Author Topic: IBM Model M with Original Packaging  (Read 2006 times)
Offline r3dx
« on: Mon, 25 March 2013, 12:00:53 »
http://www.ebay.com/itm/IBM-Enhanced-Keyboard-model-M-clicky-keyboard-in-Org-Pkg-Un-tested-Cond-No-Res-/160994133052?pt=PCA_Mice_Trackballs&hash=item257bff843c
Doesn't look like it's in that bad of condition. Hopefully it is in working order. Good luck to anyone that bids on it.  :D
Filco MJ2 Ninja | CM Storm QFR | CM Storm QFR | IBM Model M | IBM Model M SSK | ErgoDox |
LZ-GH
Re: IBM Model M with Original Packaging
« Reply #1 on: Mon, 25 March 2013, 12:04:27 »
An early-1989 probably has the heavy plate and wire stabilizers.
Looks like a desirable item and I would guess that it should fetch $100 or more.
« Last Edit: Mon, 25 March 2013, 16:21:10 by fohat.digs »
- Oliver Willis 2026-08-01
Offline MarkPharaoh
« Reply #2 on: Mon, 25 March 2013, 13:14:16 »
An early-1998 probably has the heavy plate and wire stabilizers.
"Recived a question and want to add the following information as it might be important...Date: 08 Mar. 89, Part No. 1391401, ID No. 2043400"
Current: HHKB Pro 2, 87u 55g 10AE, FC600C, Model M 1391401
Offline tricheboars
  • Keyboards are Important!
« Reply #3 on: Mon, 25 March 2013, 13:14:17 »
looks good to me. i would grab this if it stays under 70$.
« Reply #4 on: Mon, 25 March 2013, 16:15:05 »
I don't think a grey oval label will have the wire stabilizers, but nevertheless, this is a good find.
« Reply #5 on: Mon, 25 March 2013, 16:22:20 »
I think the switch-over from wire stabilizers to plastic sleeves happened early-mid-1989.
Offline MarkPharaoh
« Reply #6 on: Sun, 31 March 2013, 15:41:01 »
I won the auction. It uses wire stabilizers.
