Author Topic: CM Trigger LED Color  (Read 8022 times)
Offline SpartanW80
« on: Mon, 18 March 2013, 19:45:36 »
Does Coolermaster have any plans for fitting the LED color to the switch type for the Trigger series? I'd really like to get a Trigger(MX Brown) with white LEDs off of Newegg but all the switches(minus green) use red LEDs.
If not, how difficult and expensive would it be to remove the red LEDs and replace them with white LEDs?
Offline PointyFox
Re: CM Trigger LED Color
« Reply #1 on: Mon, 18 March 2013, 20:52:10 »
I think I heard that they're going to make one with MX green and green LEDs; so probably other colors too.
