Author Topic: Cherry MY7000 HPBUS White on Black Double Shot Caps Vintage Profile.  (Read 6915 times)
Offline ideus
  • Björkö.
This is the link to the original seller of the keyboard at ebay
http://www.ebay.com/itm/Cherry-MY7000-HPBUS-POS-Credit-Card-Swipe-Keyboard-Black-/400422698537?pt=PCA_Mice_Trackballs&hash=item5d3b0d7e29
I found this keyboard for 9.99 at ebay, I bought only the key caps and the shipment was only 5.5. I think someone has already mention this finding, but I think it worth to refer it one more time. I installed them in a KBC Poker, and its feeling change for the better, the height of the caps is shorter than the original poker's that makes the feeling to be a little bit more responsive like installing an o-ring or hard dampener, other difference is the shape of the F and J keys to place your index fingers, instead of having a bar or dot protruding from the surface they have a deeper curve, that makes them very confortable. It is a shame some of the keys are shinny as a mirror  8) , because the feeling is so great. 16081-0 What can I ask for being only a cheap replacement set. They are double shots so while shiny they will not fade.
« Last Edit: Thu, 21 March 2013, 17:29:37 by ideus »
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Cherry MY7000 HPBUS
« Reply #1 on: Mon, 18 March 2013, 17:11:33 »
I have a $10 Cherry MY7000 HPBUS board that just arrived at home. So I'm happy to hear that the key caps worked out so well!
I see you're still using your default caps for the bottom row, which seem to work nicely. How do you like having the bottom row in a different profile?
Offline ideus
  • Björkö.
« Reply #2 on: Mon, 18 March 2013, 17:56:37 »
The bottom row is a little bit taller of course, but feels nice, also the right shift and the caps lock are the originals. They can be replaced because of size or stems or stabilizers that do not match.
I am waiting for some caps so these ones will be just a back up, but I will keep the F/J and the tilde cap just for fun and comfort.
Please post yours when you install them or use your new keyboard.
Offline laden3
« Reply #3 on: Mon, 18 March 2013, 18:18:42 »
Can you show a picture of the spacebar and the keys larger than 1X (shifts, enter etc.) you harvested from the MY board?
I rrrove brrracks.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #4 on: Mon, 18 March 2013, 18:21:32 »
Can't wait til mine gets here, I got it for donor keys for my poker.
Offline ideus
  • Björkö.
« Reply #5 on: Mon, 18 March 2013, 18:25:44 »
I will take some pics of the key caps tonight. Please be patience I should wait until my family had their quality time :)
Offline ideus
  • Björkö.
« Reply #6 on: Mon, 18 March 2013, 18:27:29 »
Just be aware that modifiers will not fit the Poker, I only managed to have the left shift and the enter key fitting it. Post yours when you get them.
Offline laden3
« Reply #7 on: Mon, 18 March 2013, 18:32:18 »
These keycaps are even better if you have a pure I guess. The spacebar might fit a blackwidow?
I rrrove brrracks.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #8 on: Mon, 18 March 2013, 18:32:39 »
I bought cherry mods that fit, too.
Offline ideus
  • Björkö.
« Reply #9 on: Mon, 18 March 2013, 18:37:37 »
Where did you get them? Are there more available?
Offline ideus
  • Björkö.
« Reply #10 on: Tue, 19 March 2013, 07:52:28 »
Here you are: The pictures of the non 1x key caps that came with the set.16131-016133-1
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #11 on: Tue, 19 March 2013, 13:11:35 »
Talk to tinlong.
Offline SmallFry
« Reply #12 on: Tue, 19 March 2013, 13:23:18 »
Oddly, the spacebar from the MY7000 sets says PBT from the mould. I wonder if Cherry made PBT editions of their boards... ?.?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #13 on: Tue, 19 March 2013, 13:24:59 »
If you might be interested in some colorful also have a look at my groupbuy for modifers sets.
Of course they make PBT, all the lasered key in light color are PBT.
Offline SmallFry
« Reply #14 on: Tue, 19 March 2013, 13:35:08 »
Ah, so if I were to find a black set with lasering, that would be PBT?
« Reply #15 on: Tue, 19 March 2013, 13:36:54 »
No only light color lasered is PBT like light grey, white/biege. Lasered black keys are POM.
Offline SmallFry
« Reply #16 on: Tue, 19 March 2013, 13:37:23 »
Hm. Interesting. Thanks! :)
Offline mashby
    • Mashby
« Reply #17 on: Wed, 20 March 2013, 22:21:11 »
 :-* I think I'm in love.  :-*
The keyboard came in Monday evening. I scrubbed the keys and installed them on Tuesday and have been using them for the past two days. I can see now what all the fuss is about. I really like everything about the Cherry profile and build quality. Now the quest is on to find a caps lock, right shift and modifiers. Until then, the OEM profile keys are working OK.
I posted a photo gallery on Flickr that you can find at this link.
New Keys! by Michael Ashby, on Flickr
« Reply #18 on: Wed, 20 March 2013, 22:27:23 »
I like these keys a lot.
Offline ideus
  • Björkö.
« Reply #19 on: Wed, 20 March 2013, 22:41:24 »
Excellent! The keys profile is awesome, the F/J curves fits the finger tips like charm. Congrats that you get the finding.
Offline ideus
  • Björkö.
Re: Cherry MY7000 HPBUS White on Black Double Shot Caps Vintage Profile.
« Reply #20 on: Wed, 20 March 2013, 23:22:40 »
I have added the link of the original ebay offer:
I just checked and the keyboards are still available at $10, plus shipping. The seller dropped the S&H cost when I explained that I wanted only the caps.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #21 on: Wed, 20 March 2013, 23:25:51 »
I'll be getting mine tomorrow.  Also, talk to tinlong, he may have some more white on black cherry mods.
Offline ideus
  • Björkö.
« Reply #22 on: Wed, 20 March 2013, 23:28:16 »
Well done. Post your set when you get it completed.
« Last Edit: Wed, 20 March 2013, 23:29:48 by ideus »
Offline calavera
« Reply #23 on: Thu, 21 March 2013, 02:32:40 »
Or buy my white on black moogle kit instead. ;)
http://geekhack.org/index.php?topic=40475.0
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #24 on: Thu, 21 March 2013, 12:09:53 »
Oh man, glad I checked, tinlong is sending me 1.5x.  PMed
