Author Topic: A question for all Apple Standard Keyboard M0116 users  (Read 1140 times)
Offline simingma
« on: Fri, 01 March 2013, 17:46:21 »
Do you find sometimes the keyboard fails to register a letter when you type fast?
For example, try typing "region" and "question" as fast as you can.
What I usually get is:
regin
regin
regio
regin
reion
region
reign
region
regin
questin
questin
question
questin
questin
qustin
questin
I tried on two different M0116s all had this same problem. My AEK does not, so it was not the iMate. I suspect its the microcontroller? Do you have the same issue?
Thanks.
