Author Topic: buggered SDL cable - 5-pin connector mangled - wire in new PS/2?  (Read 2682 times)
Offline hlehmann
Hi,
I received my second M knowing that its 5-pin din connector was shot (looks like a dog has been at it).
Rather than fork out the monies for a new cable can I solder on a PS/2 or do I have to stick to the DIN with a ps/2 converter?
Assuming the five pins map perfectly well to the 6 with some knowhow.
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
Re: buggered SDL cable - 5-pin connector mangled - wire in new PS/2?
« Reply #1 on: Mon, 18 March 2013, 03:20:48 »
AT to PS/2 is passive, so yes you can just solder on a PS/2 plug with "some knowhow".
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline hlehmann
« Reply #2 on: Mon, 18 March 2013, 14:03:09 »
all i need now is the knowhow.
Armed with soldering iron and solder and have a supply of old rubber dome keyboards I can pilfer from :)
Offline The_Ed
« Reply #3 on: Mon, 18 March 2013, 15:52:14 »
If you fail you can always pay for a new SDL cable. The $30 SDL to USB cables from orihalcon are well worth the money. Even his $20 SDL to PS/2 cables are worth it.
R.I.P.ster
