Author Topic: Fixing pinging brown switch?  (Read 1350 times)
Offline frowni
  • i love typing!
« on: Mon, 25 March 2013, 19:30:52 »
Hey there,
I just made a quick text with my new Filco majestouch 2 cherry browns, some of they keys are pinging..i can notice that the board itself pings a bit, thats ok, since its metal and all, but there are certains keys(V, Y and U) pings! I removed the keycaps, pressed&released the switches, and they ping like bells :) Like a spring sound...Is there a way to fix it?
Is there a possibility that it might go away once i break them in?
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
Re: Fixing pinging brown switch?
« Reply #1 on: Mon, 25 March 2013, 19:32:51 »
Here we go again... ping!
No, there's nothing you can really do about it.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline Lunartuna
  • Good bye money!
« Reply #2 on: Mon, 25 March 2013, 19:38:15 »
Learn to love it!
Think of it as assurance you're typing on such a solid board that the sound vibrations of the springs carry right through it. No vibrations being absorbed by crappy soldering or bad switch mounting  ;)
(Just go with it guys)
Shine 2 TKL - Choc Mini
Offline frowni
  • i love typing!
« Reply #3 on: Mon, 25 March 2013, 19:43:08 »
Will do that :) So it doesn't go away by itself right... :)
Offline Surnia
« Reply #4 on: Mon, 25 March 2013, 20:23:53 »
pinging! woohoo. I tend to wear headphones so I don't hear it but I don't find it annoying at all. Its also very odd for me, I initially owned a Das with brown switches and the H key began to ping.. changed to a Filco with blacks and just recently the H on this one's beginning to ping.
Coincidence? I'm not sure if its how I type that's causing it either. I'll have a third sample to the test once Keycool and Qtan get the production lines back in order and pickup a board for work...
Even then, I don't get pinging unless I really hammer down on the keys and bottom out like mad (picked up the blacks because they're helping NOT bottom out).
Noppoo Choc Mini with MX Black | Filco 104 MJ2 Ninja with MX Black
