Author Topic: Small keyboard with "feel".  (Read 27955 times)
Offline vils
« on: Thu, 14 February 2008, 17:16:24 »
I'm making a computer out of an old electric typewriter (a Facit with cast aluminium shell). So, I'm searching for a keyboard to fit into this. The HHKB 2 pro is perfect in size but is it "clicky" enough? This http://www.ergocanada.com/products/keyboards/dsi_smk85_compact.html DSI board could work but is a bit too big and the HHKB seems more typewriteish.
Any suggestions?
First poster
/Vils
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline iMav
  • geekhack creator/founder
« Reply #1 on: Thu, 14 February 2008, 17:34:59 »
First off, welcome to geekhack!!
If you are looking for the keyboard to give you an authentic typewriter clicky noise...then the HHKB Pro is not a good choice.  It isn't "clicky" at all.
Your best bet would be to wait for Unicomp to release their "Mighty Mouse" replacement.  It will have a small footprint and buckling springs (which will give you exactly what you are after, I suspect).
Offline rnak92a
« Reply #2 on: Thu, 14 February 2008, 21:04:14 »
iMav,
Might not an 84 key space saver fit his needs, too?  I've no idea how big Unicomp's mighty mouse replacement will be, but I'd suspect it'll be close to the 84 key space saver.  Just a guess...
Regards,
~rn
My keyboards, numpads, and pointing devices
Quote from: Hak Foo
The label says, "World\'s best... guaranteed."
What would happen if I bought one and sent them a nasty letter that read:
"1391401.  I want my money back."
Offline iMav
« Reply #3 on: Thu, 14 February 2008, 21:08:05 »
Quote from: rnak92a;2976
The Mighty Mouse's footprint is SIGNIFICANTLY smaller than that of the 84-key spacesaver.
(Check out the pics at PCKeyboard.)
Offline rnak92a
« Reply #4 on: Thu, 14 February 2008, 21:26:06 »
Sure is.  Mea culpa.
Did Jim Owens give any hint about the release date of the new mighty mouse?  Earlier posts suggest Q2.
Cheers,
~rn.
Quote from: Hak Foo
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #5 on: Thu, 14 February 2008, 22:41:54 »
Buy an HHKB for the chip and make the 'board with whatever clicky switches you like - Alps whites is what I'd use. I like them better than the blacks.
And BTW, I use my HHKB Pro 2 in the library at school. Clicky it is not.
Offline vils
« Reply #6 on: Fri, 15 February 2008, 03:06:52 »
Thanks for all ideas.
The biggest possible size for the keyboard (i.e. the keys) is 13.2x4.7", but rather 11.5x4.65".
I might sacriface the clicks for the perfect size of the HHKB wich in all other respects seems to be an excellent keyboard.
Has anyone expirience of the DSI board?
/Vils
Offline vils
« Reply #7 on: Fri, 15 February 2008, 03:56:53 »
Quote from: vils;2981
/Vils
The DSI board seem identical to the SMK-85.
Where can it be bought?
/Vils
Offline iMav
« Reply #8 on: Fri, 15 February 2008, 05:44:28 »
Which DSI 'board are you referring to?
Offline vils
« Reply #9 on: Fri, 15 February 2008, 05:56:11 »
Follow the link in my first post.
SMK85U-SIL-SM
/Vils
Offline vils
« Reply #10 on: Wed, 05 March 2008, 17:37:43 »
Ok, I seems to have three choices:
SMK85 (Available in april?)
Mighty Mouse (Available before summer?)
HHKB2 Pro
I use a swedish KB layout so some sort of "tweaking" will have to take place. The blank HHKB gives me the option of printing my own letters, but how?
Have I missed som good compact keyboard out there?
Happy for input.
/Vils
Offline alpslover
« Reply #11 on: Wed, 05 March 2008, 19:20:50 »
i once won an ebay auction and the seller sent me the wrong keyboard by mistake.  it was a qtronix scorpius kt-305 with blue cherry switches.  i liked the feel, but disliked the castrated layout.
there's another one on ebay now.  i'd ask the seller to verify the switch type before bidding, though.
Offline IBI
« Reply #12 on: Thu, 06 March 2008, 12:18:42 »
What about the Cherry G84-4100?
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline vils
« Reply #13 on: Thu, 06 March 2008, 17:22:02 »
Quote from: IBI;3466
Right in size, but ML-switches? Is it available in black?
Thanks for the tip.
/Vils
Offline xsphat
  • Enlightened
« Reply #14 on: Thu, 06 March 2008, 18:19:44 »
The ML is a nice switch. It has a real nice clean feeling to it. It's a true linear switch, meaning the force required is equal throughout. The MX black switch isn't really linear at all. As I think Karlito pointed out, it's more like a quadrilateral switch, which sucks. And the G84-4100 comes in black.
One problem for you though: The key caps aren't full sized - they're 3/4. Something to consider. I had one of those keyboards and really liked it.
Offline IBI
« Reply #15 on: Thu, 06 March 2008, 18:20:46 »
It's certainly availible in black here in the UK.
Offline vils
« Reply #16 on: Tue, 11 March 2008, 09:08:51 »
After speaking to the nice people at Unicomp I'm quite sure that my choice will be The MightyMouse.
Does anyone have the exact dimensions of this board, both footprint and the "keys part" (i. e. the opening in the plastic for the keys).
/Vils
Offline vils
« Reply #17 on: Fri, 25 April 2008, 16:37:32 »
Just ordered the HHKB pro 2, will fit perfectly in my rig. I will however also buy the mighty mouse ,for my other computer, when it's available.
/Vils
Offline Bluemercury
« Reply #18 on: Mon, 28 April 2008, 18:16:27 »
Quote from: vils;2973
Any suggestions?
First poster
/Vils
It says there that the smk85 has strongman switches which according to fellow geek hackers are worse than the true alps ones. Also says that the ps/2 has alps linear switches???which color are these?
Collection:
Das Keyboard II
Model M5-2
Model M5-1(considering selling this one)
Cherry G80-3000LCMPO with black switches
Cherry G80-5000HAMPO (Brown switches)
McAlly96
HHKP2 BNx2
Offline xsphat
  • Enlightened
« Reply #19 on: Mon, 28 April 2008, 18:20:54 »
Actually, my SMK85 had black Alps tactile non-clicky switches.
Offline Bluemercury
« Reply #20 on: Mon, 28 April 2008, 18:29:44 »
Quote from: xsphat;4262
It seems they stopped using those for some time.
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline vils
« Reply #21 on: Sat, 02 May 2009, 09:10:12 »
This project is moving forward slowly, but I thought that I should share some pics of the installed keyboard.
Offline vils
« Reply #22 on: Sat, 02 May 2009, 10:36:29 »
I won't be able to keep the raw aluminium finish there are too many epoxy repairs that needs to be covered. I'm trying to find a paint that resembles that greenish metallic apparatus paint used in the 50's and 60's, but I'm still searching...
My comp is always placed in the kitchen, thats where I resides :)
This comp is prepared for a standard PSU, micro-atx mobo, slim-line slot in dvd and two hdd.
For the moment I'll just do things that don't require any cash... hope I can buy some stuff later on.
A very brief project description can be found herehttp://mashie.org/forums/showthread.php?t=357
And my last completed here:http://mashie.org/forums/showthread.php?t=93
Offline chimera15
« Reply #23 on: Sat, 02 May 2009, 11:21:40 »
So did you end up using an smk85? What is that?  Is the mighty mouse clicky?
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline Rajagra
« Reply #24 on: Sat, 02 May 2009, 17:27:21 »
Quote from: vils;88655
Hammerite, maybe?
Offline wheel83
« Reply #25 on: Sat, 02 May 2009, 17:59:26 »
i am currently perfecting the art of installing glass typewriter keys onto model m's.  pics will come in a few weeks.
I <3 BS
Offline vils
« Reply #26 on: Sun, 03 May 2009, 15:57:51 »
Hammerite is not what I'm looking for. To much "paint-feeling".
Does anyone remember that pale, metallic, slightly transparent green laquer found on old dia-projectors, electric radiators, calculating machines and stuff like it? It had a hammered look... is anyone getting wich finish I'm looking for?
I'm propably posing this question to forum members that, like me, was amazed by the first video (top-loaded) and followed the betamax vs. VHS struggle.
Offline vils
« Reply #27 on: Sun, 03 May 2009, 16:43:55 »
That music-thing box has the finish close to what I'm trying to accomplish. I'll trawl hammerite  sites for something like it. Here, Sweden, the hammerite collection is quite thin.
Thanks for the pics.
Offline vils
« Reply #28 on: Sun, 03 May 2009, 16:46:51 »
http://www.rustoleum.com/CBGProduct.asp?pid=29
Bookmarked, searching for retailer...
Offline vils
« Reply #29 on: Sun, 10 May 2009, 18:21:02 »
I should have posted this in the mod thread, but let's continue here.
Right to the keyboard you can see a rectangular hole, I intend to have an indicator display there, num lock, caps lock, scroll lock, DVD, HDD and power on.
I'll make a construction with a "template" where the text is etched through a coat of black paint and amber leds underneath. When the led is lighted the text will glow.
Inspiration comes from old stereos.
I suppose flat leds will work best but the only good amber versions I've found are surface mounted... how hard are they to solder?
Offline watduzhkstand4
« Reply #30 on: Wed, 13 May 2009, 15:06:56 »
HHKB pro 2 imo is great. I've typed on it before and loved it comparing it to my Lite 2
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline vils
« Reply #31 on: Sun, 19 July 2009, 16:32:51 »
Quote from: vils;90201
I think I've figured out a good way to make the "text indicator window", more on this in the Mod section later on.
Now to aesthetics.
Wich font do you recommend for a 60's industrial look?
The text row will look like this:
Power
HDD
DVD
CapsL
NumL
ScrL
And another thing should all leds be amber or some in different colours?
"Power" green for ex., CapsL in super bright red maybe? I'm open for suggestions.
Specs for case leds are also welcome.
Offline vils
« Reply #32 on: Sun, 19 July 2009, 17:38:36 »
Quote from: ripster;88881
Ripster this might intrest you.
Offline vils
« Reply #33 on: Sun, 19 July 2009, 17:47:41 »
Best font I've found so far is "Alte DIN 1451 Mittelschrift gepraegt"
Offline vils
« Reply #34 on: Sun, 19 July 2009, 20:34:00 »
This slideshow about the demise of the Facit company is quite intresting.
Slide number 76 depicts "my" typewriter.
I still have that little Facit aluminium badge, and will replace it as soon the casing is painted (or propably powder coated).
Both the corona and ibm logos are nice.
Offline vils
« Reply #35 on: Sun, 19 July 2009, 20:55:08 »
Quote from: ripster;103343
Pretty sharp points - depends how modern you want.
Well, the display will be fairly small so the backlit legends have to be quite clean to be readable. And the have to be possible to engrave.
That narrows down the selection to something not to narrow, not to bold and propably sans-serif.
BTW the proposed font is originating from 1906.
Offline vils
« Reply #36 on: Sun, 19 July 2009, 21:12:10 »
Offline vils
« Reply #37 on: Mon, 20 July 2009, 07:05:22 »
Alas I don't have any pics of the typewriter from before the project started so I'm on my way to buy another one:
With hood!
Shipping charges could kill the deal, but I'm hopeful.
Apart from that I'm still want more input on led-colours and font choice.
Offline vils
« Reply #38 on: Sat, 01 August 2009, 19:49:04 »
Some major steps have been taken the last days. I have almost completed the case. The open hole into the typewriter you can see below now have a sturdy roof.
I'll try to take some new pics soon.
Construction and design of this part have been a major headache but now it's solved (aluminium plates, epoxy and hard work).
The activity display is still a mess, but it will be sorted out.
BTW, does anyone kows a good source for small and good looking push buttons? I need one for the dvd-eject and maybe some more for on/off and restart. A turbo button pherhaps? Nahh so 80's
Offline huha
« Reply #39 on: Sat, 01 August 2009, 19:58:15 »
As far as LEDs are concerned: There's only one colour to use: Amber.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline vils
« Reply #40 on: Sat, 01 August 2009, 23:23:52 »
Quote from: huha;106127
-huha
I'm pretty sure I will.
When I looked at the specs for blue cherrys it seemed as they could be used as dvd-eject button. A nice metal key-cap and some glueing.. must find a supplier..
Offline vils
« Reply #41 on: Thu, 06 August 2009, 15:00:19 »
Offline Rajagra
« Reply #42 on: Thu, 06 August 2009, 15:19:29 »
It's looking good. Any plans to put anything inside? You could build a PC inside. Or just use it to store CDs or something. :-)
You could complete the effect by building a TFT into an old microfiche reader maybe.
Offline rdjack21
« Reply #43 on: Thu, 06 August 2009, 15:33:19 »
I have to agree looking good. You could turn it into a web surfer by putting one of those little atom boards in it.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline vils
« Reply #44 on: Thu, 06 August 2009, 15:43:45 »
It have place for a mATX board, regular PSU and everything else for a fully functioning computer and will be my main rig. Propably equipped with 3gHz intel dual core.
A modded TFT could be a nice addition but I'll stick with the standard stuff.
Offline vils
« Reply #45 on: Thu, 06 August 2009, 15:46:03 »
Interior:
Offline lowpoly
« Reply #46 on: Thu, 06 August 2009, 16:00:07 »
Quote from: vils;107578
pics
Wow.
Those flexible LCD screens could simulate the paper:
Offline rdjack21
« Reply #47 on: Thu, 06 August 2009, 16:42:01 »
Quote from: vils;107610
Interior:
Really nice. The more I see the more impressed I am by this. Nice work.
Keyboards
Black Alps: ABS M1
Offline vils
« Reply #48 on: Sat, 08 August 2009, 07:08:39 »
Quote from: ripster;107705
Vils, Very Nice!  The inside was a complete surprise.
Thanks, I'm glad you're suprised... I'm working on it not to ressemble a PC.
I like these case switches a lot.  Feel super high quality like Elevator buttons.  Lots of more retro colors.
Those are nice, but Ireally want something small and discreet.
Here are the old keycaps:
I really want to use them, but I thing I'll pass. The lettering is nice, but nothing matches the modern layout. It would be like using a blank KB but harder....
New and old caps compared:
Some quality differance.
Looks intresting..
Edible?
I took the red one and it tastes good.
On subject again, maybe use the red "erase" button as dvd eject?
« Last Edit: Sat, 08 August 2009, 07:11:22 by vils »
Offline rdjack21
« Reply #49 on: Sat, 08 August 2009, 11:31:27 »
I hate to mention this but if you decide you don't want those keys I would love to have them. But I can understand if you want to keep them.
Keyboards
Black Alps: ABS M1
