Author Topic: Keyboards Spazzing out, HHKB Pro 2 and IBM Model F AT  (Read 1690 times)
Offline ironman31
« on: Fri, 01 March 2013, 22:42:14 »
I quickly glanced around google to see if I could find the solution, but I figured I would ask here. Ever since I rebuilt my computer I have not been able to use my HHKB and Model PC AT (using the blue cube). When I plug one of them in, things start freaking out on the screen, applications open up, basically like all the keys on the keyboard are being pressed at once.
I have narrowed it down to a problem with my computer. Both keyboards work with my mac and another Windows 7 machine I have. I'm trying to mess around with the drivers but I am not able to do anything when I have the keyboard plugged in.
Does anyone know what this could be? I feel like it might have something to do with the drivers of these abnormal keyboards not being install properly, but how can I mend this?
« Last Edit: Sat, 02 March 2013, 01:41:46 by ironman31 »
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/ATNoppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline Mainian
Re: Keyboards Spazzing out, HHKB Pro 2 and IBM Model F AT
« Reply #1 on: Fri, 01 March 2013, 22:44:42 »
Did you do a fresh install? And you are plugging the IBM as ps2 and then connecting it when the computer is on?
Offline ironman31
« Reply #2 on: Fri, 01 March 2013, 22:47:03 »
No, like I mentioned, I am using the blue cube. And I have not done a fresh install. That would be my last option.
Keyboards:
Pointing Devices:
Offline ironman31
« Reply #3 on: Sat, 02 March 2013, 01:41:54 »
OP updated
Keyboards:
Pointing Devices:
Offline laffindude
« Reply #4 on: Sat, 02 March 2013, 01:56:37 »
Try a powered hub.
Offline ironman31
« Reply #5 on: Sat, 02 March 2013, 02:11:48 »
Don't have one.
Keyboards:
Pointing Devices:
Offline laffindude
« Reply #6 on: Sat, 02 March 2013, 02:14:08 »
Well you can try to diagnose if it is a software problem. Try a linux liveCD and see if the keyboard works normally.
Offline ironman31
« Reply #7 on: Sat, 02 March 2013, 02:16:56 »
Well its definitely a problem with either windows or my machine, because it works on my mac and my other windows 7 laptop. They only thing I could think of is something might not be working correctly since I kept the same Windows install from a previous motherboard. Basically upgraded everything but my SSD. I'll probably just reinstall this weekend
Keyboards:
Pointing Devices:
Offline ironman31
« Reply #8 on: Sun, 03 March 2013, 16:12:16 »
Found what the problem was, but don't know where its coming from.
I realized that the only devices acting funny were ones with capacitive touch screens, touch pads, or switches. My Realforce didn't have the problem until last night and it acted as though the windows key was always pressed. There is definitely some interference in the room I use  since all of these devices work when plugged up outside the room.
My guess is the cable, but we'll see.
Keyboards:
Pointing Devices:
