Author Topic: Noppoo Choc Mini Space Bar  (Read 7725 times)
Offline evolz
« on: Fri, 22 March 2013, 03:00:24 »
Hey I was wondering if anyone could give me some info as to wear I can find a stock Space Bar replacement for my Choc Mini? Also If ant of you that have the Choc Mini
 could point me in the right direction as to what Key Caps are the closest to the stock keys. Any Help would be great Thanks...
Offline deazncy
Re: Noppoo Choc Mini Space Bar
« Reply #1 on: Fri, 22 March 2013, 03:06:07 »
I actually had the same question. I tried to look around google, but no luck..
“Do not pray for an easy life, pray for the strength to endure a difficult one” -Bruce Lee
Offline evolz
« Reply #2 on: Fri, 22 March 2013, 03:19:12 »
Well that sucks, Maybe I can Find someone on here that has one they are not using.
Offline longweight
  • philanthropist
« Reply #3 on: Fri, 22 March 2013, 03:26:21 »
You will probably have to buy a whole board to get a new spacebar as there are no spacebars that fit the Choc Mini so everyone will be using the stock one.
Offline evolz
« Reply #4 on: Fri, 22 March 2013, 16:22:33 »
Hmmm, Well then has anyone on here ever made keys before I am a machinist and I I have made molds for customers in the past I wonder if I just make a mold out of aluminum if that is what they use to make there key cap molds? Also If someone could give me an idea of how I go about getting the plastic to pour into the mold?
Offline Skull_Angel
« Reply #5 on: Fri, 22 March 2013, 16:41:10 »
The Making stuff together forum section might be what you're looking for, there's a few threads there that have people with some experience in this.
Offline SmallFry
« Reply #6 on: Fri, 22 March 2013, 16:57:10 »
Wait a second... how big is the space on the Choc Mini... 6x?
Offline Zifle
  • Nyaaa
« Reply #7 on: Fri, 22 March 2013, 17:02:18 »
5.5x iirc
I like cats.
Offline TrueOP
« Reply #8 on: Fri, 22 March 2013, 18:28:12 »
Same question here as OP.
I saw Feng had cool rainbow caps version of white choc mini but i haven't seen any option from noppoo or secondary sources for just only the keycap set.  I'd buy if some1 had a nice full set of keys including modifiers in dark/light grey or light blue thick pbt like the imsto keys.
http://www.ebay.com/itm/Rainbow-Scheme-Noppoo-Mini-w-Black-MX-Switch-Mechanical-Keyboard-/330806713386?pt=PCA_Mice_Trackballs&hash=item4d059ddc2a
« Last Edit: Fri, 22 March 2013, 18:30:26 by TrueOP »
Noppoo Choc Mini
Offline Jocelyn
  • 조셀린
« Reply #9 on: Fri, 22 March 2013, 18:32:10 »
I saw Feng had cool rainbow caps version of white choc mini but i haven't seen any option from noppoo or secondary sources for just only the keycap set.  I'd buy if some1 had a nice full of keys including modifiers in dark grey or light blue thick pbt like the imsto keys.
I think that would look really good. Now all we need is dark grey thick PBT (Ivan hinted at R3 GB for this), because we all know Imsto's gray caps aren't even kinda dark :)
Offline speedygonz
« Reply #10 on: Mon, 18 August 2014, 20:23:38 »
http://www.shapeways.com/model/2510099/blank-spacebar-keycap-5-5x.html?materialId=25
Apologies for digging up an old thread but there's a online store that 3D prints custom spacebars for the Choc Mini. Thought you guys might be interested.
Offline Oobly
« Reply #11 on: Tue, 19 August 2014, 01:09:18 »
Haha, someone made a shapeways model for it :)
I wonder how the Nylon feels compared to the original POM or replacement ABS or PBT? Anyway, at least there are now some options for people who want to replace their Choc Mini caps. The colours will probably be hard to match up, but it does give the Choc Mini a bit more acceptability.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
