Author Topic: another keyboard site  (Read 6348 times)
Offline alpslover
« Reply #1 on: Fri, 29 February 2008, 20:34:22 »
Quote from: alpslover;3279
http://209.85.135.104/translate_c?hl=en&u=http://www5f.biglobe.ne.jp/~silencium/keyboard/index.html&prev=/search%3Fq%3Dchicony%2Bkb-9600%26hl%3Den%26client%3Dopera%26rls%3Den%26hs%3DF0G
the force/travel graphs of different keyswitches is very informative.
Sweet.  Should be in the wiki.
« Reply #2 on: Fri, 29 February 2008, 20:40:18 »
It appears that MX blacks have the least travel before activation, and don't require that much force to do so.  Yet people complain about their stiffness.  (I've yet to try one, BTW).
Offline iMav
  • geekhack creator/founder
« Reply #3 on: Fri, 29 February 2008, 22:38:58 »
Quote from: Whiskey in the Jar-o;3280
Knock yourself out!!  (all members have the ability to add content to the wiki)
« Reply #4 on: Fri, 29 February 2008, 23:30:06 »
Quote from: iMav;3284
I'm more of an ideas man myself.
Offline karlito
    • http://altitudegame.com
« Reply #5 on: Fri, 29 February 2008, 23:56:40 »
does anyone have one of those topre realforce 30g keyboards? sounds pretty nice.  is that the one the sell on benippon?
Offline iMav
« Reply #6 on: Sat, 01 March 2008, 09:00:33 »
Quote from: Whiskey in the Jar-o;3285
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
« Reply #7 on: Sat, 01 March 2008, 10:57:47 »
Quote from: iMav;3289
OH my that was funny.  What an idiot!  What I can't believe is how polite all these Venture Capitalists in NYC were to him.  Props to them!
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline ashort
  • Hoosier Daddy
« Reply #8 on: Sat, 01 March 2008, 11:00:43 »
This is very cool.
No wonder the capacitive switches and buckling springs are so popular  They are both ends of the spectrum for tactile keyboards.  Capacitive switches are very smooth with a long "post-activation" curve, and buckling springs obviously have that SNAP in the middle of the stroke, while being incredibly linear on both sides of the buckling.
Everything else is an approximation of one of those two.  I wonder why the other non-linear graphs are so choppy when the capacitive ones are so smooth.
Andrew
Offline alpslover
« Reply #9 on: Sat, 01 March 2008, 15:08:46 »
Quote from: Whiskey in the Jar-o;3281
i think because of the linear force curve and the fact that there's no indication (tactile or aural) of when a keystroke is registered other than a character showing up on the screen, people who aren't used to cherry linears are more likely to try to bottom the keys as they type.  and because the force necessary increases with key travel and ends up being substantially higher than pretty much every other switch past midtravel, they find the keys to be 'stiff' overall, fatiguing to type on, and difficult to get a nice typing rhythm going.  of course, as with anything, they can adapt to it if they really wanted to.
i've typed on keyboards with linear switches before, just not cherrys in particular.  i can't say i liked them as much as tactile switches.
Offline alpslover
« Reply #10 on: Sat, 01 March 2008, 15:29:54 »
Quote from: ashort;3292
there are clicky capacitive keyboards - the original ibm pc and at keyboards use buckling spring actuators with capacitive switches.  it's not so much the switch technology itself that determines the feel of the keys, it's the mechanisms by which the switches are activated that you feel as you type.
Offline bhtooefr
    • bhtooefr.org
« Reply #11 on: Sat, 01 March 2008, 15:35:02 »
That said, I've heard the Model F and the AT keyboards described as "clickier and more solid than a Model M."
Offline alpslover
« Reply #12 on: Sat, 01 March 2008, 15:44:13 »
Quote from: bhtooefr;3311
they are.  the springs feel like they collapse harder and the keys smack bottom harder.  definitely not to everybody's preference, and many people find they type slower on them.
Offline fkeidjn
« Reply #13 on: Sat, 01 March 2008, 18:16:15 »
Really?  When I type on my 84-key AT keyboards, the springs feel more pleasant than the 101-key model M, although the bottoming out hurts my fingers when I type with the weight of my fingers and not simply finger strength.
Kinesis Keypad - Filco FKBN104M/EB - Unitek space-saver - Acer 6511-TW - Apple Extended II (M3501) - Scorpius M10 - Cherry G80-1800, AT - SGI Granite - vintage Fujitsu - IBM Model M, 101 and mini - Model F, 84-key AT - Dell AT101W - Northgate 101
Offline Nonmouse
« Reply #14 on: Sat, 01 March 2008, 20:15:43 »
This is very cool.
His test rig is not very accurate.  If I understand correctly, he has a scale with supposed accuracy of +/- 2g, and he moves the probe down some arbitrary distance, reads the total weight (of the keyboard plus the weight pressing the key down), moves the probe some more, etc.  I'm kind of surprised that he got anything that even looks like a force graph.  A force gauge would really be needed to get any data I'd rely on.
A cheaper, and possibly precise enough method, would be to get a high accuracy scale, like this (+/- 0.01g, it claims), set it on a stand that can be moved upwards very precisely, with a rod on the pan connected to a cam that pushes another rod down onto the keycap.  The force required to move the rods and cam could be determined by running it with no key under the final rod, and compensated for.  (If it's properly engineered, this force should be pretty minimal)
Something like this:
(Yeah, I know, very crude drawing.)
Scale on the left, key on the right.  The cam can freely turn, and the rods are hinged where they connect to the cam.
Offline fkeidjn
« Reply #15 on: Sat, 01 March 2008, 20:34:07 »
Wouldn't it be better to survey and have the people say which keyswitches should rank low force to high force in their relative order?
Offline Nonmouse
« Reply #16 on: Sat, 01 March 2008, 21:03:14 »
Quote from: fkeidjn;3326
No.  Any number of other factors can influence people's impressions of how much force is required- the angle of the key, the height of the keyboard, the size, shape, spacing and placement of the keys, etc.  With actual force diagrams, you can at least have an idea of whether or not you're going to like a keyboard, based on what keyboards you already like.
