Author Topic: Keycaps for Razer blackwidow TE  (Read 1494 times)
Offline Harryboii
« on: Tue, 12 March 2013, 13:28:06 »
Just got my first mechanical keyboard, razer blackwidow tournament edition, a couple of days back and I was wondering if I there are any keycaps for it since razer usually has different kinds of keys and sizes when it comes to their keyboards.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Keycaps for Razer blackwidow TE
« Reply #1 on: Tue, 12 March 2013, 13:55:36 »
The only keycap that is 'problematic' which is the bottom row of 1.5 ctrl/alt, 1x win/menu, 6x space... depend on what type of keycap you want. If you go for Cherry, GMK, BSP, or from certain SP set there is no problem. If you are not looking to replace the entire set, it is even less of issue.
Offline Harryboii
« Reply #2 on: Tue, 12 March 2013, 15:20:49 »
Thanks, learn something new everyday.  :)
« Reply #3 on: Tue, 12 March 2013, 15:46:24 »
Sure. While I generally don't like iOne made keyboards, they do have the 1.5 modifiers going for them which make it easy to put nice set of vintage keyboard which is most common on the old ones. Easy to use full set of old doubleshot or dyesub.
