed, 09 September 2015, 22:50:53 »
Realforce 87U 55g
with red Reaforce Mods and Pexon cable
HHKB Pro 2
with red Realforce Alphas, Hasu's BT controller, and lubed and silenced using Hypersphere's silencing rings
'91 Model M SSK | NerD 60 (MX Greens) | Realforce 87U 55g | Winkeyless B.87 (MX Greens) | Monarch Matias Custom | HHKB | Duck Octagon (67g Zealios)
« Reply #6183 on: Thu, 10 September 2015, 05:31:45 »
Realforce 87U 55g
HHKB Pro 2
Excellent use of the red set across two keyboards!
Offline yomammary
« Reply #6184 on: Thu, 10 September 2015, 07:18:07 »
That realforce though  :eek:
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #6185 on: Thu, 10 September 2015, 19:05:34 »
« Reply #6186 on: Thu, 10 September 2015, 19:10:14 »
ruined by wrapping alphas
Offline strict
  • TKL Zealot
« Reply #6187 on: Thu, 10 September 2015, 19:15:33 »
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #6188 on: Thu, 10 September 2015, 19:22:21 »
Offline ekw808
  • Ekw
« Reply #6189 on: Thu, 10 September 2015, 20:21:28 »
Realforce 87U 55g
HHKB Pro 2
The red in the HHKB almost made it look like the HHKB HP caps. Nice RF cccombo!
[One Keyboard at a time]
Offline sundin
« Reply #6190 on: Fri, 11 September 2015, 13:48:50 »
My HHKB with the new PBT spacebar  :)
Offline Air tree
« Reply #6191 on: Fri, 11 September 2015, 14:10:45 »
Damn that looks nice.
What clacks are those? I don't think I have seen that colour.   :eek:
Offline sundin
« Reply #6193 on: Fri, 11 September 2015, 14:57:29 »
http://i5.walmartimages.com/dfw/dce07b8c-37b5/k2-_ad0e30e0-2377-43dd-b80a-2689683dd906.v1.jpg
Love it, Xowie did something similar. I actually want to remove the silver on my trophy silver because it looks like it'd be a cool color.
Offline keshley
    • Blog n stuff
« Reply #6194 on: Sat, 12 September 2015, 08:08:30 »
That's why I have one of the white PBT spacebars coming too. Going to do a whole keyset and didn't want the hassle of matching the ABS to the PBT.
I've convinced the GF that she needs a topre board... and wow the full size 55g boards are hard to find. So we're talking about getting a 87UB and a 23UB.
I showed her some of the boards in this thread, think that has helped tipped the decision  :D
HHKB Pro 2       Pok3r
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #6195 on: Sat, 12 September 2015, 08:19:29 »
Offline btctopre
« Reply #6196 on: Sat, 12 September 2015, 08:55:13 »
Offline deci
« Reply #6197 on: Wed, 16 September 2015, 06:53:20 »
Realforce 87U 55g
HHKB Pro 2
Ohhh very nice.
I like these!  :thumb:
Offline sth
« Reply #6198 on: Wed, 16 September 2015, 07:09:33 »
HHKB Pro 2
hey all right
Offline saturnotaku
« Reply #6199 on: Wed, 16 September 2015, 12:31:20 »
10th Anniversary RF87U 55g with XX7 artisan cap. The Miami color scheme complements the board better than I would have expected.
« Last Edit: Thu, 17 September 2015, 20:31:20 by saturnotaku »
