Author Topic: Are there any decent mechanical full for cheap?  (Read 2555 times)
Offline Preach
  • The Insane
« on: Mon, 11 March 2013, 23:09:21 »
I was wondering if there is a cheap keyboard around the price of QFR that has 10key/keypad.
The reasoning behind it is that I play games like arma, dayz, etc. that require the use of some 10key/keypad buttons.
If anyone knows of any I'd be greatly appreciative.
Thank you
QFR - Browns |
Offline Gupgup
« Reply #1 on: Mon, 11 March 2013, 23:12:41 »
Your best bet is probably a Rosewill, there was a past sale where they went for $30 dollars and I'm sure someone would sell theirs for probably $50 and compromise.
I think they go for $90 or so on amazon or what not, but I don't buy those keyboards anymore. I just get mine from here :D
Gupgup
Offline jabar
Re: Are there any decent mechanical full for cheap?
« Reply #2 on: Mon, 11 March 2013, 23:14:48 »
Cherry POS keyboards can be sometimes found for cheap (used). If you do your research, you can find some that are both NKRO and in a good switch variety (Browns, Clears or Blacks).
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Preach
  • The Insane
« Reply #3 on: Mon, 11 March 2013, 23:20:47 »
I was thinking of a keypad but haven't found a decent one for cheap that's MX.
QFR - Browns |
Offline Hak Foo
  • Make America Clicky Again!
« Reply #4 on: Mon, 11 March 2013, 23:30:35 »
Ducky 1008XM can be as little as $50 or less delivered.
Overton130, Box Pale Blues.
Offline Gupgup
« Reply #5 on: Mon, 11 March 2013, 23:35:18 »
I saw one going for $35 today, can't remember where I did though :/
« Reply #6 on: Tue, 12 March 2013, 07:20:31 »
Coolermaster is coming out with their XT model when the QFR Stealths drop and Ducky is releasing a non-backlit fullsize as well. I think both of those were supposed to be around $70.
Offline jabar
« Reply #7 on: Tue, 12 March 2013, 08:23:22 »
Ducky already has the DK2018 Zero out, non-backlit fullsize for around $80.
Phantom 7bit
« Reply #8 on: Tue, 12 March 2013, 08:41:21 »
Didn't know it was out. Thank you!
Offline Dubsgalore
« Reply #9 on: Tue, 12 March 2013, 16:02:30 »
Thank you
i would look at rosewills
