Author Topic: Double firing key - how to fix  (Read 1130 times)
Offline automator
« on: Mon, 25 March 2013, 12:51:10 »
On Kinesis Advantage Pro MPC/USB I have a key (dash/underscore keycap ) which sometimes double--fires  (like just now).
Anything quick to try or does the switch need to be replaced?
Offline bazemk1979
Re: Double firing key - how to fix
« Reply #1 on: Mon, 25 March 2013, 18:49:12 »
people had this fixed by removing the keycap and checking if there is something stuck there, blow it with air just in case. If still continues to do the same, desolder the switch and solder new one.
