Author Topic: Where can I buy OEM height PBT keycaps?  (Read 3577 times)
Offline aznsilvrboy
« on: Fri, 15 March 2013, 08:42:18 »
Need full 104 keys for my Filco MJ2 (US ANSI layout). Can someone recommend me which ones are good?
« Last Edit: Fri, 15 March 2013, 08:44:03 by aznsilvrboy »
Offline zoolzoo
Re: Where can I buy OEM height PBT keycaps?
« Reply #1 on: Fri, 15 March 2013, 08:48:17 »
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Fri, 15 March 2013, 08:49:33 »
You could get one of Ducky or Vortex sets from mechanicalkeyboards.
Offline aznsilvrboy
« Reply #3 on: Fri, 15 March 2013, 09:10:34 »
Are KBC ones good quality? What are the advantages and disadvantages of dye sub vs laser etched?
« Last Edit: Fri, 15 March 2013, 09:12:58 by aznsilvrboy »
« Reply #4 on: Fri, 15 March 2013, 09:19:56 »
KBC, Vortex, Ducky... they all come from same factory so it doesn't matter at all really, just some style differences with font and minor detail. Dyesub is more durable and you won't have any rough raised legend with it like can be with laser.
Offline aznsilvrboy
« Reply #5 on: Fri, 15 March 2013, 10:59:43 »
How are dyesubs more durable? I read that laser etched font doesn't wear off either, just gets dirty and need to clean. So far the only black dyesub PBTs I can find are from Vortex, but I don't like the font too much. Are there other alternatives?
Offline esoomenona
  • Gnillort?
« Reply #6 on: Fri, 15 March 2013, 11:01:01 »
I have a set of Gold printed PBT OEM height caps. I just never used them.
Offline Jocelyn
  • 조셀린
« Reply #7 on: Fri, 15 March 2013, 11:02:40 »
I have a very dark gray set of OEM profile PBT blanks that I don't think is from the same factory. I might be selling them soon
« Last Edit: Fri, 15 March 2013, 11:17:01 by Jocelyn »
Offline Lunartuna
  • Good bye money!
« Reply #8 on: Fri, 15 March 2013, 11:05:24 »
It's Laser engraving that doesn't wear off because it is cut into the keycap plastic.
Laser etching can still wear off eventually.
Shine 2 TKL - Choc Mini
« Reply #9 on: Fri, 15 March 2013, 11:10:24 »
When say laser, I don't assume you mean engraved. Typically when talking laser people are talking about this type
which as you can see are not so durable in use over a period.
