Author Topic: I hate Adium  (Read 6948 times)
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
I hate Adium
« on: Mon, 18 February 2008, 13:28:50 »
I hit Apple+w with the contact list (the one that shows the status of your contacts) highlighted and it is impossible to get it back. Everything I try (options in the preferences, menu, menu bar, and dock) does nothing. It's not hidden in Spaces, and the help menu won't open the help viewer. I've tried restarting the program and the computer and that doesn't work.
Does anyone know what I did? Is it gone for good? WTF
Offline xsphat
  • Enlightened
I hate Adium
« Reply #1 on: Mon, 18 February 2008, 13:36:23 »
'm so mad at this I have to go buy a new iPod.
Offline zillidot
I hate Adium
« Reply #2 on: Mon, 18 February 2008, 18:31:03 »
Quote from: xsphat;3084
After reading this I couldn't resist trying it for myself. :) I hit Apple+w and the contact list disappeared. After unsuccessfully poking around in the menus for a while, I clicked on the dock icon and it came back. Not sure what I did there but it seemed to work!
My keyboards:
Realforce 87U (all 55g)
HHKB Pro 2 (black on black)
Filco Majestouch (n-key rollover, brown cherries)
Unicomp Customizer 101 (black with black keys)
Offline xsphat
  • Enlightened
I hate Adium
« Reply #3 on: Mon, 18 February 2008, 18:43:29 »
I think I have a ghost of it in one of my Spaces from when I used to screen span. I have the worst luck on Earth across the boards.
I do feel better that you couldn't find a way to turn it on in the menus either. I'm going to reinstall it and NEVER do that again.
Offline xsphat
  • Enlightened
I hate Adium
« Reply #4 on: Tue, 19 February 2008, 02:01:43 »
I had to move the application to different directory and open it to get his damned window back. This is a good example of my luck.
Offline karlito
    • http://altitudegame.com
I hate Adium
« Reply #5 on: Wed, 20 February 2008, 22:34:20 »
you could always you http://www.pidgin.im/ (used to be called gaim).
But i have a feeling you'll hate it more than adium :(
Offline xsphat
  • Enlightened
I hate Adium
« Reply #6 on: Wed, 20 February 2008, 23:39:11 »
It's fine now that I can use it.
