Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2298014 times)
Re: GH60 Group Buy (PRODUCTION FOR REAL)
« Reply #3550 on: Fri, 30 May 2014, 09:53:19 »
Did the PCB's ever make it to TJ? How about the plates?
Would the organizers consider shipping orders that don't require assembly or stabilizers when the parts arrive versus waiting on everything to be together etc?
Offline domoaligato
« Reply #3551 on: Fri, 30 May 2014, 13:43:11 »
Are the majority of the impossible to find stabilizer'd cherry pcb mount?
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #3552 on: Fri, 30 May 2014, 13:45:02 »
I guess since you can buy costars at wasd, but you can buy mx stabs at imsto and gon for example! :O
Offline T0ken
« Reply #3553 on: Fri, 30 May 2014, 19:56:23 »
It seems that Gon will have more Cherry PCB mount stabs next month:
http://www.gonskeyboardworks.com/stabilizers/18-pcb-mount-stabilizers.html
If stabs are going to lock the group buy up I'd rather they just ship the PCB and components, I'd rather just source the stabs for myself.
« Last Edit: Fri, 30 May 2014, 19:58:21 by T0ken »
Offline domoaligato
« Reply #3554 on: Fri, 30 May 2014, 19:58:30 »
What I was thinking was that maybe imsto or gon could help us source stabs for the whole gb. If not them then maybe some friendly people from otd.kr ?
Offline feizor
« Reply #3555 on: Fri, 30 May 2014, 20:02:46 »
Any chance of getting in on this? Extras perhaps?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3556 on: Fri, 30 May 2014, 20:06:50 »
I just want my PCBs...
please tell me you guys aren't waiting for everything before shipping out anything.
Offline codyeatworld
« Reply #3557 on: Fri, 30 May 2014, 20:06:53 »
I posted this a while back but it got buried I guess...
I've spoken with GON since and he said he could match the price in the OP for the cherry stabs only iirc. Not sure exactly how many we need though.
Just so no one gets their hopes up prematurely, please realize that ordering stabilizers was one of the responsibilities we "inherited" from WFD. As far as I know, WFD never ordered the stabilizers, and doesn't have any currently. And we are having a slight problem in sourcing them, as everyone seems to be out of stock. If anyone has a source of available stabilizers, please let us know.
GON told me he thinks he can supply the cherry stabs sets, but not the costar.
Offline domoaligato
« Reply #3558 on: Fri, 30 May 2014, 20:45:39 »
So I decided to try to do the math of how many stabilizers we would need and tried to add all this up from the spreadsheet in the OP...
This is not exact because some people did not specify exactly which stabs they wanted. In this case I choose for them and choose cherry PCB stabs because they are the most flexible with the universal plates. I also did not factor in the space bar wires that people wanted. but that is just bending the wire to size and not the actual stab kits themselves. I know that some people took over other peoples orders so that may also throw this off as well.
Cherry PCB stabs = 121
Cherry Plate stabs = 147
Costar stabs = 77
Offline GeorgeK
« Reply #3559 on: Sat, 31 May 2014, 02:20:49 »
Me too (well PCBs + plate but nothing else)
Offline skrotnisse
« Reply #3560 on: Sat, 31 May 2014, 03:09:13 »
Loled
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #3561 on: Sat, 31 May 2014, 13:25:10 »
mouser has them in stock, they don't look overly expensive...
Offline domoaligato
« Reply #3562 on: Sat, 31 May 2014, 14:05:23 »
Link?
« Reply #3563 on: Sat, 31 May 2014, 14:11:41 »
I'm pretty sure gon only can do the PCB stabs, I'll ask him about the wire sizes too next time I speak to him.
Does mouser have the plate mount stabs?
Offline domoaligato
« Reply #3564 on: Sat, 31 May 2014, 16:30:43 »
from what I have seen looking around between gon and imsto they might be able to do the cherry stabs. costar is really the problem.
edit: imsto also has cherry pcb stabs....
« Last Edit: Sat, 31 May 2014, 16:36:16 by domoaligato »
Offline n0rvig
« Reply #3565 on: Sun, 01 June 2014, 00:58:29 »
It would be great if we could get thick wires for the stabilizers. They seem to rattle less. For example, Imsto's version of cherry PCB mount have great wires.
Offline nebo
« Reply #3567 on: Sun, 01 June 2014, 09:37:19 »
Where are we for cases on this? I know they're not a part of this GB but from what I've dug up most people are making buys for poker like plastic shells. Kind of a bummer if you want a not full key layout.
Offline BlueBär
« Reply #3568 on: Sun, 01 June 2014, 09:41:44 »
GBs for plastic shells? Most are metal and there's one or two acrylic ones, but I've not seen a GB for plastic ones.
Offline Broadmonkey
« Reply #3569 on: Sun, 01 June 2014, 10:03:56 »
Tinlong had such a buy at one time, but I can't remember if it was before or after the start of the GH60 gb. also I think it was canceled, but he sold some in the classified, along with KBT Pure PCBs.
Offline nebo
« Reply #3570 on: Sun, 01 June 2014, 10:41:29 »
I just found the alu ones, but they're all just shells. Might have to get creative.
Offline pix3l_fodder
« Reply #3571 on: Sun, 01 June 2014, 10:48:30 »
Pexon has a GB for an ALU case thats dead cheap ($60), i think he has a few left over!
Offline nebo
« Reply #3572 on: Sun, 01 June 2014, 10:50:26 »
It's not the getting of a case, it's that I was either doing winkesless or HHKB style. Neither of which a lot of people want so there are no buys for them.
Offline mauri
« Reply #3573 on: Sun, 01 June 2014, 11:18:36 »
GON had a small hhkb/winkeyless case groupbuy, but it was pretty expensive and past deadline already.
I AM BABAR KING OF THE ELEPHANTS
« Reply #3574 on: Sun, 01 June 2014, 12:56:42 »
I think the most simple way is use a tray type case that's already available, then have thin piece of whatever material you like lasered out with the 'missing' key blocks in. I think there is enough bezel that you could epoxy a top on that takes care of aesthetics without needing to spend a fortune.
Offline WhiteFireDragon
    • youtube
« Reply #3576 on: Tue, 03 June 2014, 07:44:18 »
RL issues have been really unforgiving, which was why I couldn't fulfill my part of this GB. It shames me to see that my slack was picked up by JD, komar, tj, and some new guys that have stepped up.
I've had most of the stabilizers since last year, including cherries and costars. I just need to get a count on how many I ordered. The custom wires were to be ordered through a company, but I will have to get in contact with them again.
Whatever loose ends are left, I promise to get them done. But I still need to get catch up where this GB currently is at, as well as the rest of the forum status. I have involvement in a few other projects as well.
Offline LechnerDE
« Reply #3577 on: Tue, 03 June 2014, 07:55:41 »
Thanks for giving us a status update WFD!
But at this point I am not really sure whether the stabilizer situation is actually a problem anymore.
But of course JD, Komar and TJ have better insights :)
« Reply #3578 on: Tue, 03 June 2014, 08:20:38 »
Okay guys, so a status update:
The PCBs have been produced and the US/Canada part is being shipped to tjcaustin. imsto's package is on its way too, directly from China.
As far as plates go. I still have to pick them up and get them to TJ in TX. After that, I wash my hands of it all!
Hopefully everything else falls into place from here.
Any update on either of these?
Offline BlueBär
« Reply #3579 on: Tue, 03 June 2014, 08:28:56 »
Assembly needs to be done for most boards I think (resitors, the controller, etc.). This will take some time.
« Reply #3580 on: Tue, 03 June 2014, 08:40:04 »
I thought all that stuff (diodes, controller, resitors) was factory done with pick and place? That the assembly was just switches, plates, stabilizers etc.
Offline BlueBär
« Reply #3581 on: Tue, 03 June 2014, 09:36:30 »
Hmm not sure.
Offline whiskytango
  • Don't touch the trim
« Reply #3582 on: Tue, 03 June 2014, 09:39:41 »
From the OP:
 Assembly
 The PCBs will come with all SMD preassembled, including diodes. Switches and LEDs will require your own soldering. If you’re brave and want to do the SMD soldering yourself, PCB and a bag of SMT components will be cheaper. There will be options for assembly service if you cannot build it yourself.
Offline BlueBär
« Reply #3583 on: Tue, 03 June 2014, 09:44:39 »
That doesn't say if the SMD soldering is done by the factory or not though.
Offline domoaligato
« Reply #3584 on: Tue, 03 June 2014, 10:01:45 »
Following this project from the beginning like so many of us. This was supposed to be smd pick and placed all along.
Offline whiskytango
Re: GH60 Group Buy
« Reply #3585 on: Tue, 03 June 2014, 10:11:13 »
Ok then, maybe this quote is specific enough:
There are more DIY PCB kits ordered than I thought. I know price is attractive, but I want you to make sure you know exactly what you're getting into when getting a DIY kit. This is not your typical soldering of large through-hole switch pins. All the SMD components are provided, but you'll have to solder them on yourself. The pre-soldered boards have all the SMD done at the factory by a pick-and-place machine.
Offline BlueBär
« Reply #3586 on: Tue, 03 June 2014, 10:16:31 »
Ah right, thank you :)
Offline domoaligato
« Reply #3587 on: Tue, 03 June 2014, 10:26:28 »
BlueBär, have you let the church of halverson into your heart?   :))
« Reply #3588 on: Tue, 03 June 2014, 10:27:10 »
Any updates on this, where do we stand regarding
- PCBs
- Switches
- Stabilizers
- Plates
The project has been going well but since one of the leads went MIA its all been a bit in the air. I have no idea of what the time scale is for delivery? Unless I missed a post?
Offline domoaligato
« Reply #3589 on: Tue, 03 June 2014, 10:31:18 »
Reread the op please.
Offline BlueBär
« Reply #3590 on: Tue, 03 June 2014, 10:39:22 »
Maybe I should!
« Reply #3591 on: Tue, 03 June 2014, 11:08:08 »
not sure its relevant still, the PCB have been in production for months and i believe the plates also have been received?
Offline tricheboars
  • Keyboards are Important!
« Reply #3592 on: Tue, 03 June 2014, 11:09:20 »
good to hear from you WFD.  that is good news about the stabs. as it seems many places that normally sell them have been sold out recently.
thank you very much for returning. please hangout with us more if you can!
« Reply #3593 on: Tue, 03 June 2014, 11:23:37 »
Those are the latest updates I have seen besides WFD's comment today about him having some stabs.
Offline Dubsgalore
« Reply #3594 on: Tue, 03 June 2014, 21:55:48 »
Thank you based god  :'( :'(
Offline 7bit
  • MX1A-G1DW
« Reply #3595 on: Wed, 04 June 2014, 02:00:53 »
Quote from: OP
PCBs: In production
Plates: In production
Switches: On hand
Stabilizers: Looking for source...
Assembly: to be completed by tjcaustin and komar007 once all components are received
Shipping: Not started
:cry:
Any way you can send switches and other stuff to people who only ordered these?
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline BlueBär
« Reply #3596 on: Wed, 04 June 2014, 05:26:48 »
:cry:
This was asked a few times already, I don't think this will be done because it would probably result in chaos.
Offline tgujay
« Reply #3597 on: Wed, 04 June 2014, 06:41:39 »
:cry:
If that's chaos what the hell do you call the cluster**** this GB has been the whole time?
Gotta collect them all
Offline Qipz
« Reply #3598 on: Wed, 04 June 2014, 06:48:37 »
If you look at the scale of this project, places items come from, the amount of people who we are dependent on and those are doing it in their free time I'd say it's still on track mostly.
Offline iAmAhab
  • Established member
« Reply #3599 on: Wed, 04 June 2014, 06:57:52 »
I'm with qipz on this one. You have to remember that this is not a commercial buy.
