Author Topic: Need Some Help Picking Out A Keyboard  (Read 2143 times)
Offline Nawit
« on: Thu, 28 March 2013, 19:42:54 »
Hey guys,
Still a newbie to mechanical keyboards. I have my hands on the Ultimate Switch Tester as of right now I have tried all the switches and like all of them but I still feel like I love blues and have began to love greens. Currently I am using the Blackwidow from Razer and even just from the switch tester board I can tell that my keyboard is pretty poorly built compared to other boards out there.
Now I need your help. Being a noob in this field, what would you recommend for me for a new keyboard? I'm looking for:
- Backlit keys
- Cherry MX Blues/Greens
- Full board (with numpad)
- Sturdy board with sturdy key caps
- $130-140 budget.
Thanks for all your help. I really do appreciate it.
Offline omgFiRE
Re: Need Some Help Picking Out A Keyboard
« Reply #1 on: Fri, 29 March 2013, 02:29:56 »
- Backlit keys
If by sturdy key caps you imply PBT, then only Deck Legend comes to my mind as backlit PBT.
Since you tend to like stiff greens, I would recommend forget about backlit and try buckling spring keyboard like Unicomp or IBM Model M. Unicomp starts at $79 and comes with PBT keycaps.
« Last Edit: Fri, 29 March 2013, 03:57:17 by omgFiRE »
White Filco Ninja Majestouch-2 Tenkeyless FKBN87M/EFW2 (Cherry MX Brown), CM Storm QuickFire Rapid SGK-4000-GKCL1-US (Cherry MX Blue)
Offline zoolzoo
« Reply #2 on: Fri, 29 March 2013, 08:59:58 »
This is kinda simple, the only board that meets all of your specifications will be a Ducky. Well, technically Razer as well, but that doesn't count does it?
Click this link:
http://mechanicalkeyboards.com/search.php?switch_id=3&size=Full+Size&keyword=ducky&backlit=on&in_stock=on
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline omgFiRE
« Reply #3 on: Fri, 29 March 2013, 09:58:22 »
PS: if you are happy with ABS, then here is a [incomplete] list of backlit full size mech keyboards:
Ducky DK9008 Shine II
CM Storm QuickFire TK, Trigger
Gigabyte Aivia Osmium
Rosewill Illuminated RK-9100 (iRocks)
Mionix Zibal
Thermaltake meka
iOne: Razer BlackWidow Ultimate, QPAD MK-80, QPAD MK-85, iOne Scorpius-M10BL, iOne Scorpius/XArmor U9BL, Tesoro, Max Durandal, Nighthawk X7, X8, X9
Corsair Vengeance K70, K90
« Last Edit: Fri, 29 March 2013, 10:03:45 by omgFiRE »
Offline omgFiRE
« Reply #4 on: Fri, 29 March 2013, 10:09:02 »
Really? What about: RK-9100 or CM Trigger, or Nighthawk X7, etc?
Offline zoolzoo
« Reply #5 on: Fri, 29 March 2013, 10:47:42 »
Nice, well..
I didnt know the Rosewill came illuminated now, I thought the Trigger was browns only, and Max Keyboard...blah.
