Author Topic: Keycaps uneven in size  (Read 4208 times)
Offline commando
« on: Thu, 14 March 2013, 21:53:00 »
My keycaps just arrived today and I ordered it from wasdkeyboards. Once I replaced the keycaps, I realized that some of the keycaps were somewhat taller/shorter than others. And yes I they were installed in the correct rows.
Offline Jocelyn
  • 조셀린
Re: Keycaps uneven in size
« Reply #1 on: Thu, 14 March 2013, 21:56:02 »
Keycaps come in different profiles (heights). What kind of keyboard do you have and let us know if the caps are stock or something else.
Edit - Sorry totally misinterpreted that lol, I better finish my coffee :)
« Last Edit: Thu, 14 March 2013, 21:58:07 by Jocelyn »
Offline Michael
  • Formerly Bro Caps
« Reply #2 on: Thu, 14 March 2013, 21:56:08 »
Might want to direct this here: http://geekhack.org/index.php?board=83.0
Offline Amarok
« Reply #3 on: Thu, 14 March 2013, 21:56:42 »
E-mail them and they will fix it if you were sent the wrong keys for certain rows. They have great CS.
Realforce 87u 55g
Offline esoomenona
  • Gnillort?
« Reply #4 on: Fri, 15 March 2013, 09:31:51 »
Make sure you push down on them enough. Sometimes, it seems like you pushed them all the way down and you haven't.
Offline commando
« Reply #5 on: Fri, 15 March 2013, 09:41:36 »
nvm.. turns out i wasnt pressing it hard enough
btw I have a CM Storm QuickFire Rapid for those who are wondering
Offline TotalChaos
  • Indy Game Coder
« Reply #6 on: Wed, 20 March 2013, 11:21:08 »
I put bottom row WASDkeyboards.com keys on the bottom row of my CM Quickfire Rapid and the WASDkeyboards keys were a bit taller when mounted.  I posted a msg about it somewhere.  Search for "Riding Height" and u will find it :)
Offline deSheol
  • Thorpe
« Reply #7 on: Wed, 20 March 2013, 12:35:49 »
this seems to be the case most of the time. i always tilt my head to see if all the keycaps are at the same height  :))
