Author Topic: Post your Topre Keyboard  (Read 4530859 times)
Offline mteinum
Re: Post your Topre Keyboard
« Reply #8000 on: Tue, 17 May 2016, 14:31:19 »
Constitution day here in ISO land
Offline dgneo
  • Supervillain
« Reply #8001 on: Tue, 17 May 2016, 14:32:36 »
kk x Widdle Kitty
Yissssssssssssss looks so good!
Offline cookie
    • Deskthority
« Reply #8002 on: Tue, 17 May 2016, 15:03:36 »
Dark & dirty bronze mods.
You might be interested in this here: https://geekhack.org/index.php?topic=82095.msg2170824#msg2170824
I needed some way to restore the logo after I painted my jellowed HHKB Pro1 :)
Offline Hypersphere
« Reply #8003 on: Tue, 17 May 2016, 16:30:25 »
Looking for feedback from anyone who has silence a Realforce 55g board.
A Realforce 87U55 has rendered my 45g HHKB kind of mushy—enough for me to overlook my strong preference for a 60% form factor.
I don’t mean to sensationalize either camp with fanboyism—these are both great boards. I just find the 55g so much a better fit for me. I’m really a surprised to prefer one over the other so strongly, but the crispness of the heavier switch just feels right…not too heavy. But it has made the 45g switch seem light.
I guess there’s always the route of transplanting the stiffer domes to the smaller format, but I’m losing patience for the more fiddly aspects of modding, and the sheet of domes qualifies as fiddly for me.
At the same time, I have added Hypersphere’s silencing rings to my HHKB and found them a great improvement. But, other than the spacebar, the RealForce doesn’t seem too loud.
The 55g also seem to offer little quicker and more accurate typing for me. The difference is the confidence boost in knowing a key has been actuated from the additional tactility and the quicker spring back and return on the up stroke.
I’ve got the silencing rings on hand for the Realforce, but I am leery of compromising any of the responsive feel of the 55g board. Anyone completed the mod have feedback on any loss of crispness in the switches? I didn’t notice any change in feel when adding the   rings to the HHKB but then they weren’t this crisp to start with either.
I go back and forth on preferring 55g or 45g Topre. I have a HHKB Pro 2 modded with 55g domes, but I have finally decided that I prefer 45g in the HHKB Pro 2.
I have both a 55g and 45g RF87UB. I like both of them. At first, I thought I preferred the 55g, but I find it a bit too heavy for long typing sessions. In addition, Topre made a few subtle refinements on the all-45g "EK Edition" that might give it a slight edge for some people.
Any of these is especially great after installing Silencing Rings and lubing the stabilizers and switches. I also put foam rubber shock absorbers under the spacebar.
Offline btctopre
« Reply #8004 on: Tue, 17 May 2016, 21:06:54 »
hello
Offline nmur
  • ಠ_ಠ
« Reply #8005 on: Tue, 17 May 2016, 21:26:05 »
hello
awesome dude
do you have printed/blank RF sets? or just some particular keys?
Offline btctopre
« Reply #8006 on: Tue, 17 May 2016, 22:30:14 »
mostly just wasd and esc sets (have all ansi colors except for the bastard red-orange). i much prefer printed alphas in white/light gray, so just use the few caps to add a bit of color occasionally.
Offline nmur
  • ಠ_ಠ
« Reply #8007 on: Tue, 17 May 2016, 22:53:02 »
oh nice. must be slightly easier than hunting down full ansi sets haha
Offline WNovizar
« Reply #8008 on: Wed, 18 May 2016, 03:15:24 »
Hi all,
Untitled by Wendhy Novizar, on Flickr
Can I post novatouch and not get burned here? :))
I like mechanical keyboards
Offline losing_ctrl
« Reply #8009 on: Thu, 19 May 2016, 14:10:36 »
Tried my hand at dying some keycaps last night. They turned out much darker than I wanted (who knew iDye was so potent?), but it was a learning experience. Here shown on the iPad Pro to which it is usually connected. I use this keyboard in "sort of" ANSI format, so I purchased a set of ANSI HHKB keycaps to supplement the standard JIS-labelled keycaps, so that the labels better match the output. The result still needs some work, but it's a work in progress. Basically the dyed keys all work as labelled, while the Yen key and backslash key by the question mark don't do anything.
137503-0
And here it is with cable attached. Sorely tempted by the HHKB JP BT.
137506-1
« Last Edit: Thu, 19 May 2016, 15:21:37 by losing_ctrl »
Offline Tactile
« Reply #8010 on: Thu, 19 May 2016, 14:19:42 »
They might not have turned out as you wanted, but I love that shade of green. Great job!
REΛLFORCE
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #8011 on: Thu, 19 May 2016, 14:53:14 »
Tried my hand at dying some keycaps last night. They turned out much darker than I wanted (who knew iDye was so potent?), but it was a learning experience. Here shown on the iPad Pro to which it is usually connected. I use this keyboard in "sort of" ANSI format, so I purchased a set of ANSI HHKB keycaps to supplement the standard JIS-labelled keycaps, so that the labels better match the output. The result still needs some work, but it's a work in progress. Basically the dyed keys all work as labelled, while the Yen and backslash key by the question mark don't do anything.
Looks great with that notebook thing :)
Idye does work pretty fast tho :p
Offline losing_ctrl
« Reply #8012 on: Thu, 19 May 2016, 15:24:29 »
Thanks, I was going for light green, but got dark. I do like it though. It was fun, and I sort of want to keep experimenting. But since Topre keycaps aren't cheap or plentiful, that may not be practical.
Offline the_marsbar
« Reply #8013 on: Fri, 20 May 2016, 13:38:47 »
Got a couple of new Fns, this is one of them:
Offline jabronni
« Reply #8014 on: Fri, 20 May 2016, 13:58:35 »
Very nice. I want to add a touch of pink to mine.
Offline rurushu
« Reply #8015 on: Fri, 20 May 2016, 14:17:47 »
nowadays blank topre caps are as rare as unicorns, else their prices are beyond reach...  :'(
please Topre Corp., come back to making keysets  :(
Offline Moistgun
  • Slippery When Wet
« Reply #8016 on: Fri, 20 May 2016, 14:19:14 »
You want a blank topre cap? or a blank topre set?
« Reply #8017 on: Fri, 20 May 2016, 16:14:51 »
Offline raymogi
« Reply #8018 on: Fri, 20 May 2016, 18:36:53 »
Please feed my addiction.
  • sleever supreme
  • greyhat co-leader
« Reply #8019 on: Fri, 20 May 2016, 19:46:46 »
Everyone's getting BT :O
When you want CMYP but HHKB is life.
Offline ghostjuggernaut
« Reply #8020 on: Fri, 20 May 2016, 19:49:03 »
Those turned out amazing bro!
  • sleever supreme
  • greyhat co-leader
« Reply #8021 on: Fri, 20 May 2016, 19:59:23 »
Thanks ghost! :)
Here's a better shot of the purple too, auto WB made it kind of a plum color in those other 2 shots.
« Reply #8022 on: Fri, 20 May 2016, 20:00:20 »
Thanks ghost! :)
Making me jelly man. They look great.
Offline Capmerica
« Reply #8023 on: Fri, 20 May 2016, 20:27:48 »
Can you guys please share the tut on how to paint your caps? Thanks. They look amazing btw.
  • sleever supreme
  • greyhat co-leader
« Reply #8024 on: Fri, 20 May 2016, 20:46:13 »
Hey Capm, these are dyed.
I used idye poly, you should be able to find a tutorial or 2 with a quick google search ;)
Offline Moistgun
  • Slippery When Wet
« Reply #8025 on: Fri, 20 May 2016, 21:23:54 »
your dye job is killer.
I dont have the patience or bravery to get caps and dye needed to make something this nice, but you did inspire me.
Im making some moulds now and will cast some arrows at least!.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #8026 on: Fri, 20 May 2016, 23:36:15 »
Should have posted this old photo for Norway's Constitution Day.
Better late than never.  ;)
Offline Capmerica
« Reply #8027 on: Sat, 21 May 2016, 00:17:07 »
Damn I want a BBv2 in my life so bad. TT
Offline mteinum
« Reply #8028 on: Sat, 21 May 2016, 02:23:47 »
 :thumb:
Fresh from the mailbox.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #8029 on: Sat, 21 May 2016, 12:56:32 »
My new shiny :
Offline muon
« Reply #8030 on: Sat, 21 May 2016, 13:10:04 »
Phase 1 of my HHKB build complete!
btw - loving the equation for capacitance, very clever :P
« Last Edit: Sat, 21 May 2016, 13:14:14 by muon »
Offline rurushu
« Reply #8031 on: Sat, 21 May 2016, 13:16:35 »
nice mods, you dyed yourself? a matching toothy fugu  :thumb:
Offline muon
« Reply #8032 on: Sat, 21 May 2016, 13:24:12 »
Yep, mixture of Kelly Green and Turquoise - guess I just got really lucky with the color balance. It's not quite as even as I would've liked but I might touch that up later.
Offline henz
  • What?
« Reply #8033 on: Sat, 21 May 2016, 14:27:31 »
i call it the franken touch. Wanted to try out the skidata caps :)
Edit: nice post without the link :)
Offline byker
  • Literally Canada
« Reply #8034 on: Sat, 21 May 2016, 14:30:22 »
Love that switch.
Offline Moistgun
  • Slippery When Wet
« Reply #8035 on: Sat, 21 May 2016, 17:03:39 »
the casts turned out pretty good for a first attempt.
I only made one R2 mould not thinking, so it will be hard to cast a whole arrow set without being super precise with the dyes, and copying that when making the 2nd R2
here is the result
« Reply #8036 on: Sat, 21 May 2016, 17:07:42 »
here is the result
Lmk when you need my address
Offline Moistgun
  • Slippery When Wet
« Reply #8037 on: Sat, 21 May 2016, 17:39:51 »
here is the result
You want em?
« Reply #8038 on: Sat, 21 May 2016, 17:41:23 »
When you make some fn for sure
Offline Moistgun
  • Slippery When Wet
« Reply #8039 on: Sat, 21 May 2016, 17:45:38 »
this good?
forreal though. I can definitely do R4 and Fn keys, but unfortunately the esc cap would be OEM and not the same profile as HHKB. its a few millimeters taller.
Last of the night. im on nyquil so I gotta go to bed.
Made a wine flavor!
« Last Edit: Sat, 21 May 2016, 21:40:29 by Moistgun »
« Reply #8040 on: Sat, 21 May 2016, 18:52:40 »
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #8041 on: Sun, 22 May 2016, 14:10:43 »
It's a small detail I like very much too : )
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #8042 on: Sun, 22 May 2016, 16:30:21 »
Quick and dirty pics of my HHKB and OG Cherry Beige and GMK Red Alert
Offline Michael
  • Formerly Bro Caps
« Reply #8043 on: Sun, 22 May 2016, 17:10:10 »
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #8044 on: Sun, 22 May 2016, 17:52:18 »
Sorry if this has been asked before, but in your experience, do you feel any difference in terms of feel with the Novatouch plungers compared to the original ones on the HHKB?
Offline pexon
    • Pexon PCs
« Reply #8045 on: Sun, 22 May 2016, 18:53:12 »
Not really. I only did the mod a few days ago so i can't comment really. First impressions are they seem just as smooth and consistent as the stock ones. The shift and enter keys are a little iffy as they are only supported by the central mount. I did drill the hhkb so the keys will travel their full distance and that helped.
« Reply #8046 on: Sun, 22 May 2016, 18:55:25 »
Boo
This
Man
Offline pexon
    • Pexon PCs
« Reply #8047 on: Sun, 22 May 2016, 19:10:05 »
Wot i do rong?
« Reply #8048 on: Sun, 22 May 2016, 19:12:11 »
Cherry on topre is a cardinal sin ;-;
Offline aaron6301
  • Pixel Pusher
« Reply #8049 on: Sun, 22 May 2016, 19:14:23 »
Wot i do rong?
To some it's sacrilege to mod a HHKB with nova sliders and ABS/GMK keycaps.
I dig it though, looks great. I'd like to head your feedback after a few days of usage.
