Author Topic: Keycaps not all the same height?  (Read 3914 times)
Offline WarNutts
« on: Thu, 21 March 2013, 19:56:47 »
Hi guys I ordered some vortex dye sub black on black keycaps today from qtan.  Some keys are noticeably higher than other keys in the row. Anyone else have this problem with these keycaps?  Is this normal or something?
Offline esoomenona
  • Gnillort?
Re: Keycaps not all the same height?
« Reply #1 on: Thu, 21 March 2013, 20:00:09 »
Did you make sure to push them all the way down? Sometimes you think you pushed down all the way, but you need to push harder.
Offline WarNutts
« Reply #2 on: Thu, 21 March 2013, 20:32:07 »
lmaooooo thanks man that fixed it your the best  :))
Offline mattics
« Reply #3 on: Thu, 28 March 2013, 15:13:39 »
Slightly off topic. But is the space bar with the vortex universal with 6 or so tabs on the bottom? I wouldn't mind a set for my Leopold.
