Author Topic: Bloomberg Terminal keyboard switch type?  (Read 6664 times)
Offline killazys
« on: Tue, 26 March 2013, 10:50:05 »
This. I really like how the switches feel, but all my research has turned up that it's a "mechanical switch" of some sort.
Does anyone have any knowledge of what the switches used here are?
Offline esoomenona
  • Gnillort?
Re: Bloomberg Terminal keyboard switch type?
« Reply #1 on: Tue, 26 March 2013, 10:52:05 »
What kind of travel are you getting on them? Looks like the could be scissor switches based on the height of them.
Offline SmallFry
« Reply #2 on: Tue, 26 March 2013, 10:53:28 »
That's what I thought also, though look at the finger print reader on the left, and the thickness of the cable. Thick cable. Try getting MiMiC to make one of those, I dare you. :P
Offline killazys
« Reply #3 on: Tue, 26 March 2013, 15:41:22 »
It doesn't feel like a membrane-type rubber dome keyboard. I know the older ones were membranes, but maybe my fingers just suck.
Travel is about 3mm, and there's a clicky actuation point in the middle of the key.. it almost feels like rubber dome but hard.
