Author Topic: Kenshington Slimblade vs expert? Which one is better?  (Read 15212 times)
Offline hdsound
« on: Sat, 23 March 2013, 16:01:48 »
Kenshington Slimblade or expert?
I'd like to buy one of the two.
And, I know slimblade's lack of programmable buttons is updated.
In the president situation, Which one is better to buy?
P.s. I use Mac Osx and windows.
     to use logic and cubase
« Last Edit: Sat, 23 March 2013, 16:03:20 by hdsound »
Offline zulios
Re: Kenshington Slimblade vs expert? Which one is better?
« Reply #1 on: Mon, 25 March 2013, 14:57:21 »
Quote from: BarackObama
Errr... Joker ?
Both are interesting.
The expert has a scroll ring that makes it great. Side buttons can be pressed at the same time to be used as 5th and 6th button as well, which is interesting to set up for drag & drop for example. However it is way too much inclined in my opinion for a long use. It puts your wrist in a bad position unless you can adapt your tray, in such case it's probably the best of the two.
The slimblade is flat, and more comfortable to me. The "twist ball to scroll" is nice but not as good as the scroll ring. I've settled on it anyway since I'm not good enough to mod my tray :p
Tipro matrix - mx black
Offline berserkfan
« Reply #2 on: Thu, 04 April 2013, 09:08:11 »
Slimblade is not really programmable. Just 4 buttons. It's not expert mouse where you can program a function when you click a combo of 2 buttons
I think Kensington is very stupid to leave that out
Offline vun
  • Just one more thing
« Reply #3 on: Thu, 04 April 2013, 12:55:41 »
You do have 2-button combos on the Slimblade. Currently I have my slimblade set up for left hand use, with the upper left button as middle click and upper right as play/pause. Pressing both upper buttons will skip to the next song and the two lower buttons will skip to previous song, but you can make them to pretty much what you want.
Offline berserkfan
« Reply #4 on: Fri, 05 April 2013, 07:28:40 »
OK. I don't understand this. I downloaded and updated my trackballworks less than 60 days ago, and I can assure you there were no such dual-key options!
 >:D >:D >:D :'( :-\ :-X :-[
Offline vun
« Reply #5 on: Fri, 05 April 2013, 08:36:39 »
Your TBW doesn't look like this?
Offline berserkfan
« Reply #6 on: Fri, 05 April 2013, 15:38:58 »
aha i see the problem
me: windows7
you: mac osx
Offline Glissant
« Reply #7 on: Fri, 05 April 2013, 15:47:14 »
His window seems to be a skinned version of windows, not OS X, but I could be wrong.
Have you installed the January 13 2013 update of the TrackballWorks™ Software?
Offline vun
« Reply #8 on: Fri, 05 April 2013, 15:54:09 »
Yeah, it's just win7 with a custom theme.
Offline berserkfan
« Reply #9 on: Sat, 06 April 2013, 08:09:32 »
Ah??? How did I miss that?
I thought I reinstalled my ken drivers in late Feb. But I actually have version 1.1. That is 1.1.18!
update:
???? I don't understand!
I went back to kensington, downloaded the latest, http://www.kensington.com/kensington/us/us/s/1550/softwaredrivers.aspx
1.1.18 from this page (yes, that's the same link I used in February), installed it, and again I wind up with TrackBallWorks 1.1!
I am the administrator - this is the only account on my computer. So what went wrong?
« Last Edit: Sat, 06 April 2013, 08:21:17 by berserkfan »
Offline berserkfan
« Reply #10 on: Sat, 06 April 2013, 08:24:30 »
here, guys! this is really annoying me! how can my peers be enjoying the full benefit of programmable buttons when I have exactly the same updated software? (ps mine is Win7 Home)
 :-X
17933-0
Offline esoomenona
  • Gnillort?
« Reply #11 on: Sat, 06 April 2013, 08:28:38 »
Maybe try uninstalling the whole thing, then redownloading the update and installing?
Offline berserkfan
« Reply #12 on: Sat, 06 April 2013, 11:55:45 »
Tried already
but I notice you mention the word update, whereas I downloaded the driver based on the link they gave. If it is something that appears in a 'patch', then I don't have it and can't see it on the page.
I understand Kensington has different versions of software for Europe and US. I dled from the US version.
quote author=esoomenona link=topic=41562.msg844435#msg844435 date=1365254918]
[/quote]
Offline smuvmoney
« Reply #13 on: Sat, 06 April 2013, 15:11:21 »
Like BerserkFan, I have the same issue running Win7 Ultimate.  If I look under Programs and Features, TrackballWorks is listed as version 1.1.18 (you can add the Version column if it is not shown).  This is really befuddling.  I would happily trade in my Expert Mouse trackball if I got the chording to work on the SlimBlade in Win7.  I will try uninstalling and reinstalling with just the SlimBlade as I have both an Expert Mouse and Slimblade connected currently.  Any help or feedback would be welcome.
Offline vun
« Reply #14 on: Sat, 06 April 2013, 15:18:15 »
Hm, I can't really give any info regarding my version and whatnot at the moment since I'm not at my desktop computer, but if this is still a problem when I get back home I'll post whatever relevant info I can find.
Offline Surnia
« Reply #15 on: Sat, 06 April 2013, 22:50:47 »
My Trackballworks is listed as 1.1 as well, I have options for the dual buttons (but I don't use them).
Possible thing I noticed: your trackballworks has two devices listed as connected: could this be what the issue is? Maybe try disconnecting the orbit first?
Another difference from mine: my Slimblade's listed as revision 1.07
Noppoo Choc Mini with MX Black | Filco 104 MJ2 Ninja with MX Black
Offline smuvmoney
« Reply #16 on: Sat, 06 April 2013, 23:07:13 »
Surnia - that's the problem!  Mine is a revision 1.05 when looking at TrackballWorks.  It may be time to shell out some dough if I can guarantee that I get a revision 1.07.  I don't want to go through Kensington proper since they charge $130 USD, but if I go through another vendor, I'll have to plead my case to make sure it is a 1.07 or it is a guaranteed RMA.  Decisions decisions...oh and good looking out/thanks for the help.  ;D
Offline berserkfan
« Reply #17 on: Sun, 07 April 2013, 01:36:55 »
Awesome! I love this forum!
You guys have helped me arrive at the source of the problem! Yes, I am also Rev 1.05!
Is this a hardware problem that can never be solved without buying a new Kensington?
(I don't see any firmware updates)
Offline Surnia
« Reply #18 on: Sun, 07 April 2013, 22:28:05 »
As to that, you might want to throw an email at Kensington to see what the difference is between the revisions (if it really is the capacity for the unit to understand dual clicks).
Sorry, that's as far as I know/see, as I already re-map the presses natively inside programs (love gesture controls, and the back/forward abilities with left + right clicks). good luck on the solution though!
Offline smuvmoney
« Reply #19 on: Fri, 17 May 2013, 16:32:34 »
I forgot to reply back to this topic earlier.  I did buy the Slimblade Trackball directly from Kensington after emailing them about the chording.  The product version was 1.07 and had chording with Trackballworks 1.18.  Kensington kindly gave me a 15% off coupon after the email correspondence.  I used that to buy two more -  one for the laptop and one for work.  They replaced Expert Mouse/Mice in all cases.  I was so ludicrously ecstatic to have chording that the financial hit was worth it. :) I hope this topic helps others.
Offline daerid
    • Rossipedia
« Reply #20 on: Sun, 19 May 2013, 02:15:32 »
Yeah, I've heard good things about Kensington support. My Slimblade occasionally would catch, and I just thought it was dust. Turns out it was a small nick in the ball that I found today. Hopefully they can send me a replacement ball without much hassle.
Offline yensteel
« Reply #21 on: Mon, 17 June 2013, 13:25:15 »
Just a small question, Which of these two devices require lighter button press?
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #22 on: Mon, 17 June 2013, 13:49:15 »
Hmmm I've really been wanting to buy a Kensington Slimbalde but I've heard that you can't customize the top 2 buttons just yet so I've been holding back :\ Hopefully they'll release a newer version.
Offline vun
« Reply #23 on: Mon, 17 June 2013, 14:00:57 »
Yes you can? If you look at my screenshot earlier in the thread you can clearly see that it's possible to rebind all the buttons.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #24 on: Mon, 17 June 2013, 14:01:59 »
I actually saw that a couple weeks back and totally forgot about it when I re-saw this thread :)) Let me read it again :P Thanks!
Btw, will this require some kind of firmware update?
Offline vun
« Reply #25 on: Mon, 17 June 2013, 15:01:09 »
No, it should work like that out of the box. Plug in the trackball, install TrackBallWorks and you're good to go.
Although you should be careful if you're planning on finding a used one due to the issues mentioned in this thread; older models don't allow for chording.
If you buy one new it shouldn't give you any problems.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #26 on: Mon, 17 June 2013, 15:50:44 »
Thanks for the response! I'll be sure to be wary of used ones. The price makes it hard to get new though. Really want this thing but not sure if I'm willing to drop $90 for it just yet but it's so damn pretty and cool.
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #27 on: Mon, 17 June 2013, 17:28:03 »
I began using a Slimblade after using an Expert Mouse for two years. The switches seemed harder to push on the Slimblade but that may be because I may not have been hitting the sweet spot on the buttons. The SB buttons are an integral part of the case top, where the EM has a more complex button structure which may offer less resistance over the entire surface of the button. If you press the SB buttons at the 3:00 and 9:00 position it is lightest because it is the greatest distance from the pivot point but resistance increases as you get closer to the hinge point.
I didn't use the Slimblade in its natural form long enough to get use to that.
Expert Mouse button exposed
25683-0
The physics of the EM button seems to lend itself to a larger sweet spot.
Offline yensteel
« Reply #28 on: Mon, 17 June 2013, 23:03:54 »
Thanks for the help. So, if you press the Slimblade buttons as you would with an Expert Mouse, then it would actually be more difficult to press? Also, are the buttons of the two trackball mice stiffer than conventional mice?
Offline kurplop
« Reply #29 on: Mon, 17 June 2013, 23:42:49 »
It depends on where you like to press them. If you press close to the sides of the ball it will feel lightest. I may not be the best one to answer your second question because I can't feel my fingers half the time anyways but I never noticed the Expert Mouse buttons to require more pressure than most mice. The actual force required may not be as important as your orientation as you press the switch.
Offline yensteel
« Reply #30 on: Tue, 18 June 2013, 06:15:55 »
Oh, I see. Thanks for the help!
