Author Topic: Favorite Firefox extensions  (Read 10487 times)
Offline iMav
  • geekhack creator/founder
« on: Fri, 08 February 2008, 03:56:12 »
For those of you that use FireFox, what are som of your favorite extensions?
Here are the ones I use on a regular basis:
FireGPG
Better Gmail 2
AdBlock Plus
FasterFox
Google Browser Sync
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
« Reply #1 on: Fri, 08 February 2008, 06:06:47 »
I have GTDInbox, but I can't figure out how to make it work.  I also have User Agent Switcher, which is effective about half the time.  AdBlock is great.  I have Sage installed but I don't much use it anymore.  it's a nice RSS reader.  Check4Change has it's uses.
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline fkeidjn
« Reply #2 on: Fri, 08 February 2008, 21:13:10 »
Adblock Plus and Stopscript
Is Fasterfox that good?
Kinesis Keypad - Filco FKBN104M/EB - Unitek space-saver - Acer 6511-TW - Apple Extended II (M3501) - Scorpius M10 - Cherry G80-1800, AT - SGI Granite - vintage Fujitsu - IBM Model M, 101 and mini - Model F, 84-key AT - Dell AT101W - Northgate 101
Offline iMav
« Reply #3 on: Fri, 08 February 2008, 22:40:57 »
Quote from: fkeidjn;2871
It tweaks most of the settings that I used to tweak in Firefox manually to improve perceived speed.
It certainly is worth the, what, 10 seconds it takes to install it.  ;)
Offline zerogravitas
« Reply #4 on: Fri, 08 February 2008, 23:07:39 »
Among my favs are:
Adblock
Adblock Filterset.G Updater
all-in-one gestures
DownThemAll
Flashblock
ImgLikeOpera
Stop-Or_Reload Button
Digger
Tab Mix Plus
I mostly use Tab Mix Plus to fix the tab bar since Mozilla screwed it up. recently.  :)
Offline bioanarchism
    • http://www.frro.net
« Reply #5 on: Mon, 18 February 2008, 11:58:27 »
these are the add-ons on my browsers:
CustomizeGoogle
Download StatusBar
DownThemAll!
FoxClocks
Foxmarks
HTML Validator
IETab
Tab Catalog
ChatZilla
Offline iMav
« Reply #6 on: Fri, 18 April 2008, 12:23:35 »
My new favorite.
No Squint
Offline jemkeys
« Reply #7 on: Fri, 18 April 2008, 12:59:28 »
AdBlock Plus
FlashGot
Offline karlito
    • http://altitudegame.com
« Reply #8 on: Fri, 12 December 2008, 17:29:37 »
So i started getting annoyed with stupid flash everywhere and java and java script etc and I stumbled upon No Script
https://addons.mozilla.org/en-US/firefox/addon/722
I freaking LOVE it.  Flash players now just show up as an empty box and you can click to enable them.  It blocks all
