Author Topic: keycaps for kbt pure?  (Read 3122 times)
Offline Dubsgalore
« on: Thu, 28 February 2013, 23:37:29 »
Hey All,
just wondering where and what i can buy for keycaps for my kbt pure. what types of keycaps are compatible with the kbt pure? and where can i buy backlit-compatible keycaps? thanks
Offline esoomenona
  • Gnillort?
Re: keycaps for kbt pure?
« Reply #1 on: Tue, 05 March 2013, 10:49:34 »
Backlit compatible, you may want to look at Ducky's sets, over at mechanicalkeyboards.com. With the Pure and those sets, you may not be able to fit the right shift key.
Other than those, you should be able to get any set that are sold in group buys so long as you also pick up a ISO set. You need the smaller right shift and extra key. You'll have to just accept the ISO enter key and such in the process.
Offline Dubsgalore
« Reply #2 on: Tue, 05 March 2013, 20:31:45 »
i just couldn't find any 'backlight compatible' keycap sets
Offline esoomenona
  • Gnillort?
« Reply #3 on: Tue, 05 March 2013, 20:36:11 »
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=228
I believe these are them. They also have Black and Purple, but those are both sold out. They are Shine replacement caps, as they say. The Shine is a backlit board.
Offline Lastpilot
  • Power stance
« Reply #4 on: Sat, 09 March 2013, 10:01:21 »
You can use a blank caps lock key for the right shift if you want. It's available from wasdkeyboards.com. It's a 1.75 key and you can buy it individually. Otherwise, you'll have to find a Tsangan kit if you want a printed one.
