Author Topic: How I currently use my Dolch set without moogle  (Read 3664 times)
Offline khaangaaroo
« on: Fri, 22 March 2013, 14:21:58 »
I'm waiting for the white on blue modifiers from the RainDrop group buy. I think they will go nice with the white on gray Dolch. But here's now I'm enjoying my incomplete set in the meantime:
Numpad keys as modifiers and a black PBT spacebar. I'm also missing the ~ and 1 number row keys.
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: How I currently use my Dolch set without moogle
« Reply #1 on: Fri, 22 March 2013, 14:30:51 »
You want a moogle?
Offline khaangaaroo
« Reply #2 on: Fri, 22 March 2013, 14:34:45 »
I dunno. I'm also not a fan of the incorrect profile del, end, pg down keys. The RainDrop set will let me replace those and fill in the missing ~ and 1.
Offline jwaz
  • * based mod
« Reply #3 on: Fri, 22 March 2013, 14:36:11 »
How did you end up with an incomplete set like that?
Offline khaangaaroo
« Reply #4 on: Fri, 22 March 2013, 14:38:23 »
I found a Dolch board on ebay for cheap cause it was missing a few keys.
Offline eth0s
  • Peace & Love
« Reply #5 on: Fri, 22 March 2013, 14:43:26 »
Get a moogle from JesuswasaZombie, if he has one.  You will be much happier.  IMO a mix-matched set with Dolch and Raindrop will not look as good.
@JesuswasaZombie:  sell him a moogle kit (assuming you have one).  As for an incomplete set, it looks like he is only missing the 1! key from the number row, otherwise the set looks complete, and in very good shape.
@OP:  is your spacebar upside down?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Fri, 22 March 2013, 15:24:41 »
LOL. I feel like I went back in time on the forum a few years before patch kits. GMK white on purple will look better than some crummy SP keys.
Offline khaangaaroo
« Reply #7 on: Fri, 22 March 2013, 15:31:33 »
Yup, it's more comfortable for me that way. I use my spacebar for panning more than I do typing.
