Author Topic: Apple Shortcuts  (Read 4344 times)
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
Apple Shortcuts
« on: Fri, 25 January 2008, 11:26:53 »
I have found an apple page that lists some of the shortcuts, but I wonder if that is all there is?
I am referring to the function keys provided by the latest Apple keyboards and the Tactile Pros and SMK-88s.
Volume up, volume down, mute, eject, etc...  Anyone know of keys that would lead to an equivalent keypress?  I know F12 for 2 seconds is eject, F14 is dimmer, F15 is brighter , but can I manipulate the volume from the keyboard without the explicit volume keys?
This could be very wiki-able if we could get some good info together.
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline ashort
  • Hoosier Daddy
Apple Shortcuts
« Reply #1 on: Fri, 25 January 2008, 15:23:33 »
And now that I take a closer look at the Apple keyboard, I see it is not only missing the keys between the numeric keypad and the alpha keys, but it has no function key row either.  I need some HELP if I am to use this keyboard long term.
Andrew
Offline iMav
  • geekhack creator/founder
Apple Shortcuts
« Reply #2 on: Fri, 25 January 2008, 19:17:21 »
Have you tried this??
Offline ashort
  • Hoosier Daddy
Apple Shortcuts
« Reply #3 on: Fri, 25 January 2008, 20:58:26 »
I guess I'm such an Apple newbie, I've installed it and I am looking at the configuration screen and wondering how it will help me?  I was expecting "When I press control/option/+, turn up the volume" type of configuration.  I don't see that here.
Andrew
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
Apple Shortcuts
« Reply #4 on: Fri, 25 January 2008, 23:35:08 »
I tried that one too. It sucks as a remapper. You can't choose what to do by any means other than a few check boxes, and none of them did what I wanted, so I got rid of it.
That old Apple keyboard is going to have the same function as the Model M or the Das. Sorry
If you want to control iTunes directly while using a different app, try SizzlingKeys (Google it). It adds user programmable shortcuts for all the major functions of iTunes, such as play / pause, skip forward and back, volume up and down. It's a freebie to.
If I ever find a Mac key remapper, I'll let you guys know.
Offline ashort
  • Hoosier Daddy
Apple Shortcuts
« Reply #5 on: Sat, 26 January 2008, 08:26:15 »
I'm kicking around a program called Ukelele.  Have you tried that?  It creates custom layouts.  I think implementing that layout is another thing, but the ability to create them seems like a first step.
http://scripts.sil.org/cms/scripts/page.php?site_id=nrsi&id=ukelele
Andrew
Offline xsphat
  • Enlightened
Apple Shortcuts
« Reply #6 on: Sat, 26 January 2008, 10:00:09 »
I looked at it but I got scared - I don't want to mess with all that. I have decided to give up trying to make things better and suffer for the rest of my crappy life.
