Author Topic: Post your Topre Keyboard  (Read 4682868 times)
0 Members and 7 Guests are viewing this topic.
Offline bocahgundul
  • a seal
Re: Post your Topre Keyboard
« Reply #7250 on: Thu, 28 January 2016, 17:39:42 »
Nice hhkb everyone!
Offline atlas3686
  • HHKB Elite
« Reply #7251 on: Fri, 29 January 2016, 10:00:10 »
I've always wanted a miami set for topre :)
Oooo ~ that's a super unique blend of keycaps and colors!
I like it <3
You always be surprisin' me, baby ~
Haha thanks Vesper, colours are a little off in that photo though. I will do better next time :)
Offline livingspeedbump
    • KeyChatter
« Reply #7252 on: Fri, 29 January 2016, 18:50:40 »
In prep for having HiPro caps again, and because I needed to swap in my purple sliders to my 87u 55g I went ahead and figured out a way to fix the issue with the pesky slider in the bottom left CTRL to make it compatible with HiPro and 104u caps. The guide is up on KeyChatter  :thumb:
<- My Collection (so far)
Offline btctopre
« Reply #7253 on: Fri, 29 January 2016, 18:55:33 »
If you shave the edge of the housing down that's closest to the LED spot, you don't need to desolder the LED. I forgot the exact spot to shave from, but I'm sure it's mentioned somewhere in my post history if someone wants to look for it.
Still hoping for a solution that doesn't involve cutting the plate. Tried finding one a few months back by cutting a full-size housing, but didn't have any luck.
edit- corrected myself, it was the slider housing- not the slider.
edit2- old pic i found (shaky hands = non-precision work huehue)-
« Last Edit: Fri, 29 January 2016, 19:00:08 by btctopre »
    • KeyChatter
« Reply #7254 on: Fri, 29 January 2016, 19:10:55 »
Cutting the plate seemed like the best option for me as the housing still clicks in place both ways, which is nice. That a good tip though on the LED
Offline keshley
    • Blog n stuff
« Reply #7255 on: Sat, 30 January 2016, 09:08:44 »
Or you could use a 3d printed slider that has the correct orientation on the nubs, like I am...
https://www.shapeways.com/product/6E53PURMC/keycap-slider-90-deg-modded?optionId=58766073&li=ostatus
HHKB Pro 2       Pok3r
Offline btctopre
« Reply #7256 on: Sat, 30 January 2016, 09:30:58 »
+rep, will order and try. thank you!
Offline keshley
    • Blog n stuff
« Reply #7257 on: Sat, 30 January 2016, 09:55:10 »
I just installed mine yesterday. They're a bit scratchy (injection molding vs 3d printed), but reversible mod makes it a plus IMO. I lubed the slider to make it a bit nicer. I don't use that key though, so for me its just to get it mounted.
HHKB Pro 2       Pok3r
Offline btctopre
« Reply #7258 on: Sat, 30 January 2016, 10:01:35 »
roger that, i'll be sure to lube. and yeah this would be going on an emergency only keyboard for me, so not too concerned about functionality. just would like to be able to put the mods of a 104ub-dk on a TKL without cutting into the plate of this one.
ordered one of the black ones, two week delivery eta, we'll see how it goes  :thumb:
Offline keshley
    • Blog n stuff
« Reply #7259 on: Sat, 30 January 2016, 10:23:25 »
Potato of current setup:
Probably stay like this until I can find some KeyKollectiv mods... Or I break down and buy a blank white set to dye the mods.
HHKB Pro 2       Pok3r
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #7260 on: Sat, 30 January 2016, 15:13:46 »
Do the Cherry caps feel noticeably different on Topre compared to the stocks?
« Reply #7261 on: Sat, 30 January 2016, 16:08:05 »
yeah, it feels like you're angering the topre gods with this horrible blasphemy. cherry on topre. SMFH.
Offline septamber
« Reply #7262 on: Sat, 30 January 2016, 16:11:26 »
Pink 2.0
Offline bocahgundul
  • a seal
« Reply #7263 on: Sat, 30 January 2016, 17:13:17 »
Nice modifiers but change that alpha dude  :p
Offline dan002
« Reply #7264 on: Sat, 30 January 2016, 17:28:36 »
Probably depends on the type of plastic the Cherry MX caps are. Most are PBT right and HHKB uses ABS?
Peace, love and keyboards.
Offline keshley
    • Blog n stuff
« Reply #7265 on: Sat, 30 January 2016, 17:32:58 »
Topre keycaps are PBT, with the spacebar being the exception; its ABS.
These are ABS mods, obviously, and POM blanks for the rest. POM is my favorite, and I typically prefer ABS over PBT.
HHKB Pro 2       Pok3r
Offline xondat
  • i'm not a star
« Reply #7266 on: Sat, 30 January 2016, 18:32:27 »
Pink 2.0
 :-* Love a bit of pink
Offline mason
  • have fun with her, ryan
« Reply #7267 on: Sat, 30 January 2016, 19:53:54 »
I had the same setup on my white HHKB  :)) and POM caps were my favorite on it
Offline Vittra
  • Airflow Optimizer
« Reply #7268 on: Wed, 03 February 2016, 08:50:21 »
Low light photo last night:
126852-0
I noticed an odd phenomenon using it briefly last night though that I'm not sure is inherent to silenced boards or not. Any key pressed hard enough has a sound that can perhaps be described as a ping, but almost feels slightly "sticky" as well... it seems to only occur when bottoming out with sufficient force. I haven't noticed this on my HHKB Pro 2 or RF23U, but neither is a fully an accurate comparison. I'll have to use it for more time to better describe it.
Loving it overall though. Weird to have a full-sized layout after using TKL for so many years  :p.
Filco MJ Linear R LE TKL
Offline ghostjuggernaut
« Reply #7269 on: Wed, 03 February 2016, 17:38:10 »
Offline t347
« Reply #7270 on: Wed, 03 February 2016, 19:04:34 »
Did you dye the modifiers?  That's one sexy hhkb
Realforce 87u 55g
« Reply #7271 on: Wed, 03 February 2016, 19:18:52 »
No, these are keykollectiv mods.
« Last Edit: Wed, 03 February 2016, 19:21:49 by ghostjuggernaut »
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #7272 on: Wed, 03 February 2016, 22:06:14 »
Blackout Reaper?
Great looking board though!
Offline byker
  • Literally Canada
« Reply #7273 on: Wed, 03 February 2016, 22:48:44 »
So I relubed my hhkb tonight, and had some fun making new colour schemes for my boards..
For some more pics, go here :) http://imgur.com/a/g2xIQ
« Reply #7274 on: Thu, 04 February 2016, 03:59:56 »
Offline Jokrik
« Reply #7275 on: Thu, 04 February 2016, 04:02:55 »
I don't topre
but I've to say your board is looking dope man... :)
Offline bocahgundul
  • a seal
« Reply #7276 on: Thu, 04 February 2016, 04:14:57 »
Damn that hhkb is beautiful!
Offline zennasyndroxx
  • It's good to be back!
« Reply #7277 on: Thu, 04 February 2016, 16:20:24 »
Now I need black mods modifiers, and repainting the case to black.
« Last Edit: Thu, 04 February 2016, 17:23:17 by zennasyndroxx »
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #7278 on: Thu, 04 February 2016, 16:38:37 »
fffffffffffuuuuuuuuuuuuuuuuuuuuu- that is a dope theme, dood T___T
Jelly of the Keykollectiv set and Blackout ~
I am seriously going to have consider dyeing me some Purple mods, man. That is so damn gooooooooooood T_T
Offline bocahgundul
  • a seal
« Reply #7279 on: Thu, 04 February 2016, 17:14:32 »
Now I need black mods, and repainting the case to black.
noo That case is perfect for that alpha  :p
« Reply #7280 on: Thu, 04 February 2016, 17:16:40 »
now that you mention it.. our moderation team DOES need a little diversity.
« Reply #7281 on: Thu, 04 February 2016, 17:26:33 »
Fixed lol.
BRB checking criterias of becoming a mod
Gonna try the alphas on another black hhkb and see if it matches well
Offline Fullcream
« Reply #7282 on: Thu, 04 February 2016, 17:41:04 »
Painted the case and broke the enter cap. Cool
Offline Sneaky Potato
  • Gunslinger
« Reply #7283 on: Thu, 04 February 2016, 17:44:28 »
Well played.
Offline bocahgundul
  • a seal
« Reply #7284 on: Thu, 04 February 2016, 17:47:51 »
noice
Offline btctopre
« Reply #7285 on: Thu, 04 February 2016, 18:21:34 »
I was wondering who else was going to pop up with one of the keyboards as it was pretty clear one of the other buyers was bidding through a proxy (based on the accounts feedback score). Grats!
How dirty was your your 5461? Mine was in a sad state, thankfully the keycaps cleaned up incredibly easy.
  • sleever supreme
  • greyhat co-leader
« Reply #7286 on: Fri, 05 February 2016, 00:49:08 »
Those look great, purple Topre is best :)
« Reply #7287 on: Fri, 05 February 2016, 01:16:51 »
Thank you :)
At that point, there was another topre board, the JDL board which I'm pretty interested as well but I got sniped in the end.
The board that I've got is pretty dirty as well and the keycaps is fairly easy to clean. The case is pretty yellow too
Offline deduction
  • unix layout zealot
« Reply #7288 on: Fri, 05 February 2016, 01:27:39 »
I apologize for the iPhone potato quality/lighting but this is the only family photo of all three boards.  I swapped some keys around after this picture was taken.  They're all printed - next on my todo is to get some PBT blanks, PBT spacebars and mix in the Topre HKP blanks I have.
Offline sth
  • 2 girls 1 cuprubber
« Reply #7289 on: Fri, 05 February 2016, 02:29:16 »
Thank you :)
homey do NOT paint your case, yellowed hhkb is a workhorse not a blight. is that a pro-1 or pro-2?
those caps look cool!
Offline Tinpham3000
  • I'm not a bad guy like nguyenkimtam
« Reply #7290 on: Fri, 05 February 2016, 02:39:40 »
Hi-Pro topre
Keyboards:
Kmac LE Titan, Kmac 1.2 Sivler, Kmac Pad Silver, Black - Red - Black Cheat, Duck Octagon Red, OTD 360c, Duck Eagle Blue Grey, Duck Poker Silver, GHPad Alu Blue, Orion v2
Looking for Kmac 2, Duck Poker Titanium, 356mini, 356.2, orion v1, LZ MX SE...
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #7291 on: Fri, 05 February 2016, 02:49:30 »
Hi-Pro topre
man I love the look of that board
« Reply #7292 on: Fri, 05 February 2016, 02:56:00 »
Thank you :)
that's a pro 2. bought it at a really good price but with this case lol.
If the alphas matches well with black case + black modifiers then i might just end up spraying the case ._.
Offline sth
« Reply #7293 on: Fri, 05 February 2016, 02:57:38 »
Thank you :)
pls no
if i had a black hhkb i would trade you for that one but alas
Offline xondat
  • i'm not a star
« Reply #7294 on: Fri, 05 February 2016, 06:05:36 »
Those BBv2's  :-[
Offline atlas3686
  • HHKB Elite
« Reply #7295 on: Fri, 05 February 2016, 06:12:06 »
Thank you :)
Dustin posted a process to get a yellowed case back to a nice white, looks like it worked really well, you might want to google that.
Offline sth
« Reply #7296 on: Fri, 05 February 2016, 06:15:42 »
Thank you :)
retro blight > retro brite
respect the yellowing
Offline Lansky
  • Realest motherthocker
« Reply #7297 on: Fri, 05 February 2016, 06:40:30 »
One of my only critiques of the Realforce boards is that they don't have rubber pads on the top part of the case, but only have those plastic bumps. It's probably not an issue for most people, but because my desk tends to dent/mark up fairly easily those little plastic bumps always bothered me. So I found one of my old laptops that had rubber feet tall enough to raise the board enough to clear those plastic bumps and stuck them on the board. It feels a lot better knowing that I'm not scratching or denting my desk now. And it also added some extra grip which is always nice.  :thumb:  :p
« Reply #7298 on: Fri, 05 February 2016, 06:54:45 »
Thank you :)
pls no
you can always get a black one and trade them with me :p
Offline sth
« Reply #7299 on: Fri, 05 February 2016, 06:55:48 »
Thank you :)
pls no
im seriously considering it / trying to get people i know with black cases to trade you just to keep that yellow beauty kicking
