Author Topic: LED Swap - Magitronic board  (Read 2268 times)
Offline Tarzan
  • formerly known as Greystoke
« on: Tue, 19 March 2013, 11:40:35 »
I'm interested in swapping the stock LEDs used in an older Magistronic board for a different color/shape (the stock ones are kind of tall and wedge-shaped, apparently to best fit the aperture in the top case).
Anything I should be wary of, or is this a fairly straight-forward swap?  I've no idea what the stock LEDs are rated at, I figure I can test the leads with a multimeter and see what voltage is present when the light is lit.
These are the ones I'd like to use as replacements:
http://www.unique-leds.com/index.php?target=products&product_id=1858
Re: LED Swap - Magitronic board
« Reply #1 on: Wed, 20 March 2013, 12:30:17 »
what colour were the stock LED's? If they were blue or green, their VF might be a little higher, and you can look into replacing the resistor. likewise, red LEDs are usually about 1.6V so you might have to change it there.
I notice the replacement LEDs have a VF of ~2V, so they might work as a drop-in
What's best is to check the resistor, and see what current you want through your new LED to see if it needs to be changed
