Author Topic: Is there a problem with my HHKB?  (Read 1966 times)
Offline Carlos
« on: Wed, 27 March 2013, 22:47:17 »
Greetings everyone!
I recently purchased a Happy Hacking Keyboard Pro 2, and I am not sure if mine is defective or not.  I'm hoping someone can help me...
On many of the alpha keys: if I press down firmly, hold the key down firmly, and then release it slowly, there is an audible click a little less than midway through the upstroke.  This click occurs before the switch is fully depressed and hits the upper limit of the assembly.
Is this a normal sound?  Can someone test theirs?
Other than this, I am very thrilled with the keyboard.  Fine forum here
Offline Skull_Angel
Re: Is there a problem with my HHKB?
« Reply #1 on: Wed, 27 March 2013, 22:59:55 »
Sounds normal considering it uses Topre switches, I could be wrong though.
Offline Carlos
« Reply #2 on: Wed, 27 March 2013, 23:12:10 »
Hmm...not all of them seem to do it, and some seem to do it a little more than others..
I tried to take a video, but the sound didn't really come out too well.
Thank you Skull_Angel for your reply
Offline orlando
« Reply #3 on: Wed, 27 March 2013, 23:20:07 »
You are probably just hearing the sound of the spring ... I tried to replicate the firm press and slow key release and the only sound I could identify was the spring. Then again the sound I hear is very low and I had to pretty much place my head near the keyboard to hear it.
Offline daerid
    • Rossipedia
« Reply #4 on: Thu, 28 March 2013, 00:10:33 »
On new Topre switches the springs tend to be a bit stiffer and stick a bit more.
Once they're broken in it should reduce considerably. My HHKB still does it (I don't use it nearly enough as I'd like).
Offline Carlos
« Reply #5 on: Thu, 28 March 2013, 00:43:17 »
That's exactly what I think is happening...thank you daerid :)
Offline drdoooom
« Reply #6 on: Fri, 29 March 2013, 16:37:12 »
give it a few weeeks. same thing happened with mine.
Offline Carlos
« Reply #7 on: Tue, 02 April 2013, 00:32:11 »
Was browsing Reddit, and someone else posted a video of exactly the noise.  Adding it here:
Thanks everyone for your responses!
