Author Topic: GH60 Group Buy (Salvage Mode: Enabled - Update in OP)  (Read 2333756 times)
0 Members and 7 Guests are viewing this topic.
Offline BunnyLake
  • The OG HHKB Master
  • X
Re: GH60 Group Buy (WAITING FOR ???)
« Reply #5000 on: Wed, 15 July 2015, 17:59:04 »
Does the new spreadsheet include orders that were taken over?
I took one over in addition to my original order.
from what im told, we worked form the most up to date sheet
that being said, again ill be confirming everything as i go through, so if anything like that comes up, we will be able to catch it
« Reply #5001 on: Wed, 15 July 2015, 20:24:55 »
Just wait for round 2 to start
There you go, Demik. Being Demik. Now I understand the hype.
Hey, everyone, it's Demik!
demik*
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #5002 on: Thu, 16 July 2015, 06:44:52 »
can you fū*!&g believe it?!
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #5003 on: Thu, 16 July 2015, 06:49:28 »
Mad jelly
Offline BlueBär
« Reply #5004 on: Thu, 16 July 2015, 07:54:31 »
No. You must have pretty good Photoshop skills.
Offline BunnyLake
  • X
« Reply #5005 on: Thu, 16 July 2015, 07:57:20 »
you shall see lots more showing up soon, a good amount are going out tomorrow
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #5006 on: Thu, 16 July 2015, 08:58:00 »
Offline Prelim
« Reply #5007 on: Thu, 16 July 2015, 09:04:42 »
can someone explain me what the "expansion module", "poker arrows" and "WASD" little holes (is that even in the right place) are for? soz for the noobieness  :-[
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
Offline azhdar
  • Praise the AZERTY god
« Reply #5008 on: Thu, 16 July 2015, 09:08:48 »
Explaination for poker arrows, the poker X had the arrows keys in that position :
http://i.imgur.com/IUxeH.jpg
Not idea about the rest.
Azerty Propagandiste
Offline Prelim
« Reply #5009 on: Thu, 16 July 2015, 09:10:48 »
lol, I understood the positions of course... I don't know is what the little holes are for, to solder resistances?!
Offline Dsan
« Reply #5010 on: Thu, 16 July 2015, 10:12:31 »
When I placed my order 2 years ago I was planning on soldering the board myself but now I'm not sure I can..
Would it be too much trouble to have it assembled?Of course I would pay for that on top of the donation to get all of this sorted.
Also,in case that's not possible,since I also have to receive the Toxic keyset if you want to save the GB's shipping money Bunny,you can combine the two orders :)
Thank you guys for all the hard work!
Offline jorgenslee
« Reply #5011 on: Thu, 16 July 2015, 10:14:21 »
Is this the real life?
« Reply #5012 on: Thu, 16 July 2015, 11:28:42 »
Those should be for resistors, correct (since those are the positions that support LEDs).
Offline Prelim
« Reply #5013 on: Thu, 16 July 2015, 11:41:05 »
thanks Hoff,
but isn't the entire pcb compatible with leds on an individual switch level?! soz if it's a dumb question :/
« Reply #5014 on: Thu, 16 July 2015, 11:45:51 »
thanks Hoff,
The exact details are escaping my mind right now, but IIRC it's not wired for full-LED without the LED expansion module.  The expansion module adds either hardware (controller) or something similar to accommodate.  But as I said, this is *not* official information and is from memory (a 2 year old memory, at that :P ).  Someone please correct or confirm!  :)
Offline DanielT
« Reply #5015 on: Thu, 16 July 2015, 12:11:25 »
Damn this is for real !!!! I wanted a GH60 since I started with the keyboards stuff, I have to get my hands on one PCB :) My 60% collection wouldn't be complete without a GH60 .
Offline DanielT
« Reply #5016 on: Thu, 16 July 2015, 12:16:32 »
To make it short I'm interested in one PCB ;) when these will start to arrive. I dream to have a board with a special layout I saw only once on Ivan's GH60 :)
Offline esoomenona
  • Gnillort?
« Reply #5017 on: Thu, 16 July 2015, 13:23:27 »
« Last Edit: Wed, 12 August 2015, 08:24:13 by esoomenona »
Offline AKmalamute
  • HHKB Scrub
« Reply #5018 on: Thu, 16 July 2015, 13:49:39 »
The PCB has holes [...] It will be up to the user to determine a workaround to get all other LEDs working.
Whoa, whoa, whoa. You're telling me this board isn't done?!?
I think this calls for a complete overhaul of the entire concept! Re-do the board, everything!
Don't you all agree?
HHKB-lite2, Dvorak user
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #5019 on: Thu, 16 July 2015, 13:51:09 »
I quickly assembled a GH60 keyboard to verify the that PCBs are actually working.
Here I present to you my first GH60 keyboard with a prezzy crazy layout (that's what custom keyboards are for, right?)
I found that the pads are a bit harder to solder than I'm used to, but nothing too bad. Probably the 2 yo PCBs started to oxidate, but anyway it is working. I'll make some more tests, but I believe it's a go.
I'm said shipping will start tomorrow.
Offline esoomenona
  • Gnillort?
« Reply #5020 on: Thu, 16 July 2015, 13:53:58 »
« Last Edit: Wed, 12 August 2015, 08:23:30 by esoomenona »
Offline AKmalamute
  • HHKB Scrub
« Reply #5021 on: Thu, 16 July 2015, 13:56:56 »
But yes, let's burn all the PCBs, and start from scratch.
<cracks open an ice cold can of STFU, and takes a sip>
Offline Prelim
« Reply #5022 on: Thu, 16 July 2015, 14:12:23 »
/starting engines for rev.D GB! "dedicated to the memory of GH60 rev.C"  :)) :))
Offline Wildcard
  • When caffeine isn't enough
« Reply #5023 on: Thu, 16 July 2015, 15:10:39 »
/ROFL
« Reply #5024 on: Thu, 16 July 2015, 15:55:06 »
Anyone one have an extra PCB for sale? Please contact me. Thank you!
****ING CALLED IT
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #5025 on: Fri, 17 July 2015, 03:33:18 »
I tried to burn a new firmware and make same changes to hasu's code. Everything's working properly. Go ahead. Realese the Kraken!
« Last Edit: Fri, 17 July 2015, 03:35:51 by Matt3o »
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #5026 on: Fri, 17 July 2015, 04:45:01 »
How hard is it to solder the controller with the oxidized pads
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #5027 on: Fri, 17 July 2015, 05:04:53 »
clean the board with isopropyl alcohol, splash some liquid flux and you are good to go. they are just a pinch harder to solder than I'm used to. Lead doesn't flow as well as I would expect, but totally feasible.
Offline pexon
    • Pexon PCs
« Reply #5028 on: Fri, 17 July 2015, 05:14:23 »
OK, cool, cheers Matt. I think maybe I should have gotten the pre-built, as time is a little more sparse than it was when I ordered it. I will set a few hours aside one of the evenings to do it, should be easy as long as the solder takes then
Offline BunnyLake
  • X
« Reply #5029 on: Fri, 17 July 2015, 08:49:37 »
sent the first batch of orders out today
this sunday ive set aside some time to split the remaining orders in to batches, once i have done that ill post them here, and then starting contacting users in each batch 1 by 1
« Reply #5030 on: Fri, 17 July 2015, 08:50:48 »
 :eek: :eek: :eek: :eek: :eek:
It's happening!
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5031 on: Fri, 17 July 2015, 09:15:41 »
I didn't realize I was soldering on the controller. This will be fun. :)
Good think I have been practicing my smd work recently.
Offline esoomenona
  • Gnillort?
« Reply #5032 on: Fri, 17 July 2015, 10:05:13 »
« Last Edit: Wed, 12 August 2015, 08:21:53 by esoomenona »
Offline domoaligato
« Reply #5033 on: Fri, 17 July 2015, 10:12:48 »
the expansion board that komar007 was working on should allow the usage of all the leds.
the pcb board is complete based on the goals of the project originally.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5034 on: Fri, 17 July 2015, 11:43:37 »
You won't be, I imagine. A very small number of people ordered raw PCBs to solder things together on their own. Everyone else will have a PCB with all SMD soldering already done.
One of the boards I got was a DIY board, so I expect I will probably have to do all the smd work on it...
Offline thegagne
« Reply #5035 on: Fri, 17 July 2015, 11:53:17 »
Looked back a few pages, maybe we can just bump the status of the US orders?
Something about ApocalypseMaow taking them over... maybe we can expect to receive in the next couple months?
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #5036 on: Fri, 17 July 2015, 12:41:55 »
GH60 and R5 both rumbling to life and moving toward completion... what a time to be alive!  :))
Offline pix3l_fodder
« Reply #5037 on: Fri, 17 July 2015, 13:50:55 »
I wouldn't expect any modules, and I do hope the software is polished to buggery as its been sometime since this all started!
Offline Hzza
« Reply #5038 on: Sat, 18 July 2015, 05:56:05 »
Good post day today, GH60 pcbs :D.
Thanks all, so super happy right now.
Offline DanielT
« Reply #5039 on: Sat, 18 July 2015, 09:00:35 »
Nice :) I must get one of these ! :)
Offline Hzza
« Reply #5040 on: Sat, 18 July 2015, 10:30:58 »
One down, next up is the funky bottom row version :D.
Offline wlhlm
« Reply #5041 on: Sat, 18 July 2015, 10:33:21 »
Interesting build!
Are those tactile Greys?
Offline Hzza
« Reply #5042 on: Sat, 18 July 2015, 13:10:42 »
Nixdorf blacks, with a clicky clear Esc and locking switch in the space to the right of the right shift.
« Reply #5043 on: Sat, 18 July 2015, 13:12:38 »
Which caps are you planning to put on there?
It's been so long. I've actually forgotten what I had planned for mine now. I seem to remember wanting to do an ISO board with SAG caps.
« Last Edit: Sat, 18 July 2015, 13:16:40 by Photekq »
Offline Prelim
« Reply #5044 on: Sat, 18 July 2015, 13:27:46 »
 :eek: :eek: wow @Hzza, fantastic those nixdorfs, that's what I wanted to do as well... don't even know if I'll be able to get vintage blacks to built my GH60.
is that a clear stem on spacebar?! DONT  :mad:
« Last Edit: Sat, 18 July 2015, 13:38:34 by Prelim »
« Reply #5045 on: Sat, 18 July 2015, 13:45:09 »
I'd guess it's a linear MX white ;)
Offline Hzza
« Reply #5046 on: Sat, 18 July 2015, 14:28:18 »
Indeed, the spacebar is a linear white. I've got WoB doubleshots that I could put on it, or even BoW...I'll probably be chucking the caps from my FaceU on it so it'll look basically like this.
With a bit of luck I'll get it programmed tonight and should be up and running by tomorrow :D.
edit - I had to tweak TMK a little to get an ISO keymap working, see below for keymap and keymap_common (note - this has a split backspace and right shift. Also, I'm not an expert by any means, but this is what I'm currently working on and seems to be doing fine...Also, its WIP, once I've got it confirmed I'll post it somewhere people will actually see it...Oh, and I've had a few beers...).
keymap_common
Code: [Select]
#define KEYMAP_ISO( \
    K00, K01, K02, K03, K04, K05, K06, K07, K08, K09, K0A, K0B, K0C, K0D, K49,\
    K10, K11, K12, K13, K14, K15, K16, K17, K18, K19, K1A, K1B, K1C, K1D, \
    K20, K21, K22, K23, K24, K25, K26, K27, K28, K29, K2A, K2B, K2C, K2D, \
    K30, K31, K32, K33, K34, K35, K36, K37, K38, K39, K3A, K3B, K3D, K3C, \
    K40, K41, K42,           K45,                     K4A, K4B, K4C, K4D  \
) KEYMAP( \
    K00, K01, K02, K03, K04, K05, K06, K07, K08, K09, K0A, K0B, K0C, K0D, \
    K30, K31, K32, K33, K34, K35, K36, K37, K38, K39, K3A, K3B, K3C, K3D, \
    K40, K41, K42,           K45,                K49, K4A, K4B, K4C, K4D  \
keymap
Code: [Select]
KEYMAP_ISO(
   ESC, 1,   2,   3,   4,   5,   6,   7,   8,   9,   0,   MINS,EQL,  BSPC, GRV,\
           TAB, Q,   W,   E,   R,   T,   Y,   U,   I,   O,   P,   LBRC,RBRC, BSLS,     \
           CAPS,A,   S,   D,   F,   G,   H,   J,   K,   L,   SCLN,QUOT,NUHS,  ENT,     \
           LSFT,NUBS,Z,   X,   C,   V,   B,   N,   M,   COMM,DOT, SLSH, RSFT, FN0,     \
           LCTL ,LGUI,LALT,          SPC,                     RALT,RGUI, APP, RCTL),
« Last Edit: Sat, 18 July 2015, 17:59:20 by Hzza »
Offline wlhlm
« Reply #5047 on: Sat, 18 July 2015, 18:38:52 »
:eek: I think I have to correct myself from interesting build to impressive build!
Offline heeliqin
« Reply #5048 on: Sat, 18 July 2015, 19:37:32 »
Delivery address change, has been submitted
Offline chromatically
« Reply #5049 on: Sun, 19 July 2015, 09:45:46 »
keymap_common
Code: [Select]
) KEYMAP( \
keymap
Code: [Select]
KEYMAP_ISO(
love that BoW. very beautiful board!
