Author Topic: [IC]BSP Dyesubs Full sets++  (Read 20351 times)
Offline rodtang
« on: Mon, 11 March 2013, 12:28:50 »
https://docs.google.com/forms/d/1VMf2Tu0CHu0yKffyVc17OWjSPhN0ee64VLni5BCBtJw/viewform
There are no prices on this interest check, there will be one later with prices after this one is over and we've gotten a quote the results from this IC.
Feel free to ask any questions you might have.
More info in these two threads:
http://deskthority.net/workshop-f7/theoretical-interest-check-for-bsp-dyesubs-t5234.html
http://deskthority.net/keyboards-f2/bsp-europe-a-mx-keycap-maker-t5088.html
Offline esoomenona
  • Gnillort?
Re: [IC]BSP Dyesubs Full sets++
« Reply #1 on: Mon, 11 March 2013, 13:41:34 »
Would this be like the IC being held here?
Offline rodtang
« Reply #2 on: Mon, 11 March 2013, 13:56:31 »
Well, that one is also ANSI without spacebar and RGB, this is that plus spacebar, ISO enter, winkey, language specific keys and bunch of other stuff (just take a look in the poll).
You will be able to use this set on just about any modern MX keyboard.
Also, the colour is not 100% certain.
Offline calavera
« Reply #3 on: Mon, 11 March 2013, 13:59:56 »
I would say they're two different IC's using the same company. As far as I know there was no successful attempt at merging the group buy.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Mon, 11 March 2013, 14:02:46 »
Indeed, indeed. Interest is now piqued more so than that one I posted. Is the spacebar PBT as well?
Offline rodtang
« Reply #5 on: Mon, 11 March 2013, 14:08:20 »
They will be PBT, we are currently discussing them and the goal is to have both 6.25 and 7unit moulded after cherry where the 6.25 one will have universal mounts.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #6 on: Mon, 11 March 2013, 14:11:16 »
Form filled!!
-Enzo Ferrari
Offline rodtang
« Reply #7 on: Mon, 11 March 2013, 14:11:53 »
There wasn't really any attempt.
Offline Michael
  • Formerly Bro Caps
« Reply #8 on: Mon, 11 March 2013, 14:51:49 »
I hope you plan on merging interests with KBD/OTD/DT, etc to make it cheaper for all. People trying to one-off these are only hurting the community.
Offline rodtang
« Reply #9 on: Mon, 11 March 2013, 14:59:38 »
This started at DT.
I'll see what I can do.
Offline calavera
« Reply #10 on: Mon, 11 March 2013, 15:31:53 »
UK = US right?
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #11 on: Mon, 11 March 2013, 15:33:45 »
UK = US right?
Pretty sure UK is ISO.
US is US ANSI
Offline rodtang
« Reply #12 on: Mon, 11 March 2013, 15:39:42 »
The base set it US ANSI, if you're only interested in US ANSI you don't need to fill in any other language/layout.
Offline calavera
« Reply #13 on: Mon, 11 March 2013, 15:48:19 »
DOH! Damn it can I just resubmit?
Offline rodtang
« Reply #14 on: Mon, 11 March 2013, 16:10:45 »
I deleted your first one from the spreadsheet (but they'll both be in the main results page but that doesn't matter too much)
Offline leesofi
  • super lurking
« Reply #15 on: Mon, 11 March 2013, 16:17:31 »
fiiled the form.
Offline kboardvintage
« Reply #16 on: Mon, 11 March 2013, 18:06:30 »
Did you just made this up?? Since when BSP can do ISO enter, winkey and left Shift? Are you going to buy all those molds? PBT spacebar? U serious?
Anyway, I wish you luck with it... and if you can make it possible I'll be in for 2!  :cool:
Offline rodtang
« Reply #17 on: Mon, 11 March 2013, 18:22:00 »
They can make everything you just listed but the ISO and the spacebars and one major reason for the IC (and later hopefully GB) is to make those (and probably some other caps like 1.75x shift and center stem caps lock) a reality.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #18 on: Mon, 11 March 2013, 19:44:34 »
Form filled....
Offline rodtang
« Reply #19 on: Tue, 12 March 2013, 14:48:23 »
Offline alixinhzai
« Reply #20 on: Tue, 12 March 2013, 19:13:52 »
can I order 2 or 3 spacebar?
Offline rodtang
« Reply #21 on: Wed, 13 March 2013, 01:19:11 »
Size or number of spacebars?
Offline alixinhzai
« Reply #22 on: Wed, 13 March 2013, 02:40:11 »
number :)
Offline rodtang
« Reply #23 on: Wed, 13 March 2013, 08:24:49 »
You should be able to order as many spacebars as you'd like.
Offline SmallFry
Re: Re: [IC]BSP Dyesubs Full sets++
« Reply #24 on: Wed, 13 March 2013, 08:33:21 »
Everyone found the companies at the same time, don't think they're trying to harm the community, only that they had all started their own efforts at the same time. They just need to consolidate ideas, so hopefully language barriers aren't too bad. Just my .02 though.
Offline esoomenona
  • Gnillort?
« Reply #25 on: Wed, 13 March 2013, 08:35:07 »
Well I hope it happens soon, if at all, seeing that TRiK just started their GB.
Offline rodtang
« Reply #26 on: Wed, 13 March 2013, 09:03:49 »
Quote from: rodtang@deskthority
Got a quote on moulds for 1.75x right shift, ISO enter, center stem caps lock and 6.25 universal spacebar.
140 000 DKK, that is just under 18800 euros, looks like we'll need a lot of ****ing orders to make the prices not suck...
« Reply #27 on: Wed, 13 March 2013, 09:16:22 »
 :rolleyes: are u serious? Mate, give it up with the ISO sets and aim for ANSI sets  :))
Offline rodtang
« Reply #28 on: Wed, 13 March 2013, 09:48:02 »
Not gonna happen ;)
« Last Edit: Wed, 13 March 2013, 09:49:46 by rodtang »
Offline BimboBB
« Reply #29 on: Wed, 13 March 2013, 10:01:55 »
shift, capslock and spacebar hasnt anything (specific) to do with ISO.
Offline SmallFry
« Reply #30 on: Wed, 13 March 2013, 10:03:31 »
I agree, despite not using ISO, that we should include it. Maybe I'll build an ISO board just for grins some day.
« Reply #31 on: Wed, 13 March 2013, 10:30:02 »
True, I missread that 1.75x "right shift". I guess he means G80-1800 right shift and not ISO.
Offline Loligagger
« Reply #32 on: Thu, 14 March 2013, 20:10:09 »
Form filled. If all these options (1.75 right shift, control caps lock replacement, etc) become possible I'll be sold.
Offline rodtang
« Reply #33 on: Fri, 22 March 2013, 10:32:28 »
So far it looks like it would be best to only do modifiers in gray as so far over twice as many people are interested in those opposed to the white ones.
It also looks like there will be no French, Portuguese or NEO as there is no interest.
There also seems to be equal interest in all the ones needing moulds made which means there will have to be more interest for this to be possible at any reasonable price.
Offline LechnerDE
« Reply #34 on: Mon, 25 March 2013, 12:30:34 »
Filled the form. Looking forward to this!
« Reply #35 on: Sat, 30 March 2013, 03:01:18 »
Won't happen...better check RedLine groupbuy @ vendors forum.
Offline quake4mhg
« Reply #36 on: Sat, 30 March 2013, 23:40:56 »
Any picture for keycaps? Thanks.
Offline rodtang
« Reply #37 on: Thu, 04 April 2013, 16:04:20 »
Here are some pictures of of dyesubs made by BSP as an example:
Offline jil_jil32
  • Tokyo Press <3
« Reply #38 on: Thu, 04 April 2013, 19:06:22 »
Moar colors :x
Offline DamienG
    • DamienG
« Reply #39 on: Thu, 04 April 2013, 21:07:48 »
Is it the image, the camera or the actual printing that looks so bad?
Any chance of an unresized image?
[)amien
Offline rodtang
« Reply #40 on: Fri, 05 April 2013, 16:04:16 »
[)amien
The bad compression on the first pic is what makes the printing look bad, just look at the second pic.
The second pic is the only pic I have, there are some more in the first page of this thread over at deskthority: http://deskthority.net/keyboards-f2/bsp-europe-a-mx-keycap-maker-t5088.html
« Reply #41 on: Sat, 06 April 2013, 16:22:09 »
I don't know whether BSP offer it since they don't have a spec sheet like GMK do, but I would love to see the option to have the caps and scroll lock keys as windowed keys. Would be good for those people who have LEDs underneath their lock keys.
Offline rodtang
« Reply #42 on: Sat, 06 April 2013, 17:13:22 »
They do not do doubleshots so I they wouldn't be able to do windowed caps.
Offline ItsBc
  • BARACOOT
    • Portfolio
« Reply #43 on: Sun, 14 April 2013, 01:24:48 »
form filled
