Author Topic: Need a small portable keyboard recommendation  (Read 1729 times)
Offline BADBADNOTGOOD
« on: Sat, 30 March 2013, 19:50:42 »
Im thinking scissor switch.  Bluetooth would be nice but not necessary.  (Relatively) Quiet. And cheap. Cant be spending all my monies on a non mechanical...
I want to use it with my nexus 7, xbox, and for occasional quiet (but competitive) nighttime gaming
Im thinking Microsoft Arc...  but thats because its the only keyboard i have found so far that actually looks decent
Thanks in advance.
Offline daerid
    • Rossipedia
Re: Need a small portable keyboard recommendation
« Reply #1 on: Sat, 30 March 2013, 20:02:10 »
Cherry G84
$16, free shipping, mechanical low-profile keys. I have one and it feels great. USB not bluetooth though.
Actually, I was looking for a use for mine, and I totally forgot about the XBOX, thanks!
Offline Jocelyn
  • 조셀린
« Reply #2 on: Sat, 30 March 2013, 20:05:22 »
Cherry G84
This^ or this if you want and I quote bazemk1979, "the mother of all ML's dyesub legends 2 tone"
http://www.ebay.com/itm/CHERRY-G84-4100-AT-SLIM-LINE-Keyboard-G84-4101PAAUS-/350589764757?pt=PCA_Mice_Trackballs&hash=item51a0c74495
« Reply #3 on: Sat, 30 March 2013, 20:11:49 »
Completely forgot about ML switches. Thanks!
but are they really that much better than scissor switches?  I only ask because of the lower profile of scissor switches.  But if ML is really much better then i will go with that Cherry keyboard.
Offline WhiteFireDragon
    • youtube
« Reply #4 on: Sat, 30 March 2013, 20:15:52 »
I have one of those G84's and I don't really like the feel of the switches. They're too scratchy compared to MX. You'd also have to press at the center of the keys, otherwise even a little bit off-centered and it's much stiffer to press down. But then again, you can get a board with ML switches for a lot cheaper.
« Reply #5 on: Sat, 30 March 2013, 21:07:19 »
Any wireless recommendations? I would need a usb extension cable if i do end up hooking it up to my xbox and the wire with a tablet might be a bit off putting. Im feeling wireless would be the more practical of choices right now.
Edit: Maybe something like that apple keyboard? Bluetooth for tablet. Then find a bluetooth to usb adapter for xbox and pc?
« Last Edit: Sat, 30 March 2013, 21:45:45 by BADBADNOTGOOD »
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #6 on: Sun, 31 March 2013, 00:00:43 »
Check out Lenovo's Thinkpad USB keyboards. I think they are the best of the scissor switch boards.
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
Offline daerid
    • Rossipedia
« Reply #7 on: Sun, 31 March 2013, 01:32:23 »
Personally as far as scissor switches go, I'm a huge fan of the Apple Bluetooth keyboards.
