Author Topic: Idea on Switch Modifications  (Read 2454 times)
Offline eRadicatedZomBiE
  • It's OK, I'm A Doctor.
« on: Wed, 27 March 2013, 10:49:23 »
On a switch, when they say 50 million press guarantee (or something along those lines).
What on the Switch actually fails?
I would assume compressing the spring over and over again, creates a wear on the spring sort of like bending a paperclip back and forth until it degrades and breaks off.
What if on the bottom of the switch where the Spring rests you have a mechanism like that on a click pen that rotates to have the tip out and then retracts. This would rotate the spring a little bit every time you pressed a key, relieving the same spot of having pressure on it and would make the spring last that much longer.
The only downside I see is, it maybe cheaper to just buy a new switch than to add another moving part to it.
If this has already been done or I'm way off of what breaks down in the switch compartment, I apologize.
EDIT: I may have posted in the wrong area...
CM QFR | WASD V1 | Flico MJ2 LE Blue | Ducky 78 | Ducky DK9008G2 Pro LE  |Phantom |
Ergodox
My WTB Thread
Re: Idea on Switch Modifications
« Reply #1 on: Wed, 27 March 2013, 11:15:27 »
Only Rootwyrm can answer about the mechanics of infinite wear, but it has been my experience that switches fail in many different ways.
With the keyboards that I have owned, far more of the dead switches are due to electrical problems than mechanical parts wearing through.
After you have put in your 50 million strokes, just buy a new keyboard. At some point it isn't worth upgrading the parts.
I will certainly not live long enough to wear out the 4 Model Fs and half-dozen Model Ms that I own.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
« Reply #2 on: Wed, 27 March 2013, 12:44:44 »
I believe that the leaf spring inside the switch is likely to break before the coiled spring does.
I had the housing of a switch (the one in the middle) break apart. (Yes, I know the colours are weird. The blue switches look green)
« Last Edit: Wed, 27 March 2013, 12:47:49 by Findecanor »
