Author Topic: Post your tricked out CM QFRs  (Read 168662 times)
Offline deazncy
Re: Post your tricked out CM QFRs
« Reply #50 on: Fri, 22 March 2013, 03:14:15 »
Painted case, engraved PBT caps, and some doubleshots.  I'm looking for the right paracord, then I'll be adding a custom sleeved cable.
Amazing... Looks like a Korean board.
“Do not pray for an easy life, pray for the strength to endure a difficult one” -Bruce Lee
« Reply #51 on: Fri, 22 March 2013, 03:47:39 »
That's an awesome color ;) ;) ;)
Reminds me of something.
Offline Turkishrambo
« Reply #52 on: Fri, 22 March 2013, 08:49:51 »
if he didnt say it was a qfr i woulda guessed aluminum ^ lol
Offline deSheol
  • Thorpe
« Reply #53 on: Fri, 22 March 2013, 09:05:01 »
looks awesome, what color did you use to paint the case?
Offline dimamantra
  • | (• ◡•)| (❍ᴥ❍ʋ)
« Reply #54 on: Fri, 22 March 2013, 12:30:52 »
^ I think my favorite part is the 3 awesome face caps. Just love those things.
I got the phantom version for my QFR and its on the escape key.
The color is def the second favorite part
« Reply #55 on: Fri, 22 March 2013, 20:14:04 »
Montana Gold 100% Cyan.
« Reply #56 on: Fri, 22 March 2013, 20:19:55 »
I should do that to my Filco, and then I can feel like I have my LZ-S when I take it out!
Offline BornEvil
« Reply #57 on: Sun, 24 March 2013, 19:04:10 »
here is mine:
from this:
to this:
Took me 2 hour with some vinyl. My potato makes it look beige, but it it actually high gloss brilliant white.
Vinyl is brilliant, plan to change it's color every few months cos it is so cheap. What color should i go for next, i was thinking yellow...
9087 Shine 2 Brown ISO | Quickfire Pro Red ISO | Quickfire Rapid Brown ANSI
Offline dimamantra
  • | (• ◡•)| (❍ᴥ❍ʋ)
« Reply #58 on: Sun, 24 March 2013, 19:13:12 »
here is mine:
from this:
to this:
I got the same monitor as you. woot!
Also, nice board. Diggin' the all white.
Offline bazemk1979
« Reply #59 on: Fri, 29 March 2013, 20:09:36 »
« Reply #60 on: Sat, 30 March 2013, 23:36:06 »
Offline berserkfan
« Reply #61 on: Tue, 02 April 2013, 09:42:36 »
Hello Absyrd
can I ask more about the paint and technique you used? I am a noob to these kinds of things, but yes, I also want to get rid of the iritating CMStorm logo. I want to do so with minimum technical skill and equipment, so I hope you're not going to tell me you did something very difficult and expensive!
Rusto "textured" black painted QFR with (The Man, The Legend) Boost's Superhero keycap prototype...
Paint has held up a LONG time at this point. Especially since it is my daily driver, too.
Offline berserkfan
« Reply #62 on: Tue, 02 April 2013, 10:00:22 »
will post more if I have time to mess around with my keyboards!
Offline blueasjim
« Reply #63 on: Tue, 02 April 2013, 10:11:07 »
My current workstation keyboard.
Vortex KBT PURE [MX Red] | CM Storm [MX Blue] | CM Storm [MX Red]
« Reply #64 on: Tue, 02 April 2013, 13:31:31 »
Hello Absyrd
Looks to just be black PlastiDip. You just spray or brush it on.
Offline hoasican2004
« Reply #65 on: Tue, 02 April 2013, 20:13:17 »
very nice, like this ^^
« Reply #66 on: Tue, 02 April 2013, 20:23:28 »
Offline tricheboars
  • Keyboards are Important!
« Reply #67 on: Sat, 06 April 2013, 11:41:52 »
made this for my lady.  it has blues. i am still waiting for the korean flag mod pack to come in. but in the mean time i wanted to show off my paint job.  :p :p
Offline codymaust
« Reply #68 on: Sun, 07 April 2013, 11:58:14 »
Does anybody have an unbranded QFR with CCnG?
Trying to decide if I should paint mine when my set comes in.
I know CCnG looks good on black, but idk about the grey..
Here is mine: (potato)
18008-0
Offline tricheboars
« Reply #69 on: Mon, 08 April 2013, 16:32:28 »
before my QFR was pink it was an unbranded QFR qith CCnG keycaps. It looked great. It just looks way better with a pink case.
Offline SmallFry
« Reply #70 on: Mon, 08 April 2013, 18:25:50 »
Added a few caps...
Offline le_doosh
« Reply #71 on: Tue, 09 April 2013, 13:21:53 »
After seeing all of the plasti-dipped QFR's, I decided to give it ago (since I had the old "branded one")
Offline SmallFry
« Reply #72 on: Wed, 10 April 2013, 11:16:13 »
This is my other QFR.
« Reply #73 on: Wed, 10 April 2013, 11:20:55 »
You put a Korean keycap set on a non-Korean keyboard?!?! Blasphemy!! :P
Offline tricheboars
« Reply #74 on: Wed, 10 April 2013, 12:27:29 »
smallfry's first QFR can also be posted on teh Unicorn Vomit thread. LOL.  :p :p :p :p
Offline SmallFry
Re: Re: Post your tricked out CM QFRs
« Reply #75 on: Wed, 10 April 2013, 14:10:41 »
Way ahead of you!
« Reply #76 on: Wed, 10 April 2013, 14:14:06 »
Whoa. Meth clusters on Graphite?? That looks super hot.
Offline SmallFry
« Reply #77 on: Wed, 10 April 2013, 14:18:15 »
I agree, I think I'm going to leave my two QFRs as is for a while.
Offline gameaholic
« Reply #78 on: Wed, 10 April 2013, 23:44:57 »
What Korean caps are those?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline SmallFry
« Reply #79 on: Wed, 10 April 2013, 23:52:45 »
Graphite and blue or summat, typically called Graphite.
Offline naokira
  • The King in the North
« Reply #80 on: Fri, 12 April 2013, 23:04:28 »
This will be my gift for my girlfriend's graduation :)
FaceW in LZ-CE
Offline rurushu
« Reply #81 on: Fri, 12 April 2013, 23:24:42 »
graduation with flying rainbow colors!!!!  ;)
Offline file_id
« Reply #82 on: Sat, 13 April 2013, 03:31:00 »
Baller, louis vuitton
DS3 White YOTS (Blue)|Poker 2 (Blue,Clear)|QFR Rapid-i TKL (Brown,Blue)|QFR Rapid TKL (Blue,Red,Brown)|KBP V60 (Blue,Clear,Matias Click)|Code TKL Clear|Filco MJ2 TKL (Blue)|Filco MJ2 Ninja Beige TKL (Brown)|Novatouch
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #83 on: Mon, 15 April 2013, 20:45:47 »
CMStorm QFR Blues with Klaxon Key Caps and Vortex Red Aluminium Case
Fit Like a Glove and Looks Fantastic, all that's left to do is do a mod where i wire leds into the holes on the case and wire into pcb, already figured out how im going to do it but im going to need to drill into plate and desolder the switches. i just want to use my time for other stuff.
once complete this bad ****er is going to my friend as I have way too many keyboards.
i wish i had a better camera to show the awesome
Offline blueasjim
« Reply #84 on: Mon, 15 April 2013, 22:51:13 »
Where did you get the red on white keys???? o.O love em
Offline file_id
« Reply #85 on: Tue, 16 April 2013, 01:44:55 »
Offline Glod
    • YouTube Channel
« Reply #86 on: Tue, 16 April 2013, 04:42:24 »
Klaxon (Red Alert 2.0 Clone), which has shipped last week and group buy is complete. however there are few requests for a second round not sure if that will ever happen.
Offline Muffet
  • Man of many paths
« Reply #87 on: Tue, 16 April 2013, 06:04:30 »
This is the most beautiful board I have ever laid eyes on. When I recieve my GH60 I intend it to look as much like this as possible.
     Painted QFR    Cherry ML for Work
Offline monday
    • Days of Game
« Reply #88 on: Wed, 17 April 2013, 03:03:52 »
HEHEH I see what you did there :D
Offline durainello
    • Free cheap and fast International shipping solution to fellow Singaporean.
« Reply #89 on: Wed, 17 April 2013, 03:50:02 »
Offline bazemk1979
« Reply #90 on: Wed, 17 April 2013, 07:10:11 »
Added a few caps...
:O
« Reply #91 on: Mon, 29 April 2013, 23:17:03 »
Offline esoomenona
  • Gnillort?
« Reply #92 on: Tue, 30 April 2013, 09:17:59 »
Nice yellow, rowdy.
Offline Rendom
« Reply #93 on: Tue, 30 April 2013, 09:33:20 »
dat filco caps! good job rowdy. looks like you made it.
QFR - MX Blue
Offline gameaholic
« Reply #94 on: Tue, 30 April 2013, 14:25:06 »
Thick Imsto PBT (including GH).  I call it Industrial QFR.
Offline badcop
  • thorpe thocking master race
« Reply #95 on: Tue, 30 April 2013, 14:58:28 »
looks really nice with imsto's set.  i have one on my filco but im itching for a few more :p
moved my RA caps to the QFR
« Reply #96 on: Tue, 30 April 2013, 17:23:10 »
Nice yellow, rowdy.
Well spotted!  Indeed they are, with a replica Cherry red Esc (currently sporting a GH March transparent red).
Offline Goodfella
« Reply #97 on: Sun, 12 May 2013, 14:10:53 »
Took some shots of the new keyboard, finally got a brandless one, it turned out pretty sharp. QFR with browns, pbt white engraved keycaps, and a smokebot brobot..
QFR | QFR | QFR | Pure LED
Offline PolaBurrr
« Reply #98 on: Sun, 12 May 2013, 18:15:39 »
whats wrong with your spacebar?
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #99 on: Sun, 12 May 2013, 18:27:39 »
lol
