Author Topic: Does the CM Storm Quickfire TK have same quality build as Rapid?  (Read 13229 times)
Offline zippox
I hear many good things about starting with a CM Storm Quickfire Rapid for a first mechanical keyboard. I personally would have a tough time without the tenkeys, so does the CM Storm Quickfire TK have the same quality reputation?
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
Re: Does the CM Storm Quickfire TK have same quality build as Rapid?
« Reply #1 on: Tue, 19 March 2013, 11:11:53 »
Yeah, it should.
However, and I hate to sound like a spokesperson around here, but you should take a look at the Ducky full length Pro boards: http://www.duckychannel.com.tw/en/DK9008_G2Pro.html
I have used and seen the TKL QFP and the Ducky feels superior in quality to me. Especially the keys added with a few extra features. So if you are looking for a solid out of the box board, I like the Ducky more. QFP you might want to get their brand free case and better keys which will run you more than the Ducky pro which has it stock. They even have a stock PBT option.
Offline zippox
« Reply #2 on: Tue, 19 March 2013, 11:23:58 »
I actually have been considering the dk9008g2. Though it is a little higher in price. Lowest I could find was 129.99 + 9.00 shipping.
Offline laffindude
« Reply #3 on: Tue, 19 March 2013, 11:32:03 »
Not really. It feel worse than the QFPro.
Offline missalaire
  • Great Finder of Great Finds
« Reply #4 on: Tue, 19 March 2013, 11:38:57 »
The CM Storm Quickfire TK is fine. It's a solid backlit keyboard, I own one myself and it hasn't disappointed. It feels and is slightly lighter than most keyboards but it definitely has a solid build quality to it. I would recommend it if you want a good, solid, more affordably priced backlit keyboard w/ numpad. Just keep in mind if you want to replace the key caps on it, the bottom row is sized oddly so if you want to replace them with a full set, it won't be fully compatible.
Offline Rule16
  • R.I.P. SmallFry
« Reply #5 on: Tue, 19 March 2013, 12:28:04 »
Yes, but remember that its USB only.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline Abacus1234
« Reply #6 on: Tue, 19 March 2013, 15:08:39 »
I am typing on one right now, and it has served me very well. The build quality is quite good. The only thing to consider is that this isn't Costar, it just uses the cherry stabilizers, which is neither a pro nor a con, it's just a difference.
Offline deazncy
« Reply #7 on: Thu, 21 March 2013, 02:54:11 »
Most likely not; the TK is apparently made by iRocks, while the QFR is Costar.
“Do not pray for an easy life, pray for the strength to endure a difficult one” -Bruce Lee
Offline Abacus1234
« Reply #8 on: Thu, 21 March 2013, 03:29:00 »
Or then again you could listen to someone who actually has one. Quality control on these is at least as good as the Rapid, which we all know has had plenty of duds in the past. Never seen amazon take down the TK for high return rates... I have both, and I honestly see no difference in the build quality at all.
Offline missalaire
« Reply #9 on: Thu, 21 March 2013, 06:54:38 »
I don't think Cooler Master has said who the OEM of the TK is so this may or may not be true.
Offline mirage4life
« Reply #10 on: Thu, 21 March 2013, 12:17:49 »
I own both and definitely prefer the QFR's build quality. IMO, only get the TK if you really want backlighting and don't mind a non-costar stabilized board.
Offline Abacus1234
« Reply #11 on: Thu, 21 March 2013, 15:52:54 »
Out of genuine curiosity, where do you feel the TK's quality is lacking?
Offline ledskof
« Reply #12 on: Thu, 21 March 2013, 17:41:02 »
I've only had one Quickfire Rapid so I don't have an extensive history with them but so far I'm considering probably sticking with other brands.  I like how it feels, solid, heavy, etc.  But I had 2 keys fail.  The amazon reviews seem to show a pretty common failure in the Win_L and Alt_L keys.
First off, why are these the only 2 switches on the keyboard that are in this orientation?  And coincidentally, these 2 exact keys stopped working about 1 day apart.  I don't exactly beat the hell out of my keyboard.  I had to jump the connection up the circuit path to get them working.  So I guess there was some kind of etching problem or maybe the keyboard just really took damage at some point before I received it.  Other than this I also have 3 Filcos, 2 Leopolds, and 1 Razer Cherry MX keyboards.  No problems with them except how lame the 2KRO on the Razer is.
« Last Edit: Thu, 21 March 2013, 17:55:10 by ledskof »
Offline deazncy
« Reply #13 on: Thu, 21 March 2013, 18:17:12 »
Sorry if I was misinformed about the OEM, but from doing some research on the TK; it only weighs 1.2 lbs., compared to the QFR's 2.1 lbs. Now although this does not automatically mean that the TK is inferior, I just don't think that the build quality is nearly as good as the QFR.
Offline OnTheBrink
    • Wired In Store
« Reply #14 on: Thu, 21 March 2013, 19:20:30 »
Snip
I also hear that some switches that are supposed to have tactile feedback do not. For example, some Cherry MX Blue switches on a QFR not clicking.
Offline Abacus1234
« Reply #15 on: Thu, 21 March 2013, 19:43:08 »
Once again no specifics are given except that one is lighter than the other. I just think its a kind of bias against boards that are not costar. There is nothing about the TK that feels  anything less than premium.
Offline DeadLamb
« Reply #16 on: Fri, 22 March 2013, 10:39:00 »
nah someone just made an error on the cooler master store page and flipped the numbers around. The Quickfire TK is 2.1 pounds, as in here is mine sitting on a US Postal scale.
I guess no one has gotten around to changing the store page yet..
I've owned a TK for a few months now, I really like it. The only thing that bugs me about the board is I wish the - + and enter key on the far right of the number pad worked when you were in "arrow key" mode and not just when in "number pad" mode.
but that's about it.
Even the funky sci-fi like font has sort of grown on me..
Offline vipjun
« Reply #17 on: Fri, 22 March 2013, 11:01:31 »
different OEM , not sure about quality but kind of think of it as instead of filco it's a leopold.
WTT Realforce 87ub variable for 55G / MX PCB mount
http://geekhack.org/index.php?topic=42360.msg861771#msg861771
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #18 on: Wed, 27 March 2013, 04:06:00 »
I actually owned both for about a week and can say with confidence that I don't think there is much build difference at all. Matter of fact if I didn't know otherwise I would think they were made by the exact same company, fit and finish on both was top notch.
