Author Topic: Post your Topre Keyboard  (Read 4683013 times)
Offline muon
Re: Post your Topre Keyboard
« Reply #8050 on: Sun, 22 May 2016, 19:14:39 »
Not sure where the right place to ask this is - does anyone mind measuring the length of the slider housing on their HHKB? See image:
and the depth from the case to the top plate as well as the top of the switch housing to the top plate, if possible? See image:
I'd do it myself of course but I'm really lacking the equipment to do so at the moment... all I've got is a fat plastic ruler and whatever's in this Airbnb :blank:
« Last Edit: Sun, 22 May 2016, 19:16:34 by muon »
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #8051 on: Mon, 23 May 2016, 05:19:39 »
Not really. I only did the mod a few days ago so i can't comment really. First impressions are they seem just as smooth and consistent as the stock ones. The shift and enter keys are a little iffy as they are only supported by the central mount. I did drill the hhkb so the keys will travel their full distance and that helped.
Thanks.
I don't quite get the part about the stabilized keys though; aren't the lateral support stems helping with that?
Cherry on topre is a cardinal sin ;-;
What does it feel like having your Gods turned against you
Offline ghostjuggernaut
« Reply #8052 on: Mon, 23 May 2016, 06:00:08 »
Thanks.
You have to drill a whole so that the stabilized inserts in the keycaps have a place to travel. Otherwise they will catch on the outer housing of the switch. The novatouch stabilized housing already have these holes. So if you were to do the mod on a RF all you have to do is change the whole housing along with slider. Since the hhkb housings are molded into the case your only option is to drill a hole. You could remove the mounts on the keycap, but that would render the cap useless for MX in the future.
Edit: just reread your post. If this isn't what you were asking, sorry.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #8053 on: Mon, 23 May 2016, 06:16:50 »
Not exactly. I am aware of the differences between the Novatouch's stabilized plungers and Topre's classic stabilized plungers, and the necessity to drill holes in the housings of the stabilized keys on the HHKB in order to accommodate the former because of the construction of the keyboard. My question pertains to Pexon saying Shift and Enter are only supported by the central mount, when the plungers (from the Novatouch) for those keys would have lateral support stems to assist with this. So I was wondering if he modified something is this regard, or if the support stems were simply not very efficient here.
« Reply #8054 on: Mon, 23 May 2016, 07:14:56 »
I see. The Nova stabilizers actually don't have mounts for MX caps. The space-bar does, but none of the others do. They are short enough that the slider is able to support the cap, just like standard topre sliders.
Offline bocahgundul
  • a seal
« Reply #8055 on: Mon, 23 May 2016, 18:17:46 »
only got tater pic
sorry for xpost  ;D
Offline Jokrik
« Reply #8056 on: Mon, 23 May 2016, 19:32:46 »
only got tater pic
sorry for xpost  ;D
Welcome to mechanical world :D
anyway
HHKB-BT by Hanshen, on Flickr
Offline alienman82
« Reply #8057 on: Mon, 23 May 2016, 19:34:38 »
removed.
« Last Edit: Thu, 01 March 2018, 15:09:11 by alienman82 »
Offline fknraiden
« Reply #8058 on: Mon, 23 May 2016, 19:55:28 »
oh man, the time has come!
just got done domswapping this new baby to 55U.
Realforce 87USD 10th
Model# YF110S
« Reply #8059 on: Tue, 24 May 2016, 03:07:43 »
Offline dgneo
  • Supervillain
« Reply #8060 on: Tue, 24 May 2016, 07:44:37 »
Throwbacks errrrrrrrrrrrrrrrrrwhere
Offline RobotMalcolmX
  • hackerman
« Reply #8061 on: Tue, 24 May 2016, 07:52:25 »
Photato pic incoming!
« Reply #8062 on: Tue, 24 May 2016, 22:24:45 »
Offline Michael
  • Formerly Bro Caps
« Reply #8063 on: Tue, 24 May 2016, 22:29:54 »
I want the real demik back. what did you do with him?
Offline nmur
  • ಠ_ಠ
« Reply #8064 on: Tue, 24 May 2016, 22:30:49 »
« Reply #8065 on: Tue, 24 May 2016, 22:31:23 »
yuck, dude
got drunk off skittles vodka. this is the end result
Offline Michael
  • Formerly Bro Caps
« Reply #8066 on: Tue, 24 May 2016, 22:34:40 »
« Reply #8067 on: Tue, 24 May 2016, 22:39:36 »
i make you sad? i make ME sad :(
i need more fn/esc sets ;-;
Offline rm-rf
« Reply #8068 on: Tue, 24 May 2016, 22:56:03 »
Let the contest begin?
Offline beehatch
  • baehatch
« Reply #8069 on: Wed, 25 May 2016, 00:43:29 »
« Reply #8070 on: Wed, 25 May 2016, 00:48:49 »
Offline beehatch
  • baehatch
« Reply #8071 on: Wed, 25 May 2016, 00:58:47 »
Offline appleonama
  • Trollo en USA
« Reply #8072 on: Wed, 25 May 2016, 00:59:44 »
Offline beehatch
  • baehatch
« Reply #8074 on: Wed, 25 May 2016, 01:53:39 »
contest over
sth has more, you loose.
incorrect
the goal was to show off the esc/fn sets, then singles without using duplicates.
his board has duplicate caps on it
no "loose" for me, for now
Offline nmur
  • ಠ_ಠ
« Reply #8075 on: Wed, 25 May 2016, 02:01:27 »
posting a sensible hhkb
teal is a much lighter colour irl, office lighting sucks
Offline Moistgun
  • Slippery When Wet
« Reply #8076 on: Wed, 25 May 2016, 08:10:55 »
I make you one this week.  :thumb:
top cap #1 quality city
« Reply #8077 on: Wed, 25 May 2016, 09:14:27 »
Danke m8
« Reply #8078 on: Wed, 25 May 2016, 09:22:47 »
When you want CMYP but HHKB is life.
Holy **** that is H O T  :eek:
WTBWTBWTB
Offline edb5s
« Reply #8079 on: Wed, 25 May 2016, 09:32:51 »
contest over
What is that keycap on your ? key?
Offline Moistgun
  • Slippery When Wet
« Reply #8080 on: Wed, 25 May 2016, 11:52:05 »
contest over
I want to say it's an Eat_the_food blank.
« Last Edit: Wed, 25 May 2016, 12:29:56 by Moistgun »
Offline dgneo
  • Supervillain
« Reply #8081 on: Wed, 25 May 2016, 12:07:04 »
contest over
KWK blanks iirc
EDIT: I read that as Esc for some reason, ignore moi  :))
« Last Edit: Wed, 25 May 2016, 13:29:49 by dgneo »
Offline beehatch
  • baehatch
« Reply #8082 on: Wed, 25 May 2016, 12:51:23 »
contest over
It's a COZ FN blank from his recent sale
Offline Willyc277
« Reply #8083 on: Wed, 25 May 2016, 17:03:51 »
« Reply #8084 on: Wed, 25 May 2016, 17:05:20 »
That looks really good with the orange 👌
Offline Capmerica
« Reply #8085 on: Wed, 25 May 2016, 17:06:48 »
Where did u get those modifiers and what do they made off? Very nice looking keyboard.
Offline Willyc277
« Reply #8086 on: Wed, 25 May 2016, 17:23:20 »
They are from KeyKollectiv's latest sale!! Check them out: https://geekhack.org/index.php?topic=74757.0
Offline mteinum
« Reply #8087 on: Thu, 26 May 2016, 11:16:39 »
Got some black keycaps in the mail for my Pro2.
HHKB Stormtrooper ed. by Morten Teinum, on Flickr
« Reply #8088 on: Thu, 26 May 2016, 11:34:46 »
Hey, where's that helmet from? Kinda looks like the Bandai ones.
« Reply #8089 on: Thu, 26 May 2016, 11:36:56 »
It's from Star Wars.
Geez have you never seen Star Wars?
Offline beehatch
  • baehatch
« Reply #8090 on: Thu, 26 May 2016, 11:50:26 »
dad you're embarrassing me
« Reply #8091 on: Thu, 26 May 2016, 11:55:44 »
I mean which company made the toy, smart alecks.  :mad:
« Reply #8092 on: Thu, 26 May 2016, 11:57:41 »
A toy company would be my guess
Offline yomammary
« Reply #8093 on: Thu, 26 May 2016, 12:03:09 »
RF 87u 55g | Leeku 1800
Offline mteinum
« Reply #8094 on: Thu, 26 May 2016, 12:22:11 »
A toy is correct  ;D
LEGO STAR WARS 75114 First Order Stormtrooper
Offline Kudos
  • Godspeed
  • GAF
« Reply #8095 on: Thu, 26 May 2016, 14:01:37 »
55G + Purple slider HHKB Bluetooth
138092-0
Put together an overview of the modification here:
https://keykollectiv.com/2016/05/25/redefining-endgame/
Offline aaron6301
  • Pixel Pusher
« Reply #8096 on: Thu, 26 May 2016, 14:27:19 »
Frankenfurt looking right at home. Very nice  :thumb:
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #8097 on: Thu, 26 May 2016, 14:51:29 »
Removed the coffee from my RF 😅
Sadly no Artisans.. I think. Will have to check my storage.
Sent from my OnePlus One
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #8098 on: Thu, 26 May 2016, 14:58:26 »
Is that green a dye job?
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #8099 on: Thu, 26 May 2016, 15:06:08 »
Nah I bought these. Not sure the source though I bought it second hand.
