Author Topic: A few questions... M13 vs. EnduraPro  (Read 9074 times)
Offline bhtooefr
    • bhtooefr.org
« on: Sat, 01 March 2008, 13:51:16 »
Let's start with the big one... I've read in multiple places that Unicomp isn't using a true TrackPoint mechanism, but rather a mechanism of their own development, for the pointing stick on the EnduraPro. True or not?
(If that isn't true, and it's a real TrackPoint II in there, then there aren't any true dealbreakers on the EnduraPro...)
Now, next question... I've read in some places that it's possible to call Unicomp and request a black/black model, rather than the black/silver or white/white model available on the Unicomp site. True? I'd prefer an all-black board, and that might sway me to the M13 if I can't get the EnduraPro in black/black. (I've already ordered a white M13 that'll probably end up being used at work.)
In the EnduraPro's favor, it's in the Unicomp SpaceSaver chassis, and it's 104-key (which will make using it with my Mac easier - remapping for 101-key is slightly annoying.) Oh, and built-in USB.
Offline iMav
  • geekhack creator/founder
« Reply #1 on: Sat, 01 March 2008, 14:09:39 »
Quote from: bhtooefr;3298
I suggest you give them a call.  Jim Owens from Unicomp should be able to set you straight.
Offline bhtooefr
    • bhtooefr.org
« Reply #2 on: Sat, 01 March 2008, 14:27:36 »
Well, I know you have an EnduraPro 104... so I'll go ahead and ask you... how does it compare to the TrackPoints in ThinkPads? I believe it doesn't have the negative intertia feature (but the M13 doesn't have that, either,) and I know it doesn't have the middle button (again, something the M13 also doesn't have,) but other than that? (And, seeing as it'll mainly get used on my Mac, even two buttons would be nice. :))
Offline fkeidjn
« Reply #3 on: Sat, 01 March 2008, 18:19:32 »
This page should answer your question about the Unicomp trackpoint vs the IBM trackpoint.
Kinesis Keypad - Filco FKBN104M/EB - Unitek space-saver - Acer 6511-TW - Apple Extended II (M3501) - Scorpius M10 - Cherry G80-1800, AT - SGI Granite - vintage Fujitsu - IBM Model M, 101 and mini - Model F, 84-key AT - Dell AT101W - Northgate 101
Offline bhtooefr
    • bhtooefr.org
« Reply #4 on: Sat, 01 March 2008, 18:26:02 »
OK, so then... how are they different in actual usage? Because, if they're not noticeably different, then it'll be no big deal.
Then again, part of me just wants to get a Unicomp board to see how they are, so maybe I'll do that - white M13 (if the place ever ships it... at least they haven't taken my money yet, either,) black (hopefully all-black, but...) EnduraPro...
Offline fkeidjn
« Reply #5 on: Sat, 01 March 2008, 19:59:27 »
Here's another article that talks about the Unicomp trackpoint.  I haven't tried the Unicomp trackpoint, yet.
Offline bhtooefr
    • bhtooefr.org
« Reply #6 on: Sat, 01 March 2008, 20:23:05 »
Hrm... wigglier...
I guess, worst case, I blow $99, and I have another clicky keyboard with a red dot in the middle. I will have a real M13, after all... (and if this place never ships my white one out, I'll get a black one, and then have a black M13 AND an EnduraPro! Muahahaha!)
Offline iMav
« Reply #7 on: Sat, 01 March 2008, 20:44:15 »
Quote from: bhtooefr;3325
Hrm... wigglier...
I wouldn't say wigglier.  There is noticeably more play in the trackpoint on the EnduraPro.  Or, rather, it simply travels more than an actual trackpoint.  It's not loose at all and is very responsive.  I have no complaints...however, I also haven't used mine on a consistent basis.
If the Mighty Mouse replacement is as portable as I hope it will be, I will likely use one of them quite a bit.
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #8 on: Sat, 01 March 2008, 22:58:37 »
Quote from: iMav;3329
That will be the first Track Point I've ever used.
Offline iMav
« Reply #9 on: Sun, 02 March 2008, 11:56:15 »
Quote from: xsphat;3332
What a sad, sad life you live.
Seriously, I figured since you weren't in to the trackpoints that you'd simply buy one without a trackpoint.  (that is assuming, of course, that the new board will be available with and without...just like the Mighty Mouse was)
Offline bhtooefr
    • bhtooefr.org
« Reply #10 on: Sun, 02 March 2008, 12:20:48 »
Well, even if you hate TrackPoints (which, based on what I've seen my coworkers do when presented with X61 Tablets with no touchpad, is usually because you sit there flicking at it, rather than using it properly... ;)) It's still useful to have SOME variety of a pointing device, so if you don't have room for a mouse...
Anyway, I made up my mind... I checked my bank account, and the white M13 has shipped (because they charged my card, finally.) So, it'll be the EnduraPro - even if I can't get it in black/black.
Expect a comparison review once I get my hands on both.
Offline xsphat
  • Enlightened
« Reply #11 on: Sun, 02 March 2008, 12:48:09 »
I never said I didn't like them, I just haven't used one yet. I'm open to them and I think they are a good form factor.
Offline iMav
« Reply #12 on: Sun, 02 March 2008, 13:34:51 »
Quote from: bhtooefr;3346
I bought my X60s SPECIFICALLY because it didn't have a touchpad.  At the time, form factor wasn't really a concern...so I narrowed my choice down to either the X series or the R series (econo-line without the touchpad).  I also own a T23 (which is, also, touchpad-less).
As far as I'm concerned, it's not a true thinkpad unless it sells out to the trackpoint.  :)
Offline bhtooefr
    • bhtooefr.org
« Reply #13 on: Sun, 02 March 2008, 16:10:16 »
You do realize that you can call Lenovo and request that they install the touchpad-delete palmrest, right?
Or, you can order that palmrest after the fact...
Offline iMav
« Reply #14 on: Sun, 02 March 2008, 18:48:00 »
I've seen them available for sale, yes.
Which is entirely unnecessary since all the Thinkpads I own are touchpad-less.  :)
I might consider that if I find myself fancying a new T-series in the future though.
Offline xsphat
  • Enlightened
« Reply #15 on: Sun, 02 March 2008, 23:09:29 »
does anyone make a stand alone USB trackpoint device and if not, why not? I'd buy one.
Offline iMav
« Reply #16 on: Mon, 03 March 2008, 04:53:49 »
Quote from: xsphat;3370
Without the keyboard, the whole point of the trackpoint is lost.  The idea is to allow yourself to keep your fingers on the keyboard.  A standalone trackpoint, IMO, would be ridiculous.
Offline bhtooefr
    • bhtooefr.org
« Reply #17 on: Mon, 03 March 2008, 05:40:27 »
Not that IBM hasn't done that before, of course.
(Then again, I guess it isn't TECHNICALLY a TrackPoint - the pointing device is still the mouse, but there is a TrackPoint (early ones actually had a TrackPoint tip, even, but they changed it to a different design tip on the latest ones) on board that behaves like the Internet Scroll Bar on ThinkPads.)
Offline Mikecase00
    • http://www.mikecase.net
« Reply #18 on: Mon, 03 March 2008, 13:50:57 »
Good luck with getting a board with black keys from Unicomp.  When I called and asked for either a full keyboard with black keys, or just black replacement keycaps for a Model M I was informed they don't make them anymore.  Apparently they are quite a bit more expensive to manufacture than white or silver keys with black text when done properly (so the text doesn't rub off easily).
I own two black M-13s, although one has a broken trackpoint so I used it for parts in making the black 1391401 pictured in my avatar (it supplied the black keys, black/silver IBM logo, and darker Num/Caps/Scroll light cover).  I used the other functional one for a while but never quite got used to typing with the trackpoint sticking up.  I can say that it felt quite similar to the trackpoint on a modern Thinkpad, except for the issues you mention above.
I will say that every M-13 I've typed on had key action that was just slightly less precise than the average IBM built Model M I've used.
IBM Model M 1391401 (dyed black) w/ keys from M-13
IBM M-13 Trackpoint (naturally black)
IBM Model M 1392934 SpaceSaver
Several plain IBM 1391401 Ms
Epson Equity Q203A
Offline bhtooefr
    • bhtooefr.org
« Reply #19 on: Mon, 03 March 2008, 16:16:36 »
Quote from: Mikecase00;3387
Ah. In that case, I'll just go ahead and order the black/silver one...
Offline zillidot
« Reply #20 on: Mon, 03 March 2008, 17:52:59 »
They used to sell them! I have a black Customizer 101 with black keys, which I bought back in 2003. :)
Some of the white lettering on the keys have partially worn off, so I can understand why they don't want to make them anymore.
My keyboards:
Realforce 87U (all 55g)
HHKB Pro 2 (black on black)
Filco Majestouch (n-key rollover, brown cherries)
Unicomp Customizer 101 (black with black keys)
Offline bhtooefr
    • bhtooefr.org
« Reply #21 on: Mon, 03 March 2008, 19:11:31 »
My guess is they sold them for as long as they had stocks of the black caps.
I guess they only had to keep stocks until the last all-black boards were 18 months old, and therefore out of warranty...
« Reply #22 on: Mon, 03 March 2008, 21:04:30 »
Something similar.
