Author Topic: Post your tricked out CM QFRs  (Read 170014 times)
Offline HotKillerZzz
  • Ammesia
Re: Post your tricked out CM QFRs
« Reply #300 on: Sat, 09 November 2013, 08:42:19 »
Pretty simple but I like how the red back plating goes with the blanks.
I like the simplicity of it!
I do love the red back plate of this keyboards. I centered my design choice around the red back plate too! I posted this in another thread 2 weeks back but I'll post it here too :)
The entire keyboard is Red, White, and Black! From the case, keycaps, back plate, logo, and even down to the switches (MX Reds)!!!
How did u make that red cmstorm logo?
  • Ammesia
« Reply #301 on: Sat, 09 November 2013, 09:47:25 »
Offline zoolzoo
« Reply #302 on: Mon, 11 November 2013, 14:55:02 »
Here's my QFR's latest look
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
« Reply #303 on: Mon, 11 November 2013, 23:16:54 »
Smooth, with a capital smoo! :)
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
« Reply #304 on: Mon, 11 November 2013, 23:57:08 »
I'll just put this here my QFR with Greens....oh and a lot of pink!
43610-0
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
« Reply #305 on: Tue, 12 November 2013, 03:17:33 »
White an pink is excellent match for Miami!
Offline zoolzoo
« Reply #306 on: Tue, 12 November 2013, 05:14:17 »
pretty hot!
Offline baldgye
  • Will Smith Disciple
« Reply #307 on: Tue, 12 November 2013, 05:34:41 »
Damn son that looks epic!
Offline ITzNybble
« Reply #308 on: Tue, 12 November 2013, 09:06:23 »
Thanks! It is my current pride and joy.....well except my daughter of course :D
« Reply #309 on: Wed, 13 November 2013, 16:29:56 »
I really like this look!  :thumb:
Offline Coreda
« Reply #310 on: Sat, 11 January 2014, 01:18:10 »
Quick question: is there a place I can find blank / colored QFR cases? Or are they all custom-painted?
Also, is there an online store which sells full replacement key sets or will I have to browse the forum to pick them up?
Thanks  ;D
« Reply #311 on: Sat, 11 January 2014, 01:51:27 »
Thanks  ;D
http://www.cmstore-usa.com/quickfire-rapid-replacement-top-panel/
Black or silver only.  Colour it yourself :)
Offline Coreda
« Reply #312 on: Sat, 11 January 2014, 03:11:42 »
Good to know, thanks! Appears as though the MX Browns only come in a black case  :rolleyes:
Is it just the stock photographs or do newer models actually come without the logo above the arrow keys now?
« Reply #313 on: Sat, 11 January 2014, 04:40:35 »
The older cases had the logo above the arrow keys.
Newer cases do not.
Offline reset
« Reply #314 on: Sat, 18 January 2014, 14:11:30 »
This is my first MX board. Like a lot of others, I found the font to be annoying. Luckily, I found an old Silitek Lite-On board for $2 that had MX-compatible caps. Kill+, Link+, & Loop+ keys are from a grab bag. Anyone know what they were used for?
« Last Edit: Sat, 18 January 2014, 14:23:56 by reset »
Offline do_Og@n
« Reply #315 on: Sat, 18 January 2014, 19:29:12 »
That brings back memories....my first QFR looked exactly like that.
Offline reset
« Reply #316 on: Sun, 19 January 2014, 12:10:03 »
It would be nice if I could find a cheap rubber-dome that would provide a complete keyset for the QFR. (Are there any?) I like my current set-up, but I'm sure I'll eventually spring for something else.
« Reply #317 on: Sun, 19 January 2014, 15:12:01 »
If you're asking what I think you're asking, most rubber dome keycap sets are not Cherry MX-compatible.
Offline reset
« Reply #318 on: Sun, 19 January 2014, 15:31:30 »
Sorry, I wasn't clear. I meant an MX-compatible rubber dome that would provide a complete set for the QFR. The Lite-On rubber dome that I found was MX-compatible, but it was made before Windows, so the bottom row wasn't compatible.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #319 on: Sun, 19 January 2014, 15:35:49 »
like he said there are none.........
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline reset
« Reply #320 on: Sun, 19 January 2014, 15:40:53 »
Hmm...that's what I thought. I was hoping there were some with a modern layout, but I guess they're not out there. Thanks.
Offline Tabrin
« Reply #321 on: Sat, 22 February 2014, 09:42:10 »
QFR, MX Reds. Vortex double shot PBT whites and Sanctuary Diablo-style red keycaps. I wish I could find more red/orange keycaps that weren't pastel shades.
« Last Edit: Sat, 22 February 2014, 09:48:37 by Tabrin »
« Reply #322 on: Sat, 22 February 2014, 18:06:01 »
Rowdybeit QFR :)
55232-0
Offline admiralvorian
  • DIY
« Reply #323 on: Mon, 24 February 2014, 23:25:11 »
I posted this a while ago, did mine up with some colored duct tape and it came out pretty cool
Darude Status:
☐ Not Sandstorm
☑ Sandstorm                                               wts wtt wtb
Offline swornxin
    • Nailed Down Custom Pins
« Reply #324 on: Sun, 09 March 2014, 13:58:10 »
Lots of awesome ideas in here.  I'll be posting mine once the new caps come in1
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline berserkfan
« Reply #325 on: Mon, 10 March 2014, 02:05:13 »
Admiral,
I'm thinking of doing duct tape also
But don't these get nasty after a while? The sticky stuff starts leaking out at the edges causing dirt to adhere. Do you do something to prevent the dirt, such as spraying on a layer of transparent acrylic paint or something?
Offline esko997
  • Linux Lover
« Reply #326 on: Sat, 12 April 2014, 19:12:18 »
Know the thread is kind of old but really wanted to post this --
My Green QFR...
Sorry for potato quality.
Daily Drivers:  Unicomp Customizer (BS -- Linux Layout) | Vortex Race 3 (Clears)
Other Boards: CM Quickfire Stealth (Greens) | Poker II (Blues) | PLU-ML 87 (Ergo Clears)  | JD40 (Browns) | Leopold FC660C (Topre) | IBM Model M | ErgoDox (Clears) | Sentraq s60x DIY (Blacks) | Anne Pro 2 (Blues) | Cherry G80-11900 (Blacks) | Kira (99 Key) (Hako True)
« Reply #327 on: Sat, 12 April 2014, 21:30:59 »
My Green QFR...
Not that old!  My QFR still looks like Rowdybeit.
Are those EK green keycaps btw?
Offline esko997
  • Linux Lover
« Reply #328 on: Sat, 12 April 2014, 22:00:58 »
My Green QFR...
Yes sir, just arrived today for EK.
« Reply #329 on: Sat, 12 April 2014, 22:42:39 »
My Green QFR...
I have the lettered greens ones around somewhere - they were surprisingly good quality, although I didn't use them long enough to test how resilient the pad printing is.
Offline esko997
  • Linux Lover
« Reply #330 on: Thu, 17 April 2014, 20:16:42 »
My Green QFR...
They dont feel like the BEST quality to me, but theyre definitely really good for the $20 price tag I'd say. I'm enjoy them at least -- and they making me get better at touch typing  ;D
« Reply #331 on: Thu, 17 April 2014, 22:54:18 »
Under the right lighting, these are really bright:
Offline esko997
  • Linux Lover
« Reply #332 on: Thu, 17 April 2014, 23:22:14 »
Woah gotta say, those do look reallllly nice too.
« Reply #333 on: Fri, 18 April 2014, 01:03:09 »
The shots I took of them on my KeyCool look even brighter, but that is OT for this thread ;)
Offline Alex92
« Reply #334 on: Mon, 21 April 2014, 19:11:33 »
Offline esko997
  • Linux Lover
« Reply #335 on: Mon, 21 April 2014, 19:18:48 »
^^Suuuper cool!
Offline Alex92
« Reply #336 on: Mon, 21 April 2014, 19:21:08 »
Offline SeeThruHead
« Reply #337 on: Mon, 21 April 2014, 22:36:00 »
Wow that's so nice.
 Painted QFR          Poker 2
Offline esko997
  • Linux Lover
« Reply #338 on: Mon, 21 April 2014, 22:37:32 »
Also Alex92,
Where did you get that case? Or did you paint it?
Offline Alex92
« Reply #339 on: Mon, 21 April 2014, 23:21:34 »
Also Alex92,
It's a sanded down and spray painted top case
Offline barryberry
« Reply #340 on: Sun, 11 May 2014, 01:07:19 »
64344-0
64346-1
 :p
« Reply #341 on: Sun, 11 May 2014, 03:10:54 »
 :p
THAT'S a nice QFR!  And I'm not just saying that because of the yellow keycaps ;)
Offline reset
« Reply #342 on: Tue, 13 May 2014, 15:07:57 »
SP Dolch set (Green RETURN not included). First time typing on DSAs. Time will tell, but so far I like it! Much nicer than I expected.
« Reply #343 on: Wed, 14 May 2014, 05:25:22 »
The green kinda suits it!  Might have to see if I have one in my Crap Bag for when Granite arrives ...
Offline Badwrench
  • ummmm.....I forgot
« Reply #344 on: Wed, 14 May 2014, 14:18:52 »
Meh, green and blue for DD use.
64730-0
Offline whiskytango
  • Don't touch the trim
« Reply #345 on: Wed, 14 May 2014, 14:42:36 »
Nothing too fancy, but I'll play:
uTKL stainless steel plate
stickered blues with black springs
white cherry stab inserts
Tai Hao ds caps
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #346 on: Wed, 14 May 2014, 17:58:16 »
<somehow this double posted>
« Last Edit: Wed, 14 May 2014, 19:25:05 by Glod »
Offline Glod
    • YouTube Channel
« Reply #347 on: Wed, 14 May 2014, 17:58:57 »
- uTKL SS Plate
- Frosty Flake Controller with Easy AVR Keymapper Firmware (very thankful for this!)
- Clears with 62g (Korean) Springs
- painfully high quality switch lubing (i didn't rush it like i usually do, and i know some others do)
* Krytox grease/lube mix on slider rails and arms
* Krytox grease on the top of the sliders to alter sound on return travel
* Silicon "dry" lube on springs
- Green Stickers (Korean)
Man these switches, like i didnt like ergo clear before, i really dismissed it months ago when i finally tried it but now i realize how great it is :O I think my ergodox needs to have these.....
Currently rocking skull squad dsa set and black CMStorm shell that has seen better days
« Reply #348 on: Thu, 15 May 2014, 05:39:55 »
The BroBot goes well with the TaiHao! :)
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #349 on: Thu, 15 May 2014, 06:20:28 »
My custom QFR with a custom plate which has been lubed vintage blacks with Korea group buy 62g springs, lubed browns, and now to ergo clears with 60g springs. Selling/giving it to my best friend who enjoyed the feel of my Filco with ergo clears, and only owns stock blacks. I'm gonna miss this baby... it's my second keyboard which I modded.
Phone pic (potato):
