Author Topic: Suggestions for new Speaker System  (Read 3425 times)
Offline Gupgup
« on: Mon, 11 March 2013, 22:14:31 »
Hey everyone, my old BostonAcoustic speakers just broke down, and it is time for an upgrade!
If you could, please post here with a link to a set of speakers, I'd greatly appreciate it!
I really don't want to spend too much, but maybe up to $200 or so..
I also would like it to have excellent bass, as far as everything else, I don't know much about sound systems so just let me know what you think of your system and why it is good!
Thanks everyone!
Conor - Gupgup
« Last Edit: Tue, 12 March 2013, 18:10:54 by Gupgup »
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Boston MediaTheater System died :/ need a new one!
« Reply #1 on: Tue, 12 March 2013, 16:48:27 »
If you simply blew the speaker it could be a simple and cheap fix. Open up the speaker enclosure an have a look at it. If not sure what you are looking at post a picture.
Otherwise I am not familiar with PC speaker options, especially not at that low end of the budget to help with that. For that cheap I would reccomend checking used/thrift shops for any hi fi gear that appears to be in decent shape.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #2 on: Tue, 12 March 2013, 16:55:10 »
Pictures would be great, but you could be lucky and have just destroyed the rubber surround that keeps everything that moves in check.  Those are typically easy to replace yourself.
Or do like doubleivan said and sink slowly into hi-fi as a hobby.
Offline Gupgup
« Reply #3 on: Tue, 12 March 2013, 17:08:04 »
15493-0
This is the system I own, do you need other pictures? I tried unscrewing the back but some screws wouldn't come out!
Hmmmm
Thanks for your help guys!
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #4 on: Tue, 12 March 2013, 17:13:08 »
I meant the actual speaker :P
Offline Gupgup
« Reply #5 on: Tue, 12 March 2013, 17:23:18 »
15495-0
Sorry haha there ya go!
« Reply #6 on: Tue, 12 March 2013, 17:29:12 »
No the inside! The speaker itself not the enclosure. We need to see if it is clearly blown and what is the size and etc to give repair advice. I searched but could not find any of that info.
Offline Gupgup
« Reply #7 on: Tue, 12 March 2013, 17:32:36 »
Hmmm.. see I knew this was the wrong picture again. But I can't open it up for some reason, the screws won't come out? Let me try again in a sec.
Sorry guys haha
Offline Gupgup
« Reply #8 on: Tue, 12 March 2013, 18:01:49 »
Yeah I can't get it open.. Oh well. They've been used for a long time and it is time for an upgrade!
Gonna change this whole thread to just a suggestion thread :p
Offline IPT
  • Formerly projectD
Re: Suggestions for new Speaker System
« Reply #9 on: Wed, 13 March 2013, 12:29:43 »
so this is for computer speakers right?
Offline Gupgup
« Reply #10 on: Wed, 13 March 2013, 12:40:19 »
Yes sir!
Offline DavinDidIt
« Reply #11 on: Thu, 14 March 2013, 00:57:24 »
There are a lot of options out there, it really depends on what your intended use is for the speakers.  Listening to music? Making music? Movies? Gaming?
« Last Edit: Thu, 14 March 2013, 00:59:29 by DavinDidIt »
KMAC 2, HHKB
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #12 on: Thu, 14 March 2013, 01:09:15 »
I would say spend that $200 on some stellar headphones.
There have been a couple UE triple fi's floating in the past week or so that would rock the chain, if in-ear isn't your thing, there's a good amount of over-the-ear goodness that will get all the everything everytime.
My favorites at this price-ish:
http://ue.logitech.com/en-us/headphones/ue6000
http://us.akg.com/akg-product-detail-us/k-490-nc.html
http://www.focal.com/en/mobile-headphones/298-spirit-one-3544051725002.html
Or if they are your thing, you could go all-in with something like what I did, a custom set from Ultimate Ears  or JHAudio - http://www.jhaudio.com/product/jh5-pro-custom-ear-monitor(what I have, specifically).  Entry level is more than enough for most of today's recorded and compressed music.  They're more money, but well worth it in my opinion as they'll never fall out and provide quiet room levels of sound cancellation.
If $200 is your budget and $250 is super pushing it, over-the-ear will provide better bang for your buck.
« Last Edit: Thu, 14 March 2013, 01:18:53 by tjcaustin »
Offline orlando
« Reply #13 on: Thu, 14 March 2013, 01:46:30 »
If you like Bose see if you can find companion 3 series ... they usually go for under $200. I have those and companion 5 (which retail for $350ish) and I personally love them.
