Author Topic: KBT Race Cherry MX Blue vs White  (Read 3133 times)
Offline forzetk0
« on: Thu, 28 March 2013, 07:00:34 »
Hello Guys,
I decided to buy KBT Race keyboard and it will be my first mechanical keyboard.
Did a little research where to by and found mechanicalkeyboards.com (is this store legit ?)
Noe the question: they don't have LED versions at all so I am going to get non LED one, but they have two models available: Blue switch and white switch with PBT keykaps.
S
I was watching youtube for revews of the switches in general and i liked MX Blue, bit what is MX White feels/sound like ?White switch is less noisy and clicky? I am going to use my keyboard for programming/general typing/gaming.
Thanks for all your help !!!!
Re: KBT Race Cherry MX Blue vs White
« Reply #1 on: Thu, 28 March 2013, 07:05:24 »
Yes, Mechanicalkeyboards.com is legit. They have a vendor forum here and ShakeR, an employee of the site, is an active member here.
I think whites are a bit heavier than blues. They're smoother since they come lubed and have a dampened click. I will probably be getting these for my GH60. I also heard they're lovely if you swap out the springs for lighter ones. Blues are my favorite switches though.
Just remember if you're getting a Race, replacing the caps with a fullset is a bit hard since the layout is a bit weird. I believe the right shift is shorter than normal. But maybe someone can help me since I can't remember off the top of my head.
Offline SmallFry
« Reply #2 on: Thu, 28 March 2013, 07:26:21 »
As well as the escape key, young CPTBadAss :P. They use Row 5 OEM profile for the Escape/FRow, of which I've only seen the Race use and perhaps a single odd off-brand Chinese OEM board.
« Reply #3 on: Thu, 28 March 2013, 07:28:51 »
Keyboard Prof strikes again :D
Hooray knowledge!
Offline OrpheusX
« Reply #4 on: Thu, 28 March 2013, 09:25:28 »
Hello Guys,
S
I'm also a programmer and have two Races, one with white switches and one with red. I don't have any blues but I *think* the springs are in the same ballpark as the reds. The whites are _much_ heavier. If you're a good typist you may not have any issues with whites. I'm fairly terrible and have become so used to bottoming out that I find myself trying to do that on the whites. Makes my hands tire pretty quickly. If I could strike each key evenly I likely wouldn't have any problems since they actuate well above the bottom of the switch. I'm thinking about doing what CPTBadAss mentions and swapping out the springs for something lighter.
Offline forzetk0
« Reply #5 on: Thu, 28 March 2013, 09:51:09 »
Hey Guys,
THANKS A MILLION FOR YOUR HELP!
Now I am confident that MX Blues are the ones that I am going to proceed with.
I am not really going to remove/replace any keycaps I think but if I would like to do so, maybe I should get Ducky Shine 2 TKL ? Only one thing that I don't like that Shine 2 is larger that Race and I would like to save some space on my desk.
Please let me know what you think folks!
THANKS!!!
Offline OrpheusX
« Reply #6 on: Thu, 28 March 2013, 14:51:03 »
No TKL in my collection yet so I can't compare. I like my Races but, being a crummy typist, I wish the right shift key were bigger; I sometimes miss.  :p
