Author Topic: How big the difference Das vs Filco MX Brown/Blue?  (Read 1563 times)
Offline simingma
« on: Wed, 13 March 2013, 01:55:05 »
Hey guys,
Had a Das with MX Blues, and KBT Pure MX Brown, to be honest not impressed by both. Since there are so many of you Filco fans, wondering whoever had the chance to use both could tell me if there's any difference and which is better.
Offline WhiteFireDragon
    • youtube
Re: How big the difference Das vs Filco MX Brown/Blue?
« Reply #1 on: Wed, 13 March 2013, 02:28:29 »
What was so not impressive about your Das or Pure? The Das is somewhat similar to Filco, but depends on what aspects you're talking about.
Offline simingma
« Reply #2 on: Wed, 13 March 2013, 02:56:17 »
Feel of the switch. I heard there are differences in a PCB mounted and plated mounted. But just curious if there's any different between two plate mounted (Das and Filco).
    • youtube
« Reply #3 on: Wed, 13 March 2013, 03:23:48 »
My very first decent mechanical KB was a Das. Comparing it to Filco, both have steel plates, so feel differences will be negligible, if any at all. Both are also made by Costar, so you'll probably also be disappointed in Filco. There is nothing Filco or Das can do about the switch though, because it's from Cherry. Your best bet is to try other switches to see if you like those more.
